PCD float seems to be not working right
Eduardo__
PostPosted: Tue Aug 21, 2012 7:40 am     Reply with quote
I´m using PIC30F5013 and PCD compiler Version 4.124
floats seems not to be working right.
float ttt=0,ttt1=1,ttt2=2;
while(true) {
   delay_ms(1);
   if (ttt>ttt1) {
      liga(O_M3);   //The uC enters here. It is wrong!
      delay_ms(1);  //  :(
   else {
      desl(O_M3);
      delay_ms(1);
Sad Sad
Some suggestions?
Very thanks
Eduardo Guilherme Brandt
PostPosted: Tue Aug 21, 2012 8:00 am     Reply with quote
If the numbers are going to be integers, use integers instead....
Float comparisons have had 'intermittent' problems with PCD for quite a while.
<http://www.ccsinfo.com/forum/viewtopic.php?t=43918&highlight=pcd+float>
Several other examples as well.
Much safer to use scaled integers for example, and quicker as well.
Eduardo__
PostPosted: Tue Aug 21, 2012 8:17 am     Reply with quote
Thanks Ttelmah.
But floats are essential for my program. I do intensive fractional math calcs.
It have had already worked in the past, as it is.
Could it be a compiler version problem?
PostPosted: Tue Aug 21, 2012 8:46 am     Reply with quote
It appeared to work quite some time ago, but has been 'wrong' for various compilers for quite a while.
Seriously though I can't really envisage that you 'need' float comparisons. If you know the likely range of the numbers, much better to use scaled integers. If you just want to do a comparison, then convert the floats to integer for the comparison. So:
while(true) {
   delay_ms(1);
   if ((int32)(ttt*100)>(int32)(ttt1*100)) {
      delay_ms(1);  //  :(
   else {
      desl(O_M3);
      delay_ms(1);
Gives a 2 decimal place integer comparison, which does work.
Moan at CCS, but this has been happening off and on for several versions. You might want to see if the behaviour is the same with another type (float48 for example). I'd write 'round it' as being safer than relying on any CCS fix at present.
Eduardo__
PostPosted: Tue Aug 21, 2012 9:02 am     Reply with quote
yes, its the only solution.
thanks
Eduardo
Eduardo__
PostPosted: Tue Aug 21, 2012 10:08 am     Reply with quote
float48 is working fine also.
thanks
FvM
PostPosted: Tue Aug 21, 2012 1:37 pm     Reply with quote
I don't see the float compare error in present PCD V1.35.
