more power consumed in sleep mode 18f25k20
shardul
PostPosted: Tue Aug 07, 2012 7:28 am     Reply with quote
ccs 4.120, device:-18f25k20
I'm trying to make it sleep by a simple sleep(); instruction
facing strange problem, before sleep it takes 1.2mA & after 8.41mA.
I've tried all oscillator configuration!
.h file contains following code
#include <18F25K20.h>
#device adc=10
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES INTRC_IO                    //Internal RC Osc
#FUSES NOPBADEN                 //PORTB pins are configured as digital I/O on RESET
#FUSES NOLPT1OSC                //Timer1 configured for higher power operation
#FUSES NOHFOFST                 //High Frequency INTRC waits until stable before clocking CPU
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use delay(int=1M)
#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3)
Please guide me I'm stuck since a day Crying or Very sad
Gabriel
PostPosted: Tue Aug 07, 2012 8:13 am     Reply with quote
keep pins from foating.. set them as outputs and tie them to V+or GND.. allowing them to float will consume alot of power.
turn OFF all prehipedrals your not using... ADC, WDT, TIMERS, COMPARATORS, UART... you get the point...
changing oscillator frequencies will help you conserve power while running...
in sleep, the oscillator is off...
G.
CCS PCM 5.078 & CCS PCH 5.093
PostPosted: Tue Aug 07, 2012 8:19 am     Reply with quote
Gabriel has addressed the important aspects. Just a small correction, in sleep mode all oscillators except for WD and possibly 32 kKz crystal are off, digital modules aren't at risk to consume power.
shardul
tried that too
PostPosted: Tue Aug 07, 2012 8:34 am     Reply with quote
thanks for replying
i've tried your way before too .... no success
floating pin consume current ? idk Confused
i have 3 empty pins which are configured as o/p and @ logic 0.... will that affect ?
also shutting down the peripherals which are/will not used.
made WDT off ... still same result
i have big doubt on Internal pullups of port b !
i didnt get much about oscillator specified in datasheet Embarassed
thanks
PostPosted: Tue Aug 07, 2012 3:42 pm     Reply with quote
The following threads discuss how to reduce current usage in Sleep mode:
http://www.ccsinfo.com/forum/viewtopic.php?t=45094
http://www.ccsinfo.com/forum/viewtopic.php?t=44141
http://www.ccsinfo.com/forum/viewtopic.php?t=22402
http://www.ccsinfo.com/forum/viewtopic.php?t=19006&start=12
http://www.ccsinfo.com/forum/viewtopic.php?t=40938
Some of these threads are two pages long.
You shouldn't tie pins configured outputs to the power rails.
It will burn out the pin if the levels don't match. Just set
unused pins to be outputs and set them to a low level.
For example, if pin B0 not used in your design, then do this:
output_low(PIN_B0);
