changing frequencies
Gabriel
PostPosted: Fri Aug 03, 2012 8:21 pm     Reply with quote
hi,
First time trying this frequency changing deal...
from reading some of the posts here i concluded that:
at the beginning of my main:
while(!((SETUP_OSCILLATOR(OSC_NORMAL))& OSC_STATE_STABLE)); // Waits till oscillator is stable
Later in Main:
while(!((SETUP_OSCILLATOR(OSC_4MHZ))& OSC_STATE_STABLE)); // Waits till oscillator is stable
am i actually waiting for it to stabilize? or am i missing something..
seems to be working though...
going from 20M to 4M
16F886.
thanks!
CCS PCM 5.078 & CCS PCH 5.093
gpsmikey
PostPosted: Fri Aug 03, 2012 9:02 pm     Reply with quote
I have not done that, but don't forget if you change the osc. freq, you will also change any delay statements and any baud rates you are using.
mikey
mikey
Gabriel
PostPosted: Sat Aug 04, 2012 6:14 am     Reply with quote
yeap... im _very_ aware of changing the delay statement and baud rates...
im asking this question precisely because im having issues doing just that and i just want to clearout the small things...
i really dont have a clear idea on how to use the OSC_STATE_STABLE value or variable... i dont know what the hell it is ....
the .h file seems (from PCM's Comments on other posts) to mention that its not a return value but a mask to isolate the Setup_oscillator _actual_return value bits.... very confusing.
thanks..
G
PostPosted: Sat Aug 04, 2012 7:49 am     Reply with quote
In section 4.2 (oscillator control) of the datasheet it has this for the 31KHZ and HS oscillators:
bit 2 HTS: HFINTOSC Status bit (High Frequency – 8 MHz to 125 kHz)
1 = HFINTOSC is stable
0 = HFINTOSC is not stable
bit 1 LTS: LFINTOSC Stable bit (Low Frequency – 31 kHz)
1 = LFINTOSC is stable
0 = LFINTOSC is not stable
In the PIC16F886.h header file it has this:
#define OSC_STATE_STABLE 4
#define OSC_31KHZ_STABLE 2
So, the bit is used to determine when the oscillator has stabilized after a
startup or frequency switch.
You don't have to worry about it or do anything. When the
"setup_oscillator" statement is executed it will test the HFINTOSC bit and
wait until the oscillator is stable before continuing.
bkamen
PostPosted: Sat Aug 04, 2012 11:24 am     Reply with quote
Definitely read the section of the datasheet for your PIC a few times (soak it in) about the Oscillator... I did a few times and then experimented to make sure it was doing what I wanted.
I did an 18F46J11 project that switched between 10 and 40 MHz -- worked swell.
Had to deal with change in delays and baud rates -- but all was good once all those factors were accounted for.
-Ben
