Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
i2c between 1 PIC16F877 master & 2 PIC16F873 slaves
Post new topic   Reply to topic    CCS Forum Index -> Code Library
moacir_mendes
PostPosted: Mon Nov 10, 2008 7:37 pm     Reply with quote
I had a lot of problems during implementation of this circuit, more specifically with i2c protocol.
To get and send bytes between the master and one slave it works perfectly. But when I tried communicate with other slave PIC no one more communicate.
To solve this problem I do a test with SSPOV and BF bits, which indicates overflow on the buffer. If one of them are high I make it low.
#BIT SSPOV = 0x14.6
/*Indicates overflow - BIT 6 - SSPCON: SYNC SERIAL PORT CONTROL REGISTER (ADDRESS 14h)*/
#BIT BF = 0x94.0
/*Buffer Full - BIT 0 - SSPSTAT: SYNC SERIAL PORT STATUS REGISTER ADDRESS: 94h)*/
if (SSPOV || BF)
SSPOV = 0;
BF = 0;
The code is mess a bit, but it works fine Cool
It may help someone with these problems.
// -- SLAVE SOURCE CODE -- at address=0xA0
#include <16F873.h>
#device adc=8
#FUSES XT                   //High speed Osc (> 4mhz)
#FUSES PROTECT                  //Code protected from reads
#use i2c(SLAVE,sda=PIN_C4,scl=PIN_C3,address=0xA0, force_hw)
#BIT SSPOV = 0x14.6     //Indicates overflow
#BIT BF = 0x94.0           //Buffer Full
BYTE state, address, buffer[0x08];          // address and array of Bytes, change size to suit your needs
int valvula = 0;
int temp;
#INT_SSP NOCLEAR
void ssp_interupt ()
clear_interrupt(int_SSP);
   state = i2c_isr_state();
   if(state < 0x80)                 //master is sending data
      if(state == 0)
      if(state == 1)                   //first received byte is address
         address = i2c_read();
      if(state == 2)                   //second received byte is data
         buffer[address] = i2c_read();
   if(state == 0x80)                //master is requesting data
      i2c_write (buffer[address]);  //send requested data
   set_tris_c(0xFF);
   enable_interrupts(INT_SSP);      //enable I2C interrupts
   output_low(pin_a0);
   output_low(pin_a1);
   buffer[0x00] = 0b10000000;
   buffer[0x01] = 0b10000001;
   buffer[0x02] = 0b01000010;
   buffer[0x03] = 0b01000011;
   buffer[0x04] = 0b00100100;
   buffer[0x05] = 0b00100101;
   buffer[0x06] = 0b00010110;
   buffer[0x07] = 0b00010111;
      if (SSPOV || BF)
         output_high(pin_a0);
         SSPOV = 0;
         BF = 0;
      else output_low(pin_a0);
      if (BF) output_high(pin_a1);
      else output_low(pin_a1);
      if (!input(pin_b0)){
         SSPOV = 0;
         BF = 0;
      if (address == 23)
         valvula = !valvula;
         if (valvula) printf("VALVE ACTIVATED\n\r");
         else printf("VALVE DEACTIVATED  \n\r");
         address = 0x14;
// -- MASTER SOURCE CODE -- Sends to 0xA0 and 0xB0
#include <16F877A.h>
#device adc=8
#FUSES XT                       //
#FUSES WRT_50%                  //Lower half of Program Memory is Write Protected
#use i2c(MASTER, sda=PIN_C4,scl=PIN_C3, force_hw)
BYTE data = 0b00001111 /*15*/, result = 0, n;
#define end_1 0xA0     //FIRST SLAVE
#define end_2 0xB0    //SECOND SLAVE
BYTE recebe_i2c(BYTE end_disp, BYTE end_mem)
BYTE result2 = 0;
   i2c_start ();           //begin communication
   i2c_write (end_disp);       //send slave address
   i2c_write (end_mem);       //request slave internal memory address for analogue data
   i2c_stop();             //stop write cycle to shift to read cycle
   i2c_start ();           //send repeated start command to begin read cycle
   end_disp++;
   i2c_write (end_disp);       //add 1 to the address to send a write bit
   result2 = i2c_read(0);   //read analogue information from the slave
   i2c_stop ();            //terminate communication
   delay_ms(10);
   return result2;
void envia_i2c(BYTE end_disp, BYTE dado)
   i2c_start();               //begin transmission
   i2c_write(end_disp);           //select address of device to communicate with
   i2c_write(dado);           //send actual data
   i2c_stop();                //terminate communication
   delay_ms(10);             //debouncing delay
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   // TODO: USER CODE!!
   set_tris_b(0xFF);
   set_tris_c(0b10111111);
      if(!input(PIN_B0))
         for (n = 0; n <=7; n++)
            result = recebe_i2c(end_1, n);
            printf("BYTE %u: %u \n\r", n, result);
         printf("-------------------------------------\n\r");
         delay_ms(200);
      if(!input(PIN_B6))
            result = recebe_i2c(end_2, n);
         delay_ms(200);
      if(!input(PIN_B3))
         envia_i2c(end_1, 23);
         delay_ms(200);
      if(!input(PIN_C0))
         envia_i2c(end_2, 23);
         delay_ms(200);
Salenko
PostPosted: Tue Mar 31, 2009 2:03 am     Reply with quote
hi moacir_mendes,
thank you very much, your code is very useful. Smile
I have a question, why the code don't work when I add Fast to the both #use_i2c( ) (master and slave) ?
in fact, I need a fast i2c communication because I have a PIC Master and three slaves : a PIC (16F876), an External EEPROM (24C256) and an RTC (DS1307).
moacir_mendes
PostPosted: Wed Apr 08, 2009 7:35 pm     Reply with quote
Salenko wrote:
hi moacir_mendes,
Hi!
Good question Salenko. I don't know too. I read it doesn't works at this way.
i think at the normal i2c communication should be enough between them, doesn't?
ebenbekker
PostPosted: Wed Sep 02, 2009 3:43 pm     Reply with quote
How can you edit the code given by the original poster to send packets of 8 bytes to the client?
I try to hack it so that the master can write to a buffer on the slave all the instructions needed. So far all my attempts disabled all i2c comms.
Thank you very much.
Eben
PostPosted: Sat Sep 05, 2009 2:21 pm     Reply with quote
It's better to ask general questions in the main forum. Most people that
post in the Code Library do not want to make modifications to their code.
Also, the main forum is more widely read every day. You have a much
better chance of getting some help there.
cnrszr
PostPosted: Thu Mar 11, 2010 10:22 am     Reply with quote
this program works good within proteus simulation. Unfortunatly when i read 8 byte from first slave adress 0xA0 master gets data correctly. But when pressed other button and wanna get 8 byte from other slave adress 0xB0 then false values 255,255,... comes then. After that no more correct data reading and sending to the slave is possible. There is missing something, because of this i think switching between slaves is not possible.
gammi,grt
PostPosted: Thu Jul 26, 2012 2:40 am     Reply with quote
Hi, I am trying i2c between two pics. I am using 16f877a as a master device and 16f88 as a slave device. So for slave device we need to know the address of pic16f877. So please anybody can tell me address of pic16f88. Thanks.
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
