programing
kabiru
programing
PostPosted: Sat Jul 21, 2012 8:04 am     Reply with quote
Hello everyone, I am new to this forum and also new to microcontrollers programing. I will like members to please help me with some tutorial to start with...
Thanks.
PostPosted: Sun Jul 22, 2012 12:26 pm     Reply with quote
Here are some threads that have links to tutorials:
http://www.ccsinfo.com/forum/viewtopic.php?t=44291
http://www.ccsinfo.com/forum/viewtopic.php?t=41217
http://www.ccsinfo.com/forum/viewtopic.php?t=36598
You need to learn the C language by yourself, and not on this forum.
We don't want to teach you about C. We will help you with the
CCS compiler, and explain how it's different than standard C, but
we don't want to teach you the simple basics of the C language
such as the while() statement, or the for() loop, main(), variables, etc.
You must learn all them all by yourself.
kabiru
PostPosted: Sun Jul 22, 2012 3:40 pm     Reply with quote
Thank you for the reply pcm programer, i am learning the basics of c language and i am understanding it very well,also thank's for the links....
gpsmikey
PostPosted: Sun Jul 22, 2012 11:58 pm     Reply with quote
If you like video tutorials, Lynda.com has a series on C/C++ and while some of it is specific to windows etc, much of the course discusses C fundamentals. Check it out at
http://www.lynda.com/Eclipse-tutorials/CC-Essential-Training/94343-2.html
I have no association with Lynda.com other than through my credit card (I pay the annual fee). Much of the basics he covers will also apply to the CCS compiler we use here.
mikey
mikey
PostPosted: Mon Jul 23, 2012 3:49 am     Reply with quote
I think you first need to be very sure whether micro controllers at this level are the way you need/want to go.
The 'point' about the PIC's as a whole, is a huge family of very cheap chips, ideal primarily for small jobs, or where very large quantities are to be used.
However if (for instance), I wanted to control something simple, and have a simple interface to do this, without having to get involved with soldering irons, or making PCB's, a much better 'learning' starting point, would be something like the Arduino, where interface components are available to 'plug on', or the Raspberry Pi, where a complete board with basic OS, and language is available.
If you decide you do want to go the PIC route, start with a basic C tutorial, and a standard C on the PC first. Get happy that you can write and understand a number of simple programs _before_ getting involved in the extra complexity of working directly with a programmable processor. Then step _slowly_, by getting a pre-built 'development' board.
kabiru
PostPosted: Mon Jul 23, 2012 4:48 am     Reply with quote
This is a very nice forum where different people and different opinions joined together to share ideas, @ Ttelmah I am happy for your advice but I didn't thought about arduino earlier or raspberry pi. A friend advice me to start with pic and now i can understand and write small program like led blinking i think is a good starting point don't you think so?
kabiru
PostPosted: Tue Jul 24, 2012 8:08 am     Reply with quote
Hello every one i write a simple led blinking code but when trying to compile their wont be hex file here is the code..
#include<16f877.h>
#fuses HS,NOWDT,NOLVP,NOPROTECT
#use delay(clock=20M)
output_high(PIN_BO);
delay_ms (1000);
output_low(PIN_BO);
PostPosted: Tue Jul 24, 2012 8:17 am     Reply with quote
Study the forum - _code buttons_.....
#include<16f877.h>
void main(void) {
   while(TRUE) { //just nicer style....
      output_toggle(PIN_B0); //again nicer style - note the pin name
      delay_ms (1000);
Saved as (say) 'test.c', this _will_ compile and generate a hex file, provided you are calling the compiler correctly. What you post, _should work_, except you have called the pins 'BO', rather than 'B0', and the compiler should give an error that the former is not defined. If this is not the problem, how are you trying to compile this?. Through the IDE?. Command line?. MPLAB?.
Note how using the code buttons, and indenting, makes the code easier to read.
kabiru
Timer and prescalers
PostPosted: Tue Jul 24, 2012 8:32 am     Reply with quote
Very nice one Ttelmah it works Laughing you know i am a beginner that's quit encouraging thanks, and please can you help me with any tutorial to learn how to set timers, in pic?
Mike Walne
PostPosted: Tue Jul 24, 2012 10:39 am     Reply with quote
I don't want to sound rude or harsh, but you've already been told this is a help you forum not a do it for you one.
All the information you need is in the microchip data sheets for the PIC you're using and the CCS manual.
I suggest you:-
(1) Read the CCS forum guide.
(2) Have a go at getting the timers to do what you want.
(3) Come back to the forum when you are stuck.
When you need help show us that you have tried, someone will usually offer assistance.
Mike
EDIT You will also find loads of useful examples supplied with the CCS compiler, and on this forum.
kabiru
PostPosted: Tue Jul 24, 2012 11:08 am     Reply with quote
Thank you
PostPosted: Tue Jul 24, 2012 11:16 am     Reply with quote
You can learn a lot by reading the forum archives. Learn to use the
forum's search page. It's right here:
http://www.ccsinfo.com/forum/search.php
To search for tutorials on timers, type this into the top box:
timer* tutorial*
And set it to "Search for all Terms" (That's very important).
Click the Search button and you will find lots of articles to read. Most
questions have already been answered and you can find the answers with
the search page.
W4GNS
PostPosted: Tue Jul 24, 2012 11:56 am     Reply with quote
Kabiru
Welcome to the forum and:
Also download this Microchip doc, lots of useful information here.
http://ww1.microchip.com/downloads/en/DeviceDoc/33023a.pdf
PCWH 4.14
PostPosted: Tue Jul 24, 2012 12:43 pm     Reply with quote
Also have a real good look at the examples CCS supplies in the 'examples' folder. It will give you practical real world knowledge how to interface almost any device to a PIC.
Please not that you should look at them all, as they all have nice information in them !!
As well, when you have your project open, pressing F11 opens up the CCS help files, allowing fast access to most everything you might need to know, especially for beginner status.
hth
jay
