ajt
| TCPIP Examples Case Sensitive |
Posted: Mon Jul 16, 2012 7:28 pm |
TCPIP examples appear to be case sensitive. For example, ex13.c is clearly case sensitive. I cannot find a #case or #device ANSI line anywhere in the TCPIP folder.
How is the CCS default of non-case sensitive being changed and where? For that matter, are int's signed or unsigned in the TCPIP code?
Thanks _________________ Al Testani |
bkamen
Joined: 07 Jan 2004 Posts: 1617 Location: Central Illinois, USA
Posted: Mon Jul 16, 2012 10:41 pm |
It has to be turned on SOMEWHERE... otherwise, CCS is case insensitive.
look in the CCS help for PREPROCESSOR items.
In this case (no pun),
#CASE
Cheers,
ajt
Posted: Tue Jul 17, 2012 10:48 am |
| bkamen wrote: | It has to be turned on SOMEWHERE... otherwise, CCS is case insensitive.
#CASE
Cheers,
-Ben |
I had done all sorts of searching but guess what??? I had the search set to case sensitive (for some reason I don't know)! I finally found it in stacktsk.h and it is lower case (#case).
So in this case, searching for #CASE with the search set to case sensitive and it is lower case in the code as #case is a case of not following the case conventions for keywords. (sorry... couldn't resist <g>) _________________ Al Testani |
bkamen
Posted: Tue Jul 17, 2012 3:15 pm |
No worries.
Glad you found it.
