Gabriel
| TIMER1 - internal LP 32.768 OSC - SOLVED |
Posted: Fri Jul 13, 2012 6:49 pm |
PIC 16F886
What on earth is it supposed to be????!
I can't figure out the right value for T1CON.
I'm trying to implement an RTC using the internal T1 LP osc 32.768
void Main()
SETUP_OSCILLATOR(OSC_8MHZ); // Set Main PIC Osc. to 8MHZ
//SETUP_TIMER_1(T1_EXTERNAL_SYNC|T1_DIV_BY_2);
T1CON=0x08;
Printf("T1CON: %X \r", T1CON);
delay_ms(3000);
T1CON=T1CON|0x0D;
ENABLE_INTERRUPTS(GLOBAL); // Enable Interrupts
DISABLE_INTERRUPTS(INT_RDA);
ENABLE_INTERRUPTS(INT_TIMER1); // disable Serial Interrupts (SPI CONFLICT)
//ENABLE_INTERRUPTS(INT_EXT_H2L); // Enable INT pin Interrupt high to low trigger
//SET_TIMER1(0);
while (1)
output_toggle(PIN_B1);
Aas you can see I'm trying to do it manually... since the .h file does not give me much detail.
and the datasheet is ... not helping me much.
I've gotten it to trigger the isr:
| Code: | #INT_TIMER1
void Timer1Int()
output_toggle(PIN_B2);
but I get a period of 65 ms....
Whereas by my calculations... is wrong.
Its a 32.768 k osc... timer1 is 16bit so...
my interrupt should trigger every 2 seconds.
Its not happening.
Sorry... I'm very frustrated.
G.
edit... forgot fuses:
| Code: | | #fuses HS,NOWDT,NOPROTECT, NOLVP,INTRC_IO |
_________________ CCS PCM 5.078 & CCS PCH 5.093
Posted: Sat Jul 14, 2012 3:53 am |
Start by looking at the data sheet.
Figure 4-1. Clock source block diagram.
Where does it say the LFINTOSC routes to?. Does it mention timer1?.
Then look at the timer1 block diagram. Figure 6-1.
What clock sources does it show for the timer?.
Timer1, can be clocked from the internal Fosc/4, _or_ an external low power oscillator, or the T1CKI input. Not the internal low power oscillator (unless you switch the CPU down to running off this).
I think you are getting confused with the T1 LP oscillator. This is for an _external_ 32K crystal, connected between the T1OSO, and T1OSI pins, nothing to do with the LFINTOSC.
You enable this, with:
SETUP_TIMER_1(T1_EXTERNAL|T1_DIV_BY_2|T1_CLK_OUT);
This turns on the oscillator clock _output_, so that a crystal attached will oscillate.
Gabriel
Posted: Sat Jul 14, 2012 6:44 am |
thanks for your answer, I misunderstood the datasheet.
I was under the impresion that:
| Quote: | 6.4 Timer1 Oscillator
A low-power 32.768 kHz oscillator is built-in between
pins T1OSI (input) and T1OSO (amplifier output). The
oscillator is enabled by setting the T1OSCEN control
bit of the T1CON register. The oscillator will continue to
run during Sleep. |
and this
| Quote: | The Timer1 oscillator is identical to the LP oscillator.
The user must provide a software time delay to ensure
proper oscillator start-up. |
meant that the Oscillator was a complete module including a clock source...
that was _like_ the _main_internal_ Osc, which doesnt require a crystal.
thus i concluded that the internal Osc on T1 did not require a crystal as well.
I was not confusing LFINTOSC with the T1 oscillator i wanted...
now my next question is why if set T1CON to 0x0D on my code,
Why was it being driven by the internal clock?
from my code:
| Code: | T1CON=0x08; // set T1OSCEN
delay_ms(3000); // "Suitable Delay"
T1CON=T1CON|0x0D; // T1 ON, TMR1CS set, T1SYNC clear |
anyways... thanks for your answer... i thought i didnt need a crystal.
G _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Posted: Sat Jul 14, 2012 2:22 pm |
On 'why was it being driven by the internal clock', reason is that you set TMR1CS to 0. This says to run Timer1, from the internal master oscillator/4.
0xD, is 0b1101
Enable LP oscillator. Do not synchronise. Internal clock. Timer1 on.
Much easier to use binary when doing this, reduces the risk of setting the wrong bit.
Gabriel
Posted: Sat Jul 14, 2012 3:13 pm |
Yeah... I settled on 0x0F in the end, which is what the compiler gave me anyways:
SETUP_TIMER_1(T1_EXTERNAL|T1_DIV_BY_1|T1_CLK_OUT);
Its working now and I got it down to 1Hz by doing that old MSB bit trick:
| Code: | #INT_TIMER1
void Timer1Int()
TMR1H |= 0x80;
I do everything in binary ... its the probably the only thing I use the windows calculator for!
By the time I posted the code last night... I was brute forcing my way through T1CON values...I was desperate.
Thanks for your help!
