Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
code for MCP3202 with 18f4550 !!!!
Post new topic   Reply to topic    CCS Forum Index -> Code Library
slyfox
PostPosted: Sun Feb 07, 2010 12:17 pm     Reply with quote
now it's ok !!!
just few lines to use the MCP3202 , 12 bits analog to digital converter , with pic microcontroller :
USE spi hardware if you can !
#use spi(FORCE_HW, BITS=16,SAMPLE_RISE, BAUD=1000000)
#define CS1  PIN_C6
#define DIN  PIN_C7
#define DOUT PIN_B0
#define CLK  PIN_B1
in your main program or function :
int8 msb, lsb;
int16 value;
// for first channel reading
output_low(cs1);
spi_write(0x01); // start bit
msb=spi_read(0xC0); // first channel in single mode and read first byte
lsb=spi_read(0x00); // read second byte
output_high(CS1);
value=make16(msb,lsb); //convert to 16 bits
value=value & 0x0fff;  // forced fourth first msb bits to zero
print value to read result !!!!
// for second channel reading
output_low(cs1);
msb=spi_read(0x80); // second channel in single mode and read first byte
output_high(CS1);
hope it is useful !!
glk.c.93
re:
PostPosted: Mon Jul 09, 2012 2:57 am     Reply with quote
If you are transferring 16 bits at a time, then while
reading data to a 8 bit number, which 8 bits do we get ?
Do we get 16/8 bit value while we read ?
Did you check the program practically ?
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
