RTC does not run when debugging?
Goto page 1, 2  Next
Eduardo__
PostPosted: Mon Jun 25, 2012 11:41 am     Reply with quote
I'm using MPLAB with CCS C and ICD2 programmer/debugger.
My uC is the PIC18F26J11.
Despite of 32kHz clock is running (I checked with an oscilloscope), it seems that RTC does not run (does not count seconds, days...) when I stop the program.
Anyone knows whether is it possible to get RTC running even when debugging (even when it is stopped at a breakpoint)?
Thanks a lot for any idea =D
Eduardo Guilherme Brandt
PostPosted: Mon Jun 25, 2012 11:48 am     Reply with quote
Use Google to search the Microchip forum. Use their forum as a KnowledgeBase. Search for this:
site:microchip.com/forums RTC OR RTCC debug OR debugger OR debugging
Then you find threads like this:
http://www.microchip.com/forums/m442150-print.aspx
There might be other useful threads.
Eduardo__
PostPosted: Mon Jun 25, 2012 8:16 pm     Reply with quote
Thank you very much.
Just one thing more:
With U40 Programmer/Debugger, RTC runs and counts date/time when uC stopped in a breakpoint?
thanks.
asmboy
PostPosted: Tue Jun 26, 2012 9:36 am     Reply with quote
as i believe Richard Feynman once famously said:
"you can't do just ONE thing at a time"
the debugger has the potential to interfere with any aspect of your program, but ESPECIALLY in the time domain.
i have never used debug break points and probably never will.
there are other ( and IMHO BETTER) methods to figure out programming problems than carrying the overhead and operating interference that insertion of debug code creates. If you don't understand where your program is going wrong , adding more uncertainty to it's execution does not seem like a benefit, at least to me.
leds that flash , pins that can be read toggling at a given rate on on
an oscope, and serial conditional printf() scaffolding ALL come quickly to mind.
Smile
Eduardo__
PostPosted: Tue Jun 26, 2012 10:23 am     Reply with quote
Thank you Mr. Asmboy.
I think that you´re right. In this case, debugger seems to stop something in uC that could work even in a Sleep.
But I´ve already programmed without debugger. After I begun using debugger, I would like never have to come back again.
very thanks again. I appreciate CCS forum help Smile
bkamen
PostPosted: Tue Jun 26, 2012 10:56 pm     Reply with quote
There is a setting in MPLAB under the ICD menus to "freeze" or "halt" peripherals while the debugger is running that you can turn off.
So things like timers and clocks keep spinning -- although their code may not.
Check it out..
Eduardo__
PostPosted: Wed Jun 27, 2012 7:07 am     Reply with quote
Very thanks Mr. bkamen. You solved the question.
Under MPLAB menu, I click in "Debugger", then click "Settings", tab "Freeze".
I´ve not tested it yet, but Thank you a lot!
bkamen
PostPosted: Wed Jun 27, 2012 11:34 pm     Reply with quote
That's why were here...
:D Don't forget to change the subject of your original post to include "[SOLVED]" so others can find it.
-Ben
Eduardo__
PostPosted: Thu Jun 28, 2012 6:42 am     Reply with quote
Mr bkamen.
Just one more question: Do you´ve MPLAB?
I do not know why my MPLAB ICD2 does not leave me to change Peripheral Freezing (it not allows uncheck it). Do you know why?
bkamen
PostPosted: Thu Jun 28, 2012 8:26 pm     Reply with quote
Eduardo__ wrote:
Mr bkamen.
yes, I use MPLAB exclusively.
As for your question, I would have to go check. It may not work with some devices or some other MPLAB feature...
I can't get to it right now -- another project is clogging up my bench.
-Ben
Eduardo__
PostPosted: Fri Jun 29, 2012 7:30 am     Reply with quote
thanks Mr Bkamen for helping.
You can answer when you could, no problem.
I actually use PIC18F24J11.
hemasc_
PostPosted: Wed Aug 01, 2012 8:28 am     Reply with quote
Edward (rs), I want to use 18F87k90 RTC.
I would like to configure hour and date.
Can you send me some example?
Eduardo__
PostPosted: Wed Aug 01, 2012 9:01 am     Reply with quote
Dear hemasc_, you need to write in same forum language(english). Sorry, but these´re rules.
Yes, it´s very very simple with CCS.
There is a default time/date structure(see. 18F87k90 header file(18F87k90.h)).
typedef struct {
   int8 tm_year;
   int8 tm_yday;  // Not used by built in functions
   int8 tm_mday;
   int8 tm_mon;
   int8 tm_hour;
   int8 tm_wday;
   int8 tm_sec;
   int8 tm_min;
   int8 tm_isdst; // Not used by built in functions
} rtc_time_t;
But there are commands for reading from and writing into PIC´s rtc peripherals, like
rtc_write(), rtc_alarm_read(), rtc_alarm_write()
Do not forget to put a 32kHz external Crystal and enable PIC´s rtc.
You can enable RTC interrupt if you want to. It can be useful for alarm events:
#fuses HS,RTCOSC_T1,HSPLL
void init() {
   setup_rtc(RTC_ENABLE,0);                  //enables internal RTCC
   //enable_interrupts(INT_RTC);             //enable RTC interrupts
   enable_interrupts(GLOBAL);                //enable interrupts
//inside main programm
rtc_time_t  Clock;      //date/time structured variable
init();
Clock.tm_Hour=10;
Clock.tm_min=30;
Clock.tm_sec=0;
rtc_write(&Clock),
while(true) {
  rtc_read(&Clock);
  fprintf(" %02u:%02u:%02u      \r\n",
         Clock.tm_hour, Clock.tm_min, Clock.tm_sec );
  //Connect to windows hyperterminal´s
  //Donp´t forget to enable and set PIC RS232 serial configuration before
There is an Example file that comes with CCS documentation.
Good luck
hemasc_
PostPosted: Wed Aug 01, 2012 9:52 am     Reply with quote
I used the CCS example and I can write and read, but after some seconds, I read again and value of second doesn't modify.
I used RTCOSC_T1 fuse
I have a crystal of 32kHz in hardware.
I think the clock is not enabled.
Eduardo__
PostPosted: Wed Aug 01, 2012 10:20 am     Reply with quote
Check whether clock is running(with an oscilloscope).
Check whether RTC fuse is in(check before writing it to uC, in programmer view fuses).
Goto page 1, 2  Next
Page 1 of 2
