Is this a FAQ? Shift operator problem.
Manzo Saita
PostPosted: Wed Jun 27, 2012 1:37 am     Reply with quote
Sorry. I don't write english well. Please to decipher.
This work well.
my_int32 = ( 1 << 20 );
your_int32 |= my_int32;
But, this does not work.
your_int32 |= ( 1 << 20 );
Why ?
Please tell me.
--- Manzo Saita ---
PostPosted: Wed Jun 27, 2012 2:32 am     Reply with quote
Looks like an integer type cast problem. By default the compiler will choose the smallest integer type fitting your constant, i.e. the value of 1 will fit into an int8.
Shifting an int8 by 20 positions results into 0.
Casting to an int32 before the shift is performed should solve the problem.
I don't have a compiler here to test with, but try the following:
your_int32 |= ((int32) 1) << 20;
Note that I first have the cast to an int32 and then do the shift.
PostPosted: Wed Jun 27, 2012 3:30 am     Reply with quote
In all honesty though, is is perhaps worth saying, to consider using the bit_set operator instead. You are just turning on bit 20 of your value, so:
bit_set(your_int32,20);
will do the same, and generate a _lot_ faster code. Single bit set operation....
Manzo Saita
PostPosted: Wed Jun 27, 2012 6:09 pm     Reply with quote
Thanks! ckielstra, Ttelmah.
I did not want to use the bit_set().
I did not know the features of the automatic type conversion of ccs-c.
Thank you very mach.
--- Manzo Saita ---
