muatuyet_2012
| Problem read analog LTC1298, Please Help |
Posted: Thu Jun 14, 2012 11:22 pm |
Help me, Please.
I use LTC1298 + PIC16F877A.
I read the voltage and display 4 Led 7 seg. I use library "ltc1298.c". Read analog from CH0 and display Led.
My problem: But, for any input voltage, LTC1298 always read 5000 (5v).
"ltc1298" :
temp=data/div;
div=0x3330;
When display 5000 => data = 65520 = FFF0 (that time MSB=11111111 and LSB= 11110000)
I create function convert_to_volt for myself to suit for display Led and it's working fine. There is only one problem left. This is read analog from LTC.
I don't understand, Why is that?
main():
long int data;
adc_init();
do
data=read_analog(0); // ??????
Display_LTC(data); //Display Led 7 seg =>ok (tested)
}while(TRUE);
In "ltc1298.c", I have changed:
#ifndef ADC_CS
#define ADC_CLK PIN_C4
#define ADC_DOUT PIN_C5
#define ADC_DIN PIN_C6
#define ADC_CS PIN_C7
#endif
That is my problem. Please help me. |
Posted: Fri Jun 15, 2012 4:19 pm |
| Quote: | #ifndef ADC_CS
#endif |
Pins C6 and C7 are used by the hardware UART, for your RS-232
communication with your PC. (To display the results on a terminal
window, such as TeraTerm). Don't use the UART pins for the LTC1298.
Choose some other pins.
Also, post your complete test program. Don't post ltc1298.c, because
we already have it. Just post your test program which calls the functions
in the ltc1298.c file. Don't post code fragments. Post the complete
program with #include, #fuses, #use delay, main(), variables, etc. |
muatuyet_2012
Posted: Sun Jun 17, 2012 9:40 pm |
Thanks for your suggestion.
This is my program:
#include <16F877A.h>
#include <def_16f877a.h>
#fuses NOWDT,HS,NOPUT,NOPROTECT,NODEBUG,NOBROWNOUT,NOLVP,NOCPD,NOWRT
#include <ltc1298.c>
#use fast_io(c) //trans + ltc
#use fast_io(d) //led
#bit U=PortC.3
#bit D=PortC.2
#bit H=PortC.1
#bit T=PortC.0
const unsigned char seg[10]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
void convert_to_volts( long int data, char volts[4])
BYTE k;
long int temp,div;
div=0x3330;
for(k=0;k<=3;k++)
temp=data/div;
volts[k]=(BYTE)temp;
temp=div*(BYTE)temp;
data=data-temp;
div=div/10;
void Display_LTC(long int data)
int8 Th,Hr,Do,Un,i;
char volts[4];
convert_to_volts(data,volts);
Un=volts[3];
Do=volts[2];
Hr=volts[1];
Th=volts[0];
for(i=0;i<100;i++)
U=0;D=1;H=1;T=1;
portd=seg[Un];
delay_us(100);
U=1;D=0;H=1;T=1;
portd=seg[Do];
delay_us(100);
U=1;D=1;H=0;T=1;
portd=seg[Hr];
delay_us(100);
U=1;D=1;H=1;T=0;
portd=seg[Th];
delay_us(100);
long int DL;
set_tris_c(0x00);
set_tris_d(0x00);
do
DL=read_analog(0);
Display_LTC(DL);
}while(TRUE);
Please, contribute your ideas. Thanks all. |
Posted: Sun Jun 17, 2012 10:23 pm |
Your code doesn't compile. It has large numbers of compiler errors.
| Quote: |
int8 Th,Hr,Do,Un,i;
You are using a keyword as a variable name. That's not allowed in C.
"Do" is a keyword for the do-while statement. You can't use it !
| Quote: |
long int DL;
set_tris_c(0x00);
set_tris_d(0x00);
Here you are using fast i/o. Then you set PortC to "all outputs". But
that's wrong. The PIC must be able to read from the LTC1298. It's
an A/D converter and the PIC must read the result. Don't use fast i/o.
It's not necessary, and it only causes errors for people that are new to
CCS and to PICs. Delete both of the #use fast_io lines. |
muatuyet_2012
Posted: Sun Jun 17, 2012 11:02 pm |
I did it!
You're really enthusiastic.
Thanks you so much! |
