Using pin of USB as logic pin
Louati
PostPosted: Thu Jun 14, 2012 9:56 am     Reply with quote
Hello Smile
I want to know if I can use the two pins D- and D+ of a pic 18f4550 as logic pins ?
I try but they didn't work :/
If someone can helpe me I will be so thankful.
#include <18f4550.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,PUT
#USE DELAY(CLOCK=20MHZ, CRYSTAL)
#byte portc = 0xF82
#byte trisc = 0xF94
void main(void){
   portc=0b00000000;
   trisc=0b11111111;
   while(1){
         output_high(pin_c4);
         output_low(pin_c4);
         output_high(pin_c5);
         output_low(pin_c5);
PostPosted: Thu Jun 14, 2012 11:29 am     Reply with quote
Look at this thread. Less than a day ago....
<http://www.ccsinfo.com/forum/viewtopic.php?t=48443>
Louati
PostPosted: Thu Jun 14, 2012 1:10 pm     Reply with quote
thanxs Smile
