eeprom 18f252
will
eeprom 18f252
PostPosted: Fri Jun 08, 2012 10:55 am     Reply with quote
hello, I'm going a robot who saves his career.
I was in a foul or write eeprom read here?
I am willing to put the full code but it is long.
thank you in advance
void fonction_memory() {
   for(i=0;i<=255;++i)
     variable=donnee[i];
    write_eeprom(i, variable2);
    donnee[i]=donnee[i]>>8;
     variable=donnee[i];
    i=i+1;
     write_eeprom(i, variable);
void fonction_repeat() {
   for(i=0;i<=255;++i)
     variable=read_eeprom(i);
     donnee[i]=variable;
     i=i+1;
    variable2=read_eeprom(i);
    variable2=variable2<<8;
     donnee[i]=donnee[i]||variable2;
PostPosted: Fri Jun 08, 2012 6:36 pm     Reply with quote
I don't know exactly what you are trying to do. But I think you want to
write 16-bit values to internal eeprom.
Look at this driver file, included with the CCS compiler:
c:\program files\picc\drivers\internal_eeprom.c
It has functions to read and write a 16-bit unsigned integer to eeprom:
write_int16_eeprom()
read_int16_eeprom()
PostPosted: Sat Jun 09, 2012 1:04 am     Reply with quote
One little comment on the loops. If 'i' is an in8 (default 'int' size), then the loops will never terminate.
When an int8 counts, it wraps at the end. So:
254
255
0
1
2
etc..
This will always be <=255......
will
PostPosted: Sat Jun 09, 2012 2:47 am     Reply with quote
yes I try to put 16 bits in the eeprom. I put the complete code. This is a remote controlled robot using infrared (RC5).
will
PostPosted: Thu Jun 14, 2012 1:53 pm     Reply with quote
hello I can not exit the loop, how to proceed, thank you
PostPosted: Thu Jun 14, 2012 1:59 pm     Reply with quote
Ttelmah told you:
So, what is the next larger data type than 'int8' ? What is the next size ?
Look in the CCS manual and answer that question. Then change your
declaration of 'i' to the next larger size.
Look in this section:
Basic and Special types
Gabriel
PostPosted: Thu Jun 14, 2012 2:27 pm     Reply with quote
this was funny....
CCS PCM 5.078 & CCS PCH 5.093
will
PostPosted: Fri Jun 15, 2012 7:51 am     Reply with quote
[quote="PCM programmer"][quote]
Ttelmah told you:
yes I know, I did see his message but 'i' is long! So I do not see or come to the problem.
watching:
int mot_commande[] = {0, 0, 0, 0};
long donnee[128], i=0;
char variable;
long variable2;
int mot_effectue = 10;
int vitesse = 5;
long time=0;
thank
Gabriel
PostPosted: Fri Jun 15, 2012 8:19 am     Reply with quote
Edit**nevermind...
try printing out the value of "i" to serial... see what its doing.
will
PostPosted: Wed Jun 20, 2012 7:04 am     Reply with quote
hello
Sorry I can not display it.
Yet I have always not solved my problem.
I have two dc motors that I control via infrared (RC5) I have two push buttons, one to store, the other to play again. I stored the data length and direction in the eeprom but I can not do it. if someone can help me as impossible.
int mot_commande[] = {0, 0, 0, 0};                  // {MOT_D_AV, MOT_D_AR, MOT_G_AV, MOT_G_AR} [0, 10]
char variable;
long variable2;
int mot_effectue = 10;                           // [0, 10]
int vitesse = 5;
long time=0;
   for(i=0;i<=255;++i)
     variable=donnee[i];
     variable=donnee[i];
    i=i+1;
   for(i=0;i<=255;++i)
     donnee[i]=variable;
     i=i+1;
void fonction_decode() {
   for(i=0;i<=255;++i)
    variable=donnee[i];
     variable=variable&&7;
       switch(variable) {
            case 1:
              mot_avancer();
            case 2:
               mot_reculer();
            case 3:
               mot_arreter();
            case 4:
               mot_rotation_gauche();
            case 5:
               mot_rotation_droite();
            case 6:
               mot_virage_gauche();
            case 7:
               mot_virage_droite();
            default:
         variable2=donnee[i];
         variable2=variable2>>3;
         time=0;
         while(time!=variable2);
//////PROGRAMMME
  while (input(REC_IR) == 1) // Attend bit de START
      if(input(PIN_C7))
            fonction_memory();
         output_high(LED_VERTE);
       if(input(PIN_C5))
            fonction_repeat();
            fonction_decode();
switch(commande) {
            case CODEIR_AV:
              mot_avancer();
           donnee[i]=donnee[i]+1;           //// ICI
            case CODEIR_AR:
               mot_reculer();
           donnee[i]=donnee[i]+2;            ////ICI
            case CODEIR_ST:
               mot_arreter();
            time=time<<3;
            donnee[i]=donnee[i]||time;                               ///// TIME
            time=0;
            i++;
            case CODEIR_RG:
            donnee[i]=donnee[i]+4;                /// ICI
            case CODEIR_RD:
            donnee[i]=donnee[i]+5;      ///ICI
            case CODEIR_VG:
           donnee[i]=donnee[i]+6;            //// ICI
            case CODEIR_VD:
           donnee[i]=donnee[i]+7;                           //////////ICI
            default:
PostPosted: Wed Jun 20, 2012 8:08 am     Reply with quote
Just going through the write routine - comments inline.
void fonction_memory(void) {
    for(i=0;i<=255;++i) {
      variable=donnee[i];
      //i is moving forwards by _2_ every loop - you increment both in the for
      //and at the end of the loop. You will access donnee[0], then donnee[2].
      //Er. You have put the LSB of the value into variable, then write
      //variable2.....
      //Do you mind that this will destroy the stored value?.
      variable=donnee[i];
      i=i+1;
//Alternative:
    long val;
    int index;
    for(i=0;i<128;i++) {
      index=i*2;
      val=donnee[i]; //Will access values from locations 0 to 127.
      write_eeprom(index, make8(val,0)); //LSB
      write_eeprom(index+1,make8(val,1)); //MSB Write the two bytes
You probably have similar problems elsewhere - haven't looked.
will
PostPosted: Wed Jun 20, 2012 8:37 am     Reply with quote
pffffffffff a big thank
and then you can not help me fix because I'm lost ..
a big thank you and sorry ..
PostPosted: Wed Jun 20, 2012 8:48 am     Reply with quote
I have posted a fixed version for this function. Look for similar mistakes elsewhere.
will
PostPosted: Wed Jun 20, 2012 10:02 am     Reply with quote
thank ,
why do you * 2? => index = i * 2
PostPosted: Wed Jun 20, 2012 11:39 am     Reply with quote
Because 'i', addresses an array of int16's, and it takes two bytes of the EEPROM to store an int16. Hence two writes for each value in 'i', and the byte address used has to be 2*i.
This is the core problem from the start of the thread. Even if you used the CCS code to write an int16, the _address_ must move forward by 2 for each value written.
