RTOS Tasks
waheed
RTOS Tasks
PostPosted: Sat Jun 02, 2012 7:33 am     Reply with quote
Is there any limitation to how much tasks can be used in a program? I am writing a program that uses 7 tasks but only 3 tasks are running at a time.
When I include 8th task it gives strange behaviour. (Keep switching between the task), even if the 8th task does nothing except incrementing a variable.
PostPosted: Mon Jun 04, 2012 2:56 am     Reply with quote
I don't know what the maximum number of allowed tasks is, but 7 sounds like a possible maximum. For an exact answer you'll have to mail CCS Support.
Just a few hints though:
1) The CCS RTOS feature is not used widely, i.e. you are in new territory and it is very well possible you will discover new bugs.
2) From doing I've learned that it is bad practice to create an application with many threads. Debugging becomes much more complicated as most debuggers and processors have poor support for multi-threading. Not to mention the problem of race conditions and dead locks which can be a real nightmare to track down.
Are you really sure you need threads? Or is it just a nice way for partitioning your program?
The fact that only 3 out of 7 tasks will be active at any given time suggests the latter. Partitioning a program into seperate parts is a Design Time problem and can be solved by creating multiple C-files / functions.
Mike Walne
PostPosted: Mon Jun 04, 2012 2:40 pm     Reply with quote
If you must use RTOS, why not merge task8 with other tasks?
Mike
