interruption
will
interruption
PostPosted: Mon May 28, 2012 8:15 am     Reply with quote
Hello
I try to make a break with two micro switches.
The program compiles fine but no detection. The LED does not light either.
why??
My program:
I put all my interruptions, see bold character
}[/b]
Thank you very much.
PostPosted: Mon May 28, 2012 8:22 am     Reply with quote
Three things:
if (droit)==0) {
Needs to be
if (input(droit)==0) {
Second, you are not enabling INT_RB.
Third, you are 'pushing' the interrupt speed for your timer. Technically you could be interrupting about every 285 instructions. Depending on what is in 'mot_generation_pwm', you may not have any time to actually do much else.....
will
PostPosted: Mon May 28, 2012 8:30 am     Reply with quote
thanks
why?
I do not understand, what should I do?
jeremiah
PostPosted: Mon May 28, 2012 7:23 pm     Reply with quote
you have an interrupt service routine setup for RB but never turn it on with enable_interrupts() like you do the other interrupt.
will
PostPosted: Tue May 29, 2012 4:56 am     Reply with quote
thank you
like this? but it does not work.
PostPosted: Tue May 29, 2012 5:32 am     Reply with quote
You've really only shown us part of your code.
You do have a main ?
Mike Walne
PostPosted: Tue May 29, 2012 5:36 am     Reply with quote
Read the CCS forum guide.
Learn to use the code buttons.
Post a SHORT but complete compilable version of you code that we can test.
Give us some idea of your schematic.
Mike
