USB SOF doubt
xxopiumxx
USB SOF doubt
PostPosted: Mon May 28, 2012 11:19 am     Reply with quote
greetings,
I have reading upside down the entire usb.c pic18_usb.c etc etc etc libraries, but I cannot find any code relating to the SOF token. As I know, it must be sent every 1ms (in full speed) in order to prevent a suspended mode entering.
Of course it is being sent, otherwise my program wouldn't work at all, but as curious as I am, I wanted to know if you can give me a tip about this.
Thanks for advance.
PostPosted: Mon May 28, 2012 1:19 pm     Reply with quote
If you really,really NEED to know about it, I suggest Jan's bible on USB. Somewhere in the 500-600 pages of dull,dreary reading you'll come across it....
As for the CCS drivers,again, just read the code, line by line, it's there if it needs to be...
Frankly I've got better things to do than dive into the workings of the Useless Serial Bus.
PostPosted: Mon May 28, 2012 2:35 pm     Reply with quote
You find the basic information even in the USB chapter of the PIC18 datasheet. SOF is send from host to device. The device don't answer the SOF, only succeeding explicite commands, if any.
xxopiumxx
PostPosted: Tue May 29, 2012 6:12 am     Reply with quote
thanks, pals
