Memset function reset gpio PIC12F675
Diego López
PostPosted: Fri May 25, 2012 10:33 am     Reply with quote
I do not speak English, I apologize
memset function has gpio port to zeros
set_tris_a(0b111110);
bit_set(gpio,0);
memset(dato_recibido, 0, sizeof(dato_recibido));
thank you very much
complete code
#include <12f675.h>
#use delay(clock=4000000, restart_wdt)
#fuses xt,wdt,brownout,put,protect,nomclr
#byte   gpio = 0x05
#define led_tecla gpio,0
int dato_recibido[5];
void main()      //Rutina principal
bit_set(gpio,0);
while(true)
      delay_ms(10);
PostPosted: Fri May 25, 2012 1:13 pm     Reply with quote
What is the problem ?
Do you think that memset() is setting the GPIO port = 0 ?
What is your CCS compiler version ?
Diego López
PostPosted: Fri May 25, 2012 7:54 pm     Reply with quote
When you run the function memset() on the PIC12F675 happens that the GPIO is set to zero.
CCS 4.130
thank you very much
PostPosted: Fri May 25, 2012 11:46 pm     Reply with quote
I think it's a bug in memset() for the 12F-series PICs. Look at the last
post in the thread in the following link. He has the same bug.
He's using vs. 4.108.
http://www.ccsinfo.com/forum/viewtopic.php?t=43266&highlight=memset
This bug appears to start in vs. 4.033 and continue to the current
version 4.032.
You can see it in the .LST file below. The code is clearing PortA (GPIO).
.................... bit_set(gpio,0);
0030:  BCF    03.5   // Bank 0
0031:  BSF    05.0
.................... memset(dato_recibido, 0, sizeof(dato_recibido));
0032:  CLRF   05    // Set GPIO port = 0   *** Bug
0033:  MOVLW  24
0034:  MOVWF  04
0035:  CLRF   20
0036:  MOVLW  05
0037:  MOVWF  21
0038:  GOTO   004
Here's the code for vs. 4.031. Notice that they don't call a routine at
address 0004. Instead they just clear memory in a loop. They don't
write to PortA (at address 05) and there is no bug:
0029:  BCF    03.5
002A:  BSF    05.0
002B:  MOVLW  05
002C:  MOVWF  21
002D:  INCF   22,F
002E:  MOVLW  25
002F:  MOVWF  04
0030:  BCF    03.7
0031:  CLRF   00
0032:  INCF   04,F
0033:  DECFSZ 21,F
0034:  GOTO   031
The memset bug appears to be confined to the 12F series. I looked at
code for 16F877 and 16F628 and I didn't see it clearing Port A.
I'll report it to CCS.
As a work-around, I suggest that you clear the array manually with
code. You can do it the same way as shown in the last post in the link,
or you could write a for() loop to do it.
Diego López
PostPosted: Sat May 26, 2012 10:43 am     Reply with quote
Thank you very much.
