sterob
strange ADC problem |
Posted: Thu May 24, 2012 7:48 am |
Hi, everyone, I am working on a project that requires sampling some 6 adc signals and output through 6 pins, if the input is greater than a reference (set in the code). The problem arises whenever i sample more than two signals, Pin_C2 (related to the third channel, in the code) flickers (i.e goes on and off repeatedly), whereas if a sample just 1, or two, the outputs won't flicker. Please, I need help. Am using compiler version 4.114. Here's the code:
#include <18F2550.h>
#DEVICE ADC=8
#FUSES PLL1 //No PLL PreScaler
#FUSES CPUDIV1 //No System Clock Postscaler
#FUSES NOUSBDIV //USB clock source comes from primary oscillator
#FUSES XT //Crystal osc <= 4mhz for PCM/PCH , 3mhz to 10 mhz for PCD
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES PUT //Power Up Timer
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES VREGEN //USB voltage regulator enabled
#FUSES PBADEN //PORTB pins are configured as analog input inels on RESET
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,bits=8)
int i;i;
float intake[6], scaled_intake[6], scale;
scale = 2.00;
setup_adc(ADC_CLOCK_INTERNAL); // ADC clock
setup_adc_ports(AN0_TO_AN8); // Input combination
for(i =0; i < 9; i++ ) // Read 8 inputs
// Since pic18f2550 does not have AN5,AN6, and AN7, this lines skips through!
if(i==5)
i+=1;
if(i==6)
i+=1;
if(i==7)
i+=1;
delay_ms(1000); // Wait 1 sec
set_adc_channel(i); // Select inel
intake[i]= read_adc(); // Get input
scaled_intake[i]=(intake[i])/51; // Scale input
printf( " INPUT%u = %4.3f \r",i ,scaled_intake[i]); //,scaled_intake[1],scaled_intake[4],scaled_intake[11]); // Display intake
if(input(PIN_D0))
if(scaled_intake[0]<scale)
output_high(PIN_C0);
else if(scaled_intake[0]>scale)
output_low(PIN_C0);
if(scaled_intake[1]<scale)
output_high(PIN_C1);
else if(scaled_intake[1]>scale)
output_low(PIN_C1);
if(scaled_intake[2]<scale)
output_high(PIN_C2);
else if(scaled_intake[2]>scale)
output_high(PIN_C3);
// Similarly repeated for the remaining 3 channels
else if(!input(PIN_D0))
delay_ms(10); // switch debounce
output_high(PIN_D2);
Posted: Thu May 24, 2012 8:14 am |
Tacq.....
The ADC takes _time_ to acquire a signal after a channel is selected. Depends on the impedance of the source, but typically 10 to 20uSec. You _must_ wait for this time after selecting a channel, before reading. Otherwise the voltage from the _last_ selected channel will still largely be on the internal capacitor, and the channels will interfere with one another.....
sterob
Posted: Thu May 24, 2012 8:27 am |
Ttelmah wrote: | Tacq.....
I put a delay of 1sec inside the for loop to check for sampling time. |
RF_Developer
Re: strange ADC problem |
Posted: Thu May 24, 2012 9:40 am |
There's lots wrong, or confused and confusing with this code. Here's a few ideas:
sterob wrote: |
#DEVICE ADC=8
// 18F2550 has a ten bit ADC. Why throw away 4 good bits of useful data? Better to set it to 10 bit mode and adjust your scaling.
// I'm assuming your fuses are OK. Could be wrong....
// Best to include errors to ensure UART doesn't lock up on error.
int i;i;
// Why is i; repeated? Most compilers would raise an error for that.
// Delete the repeat.
// Are all these really needed to be floats? No, intake should really be an int16 for 10 or 8 bit ADC mode, or int8 for 8 bit mode. Also intake doesn't need to be an array, as its a temporary variable.
scale = 2.00;
// Ah, so scale doesn't change, therefore it is a constant. Use
// const float scale = 2.0f; or #define SCALE 2.0f
// Nearly always a bad idea to use the internal RC clock for the
// ADC. Better to use a clock divided from the main oscillator.
// No, that loops NINE times, 0, 1, 2... 7, 8. Should be
// for(i =0; i < 8; i++ ) // Read 8 inputs
if(i==5)
i+=1;
if(i==6)
i+=1;
if(i==7)
i+=1;
// What? You really wanted to loop only six times, so loop six times and only do something special on the last loop as its not on the expected ADC channel. Lets try that again:
for(i =0; i < 6; i++ ) // Read 6 inputs
// No, this delay, which is far too long anyway, must be after the set_adc_channel() and before the read_adc(). You can configure the ADC hardware to do it for you using ADC_TAD_MUL_x.
if (i == 5)
set_adc_channel(8); // Select inel
// Why put the brackets aroiund intake[i]? They are not needed.
// Why have intake as a float? The ADC result is an integer, storing
// it as a float just wastes processor time and memory. In this case
// storing it at all is a waste. Simply read the ADC and convert in
// one go like this:
scaled_intake[i] = read_adc() / 51.0f;
// Note the ".0f" making sure the constant is a float. Division takes
// longer than multipication, so I prefer to make all my scaling
// constants multipliers:
scaled_intake[i] = read_adc() * 0.0196078f;
// Its not precisely the same but its more than close enough for
// this application.
if(input(PIN_D0))
output_low(PIN_C0);
output_low(PIN_C1);
// Wait a moment, in this loop you are only measuring one
// channel each time. There's no point is checking every channel in
// every loop. Try using a switch block here, one case for each loop possibility.
// the if(!input(PIN_D0)) is almost, but not quite redundant here. If // PIN_D0 was 0 we'll execute this code. So why check it again?
// Unless there's some strange possibility that it may have
// changed between then and now (less than a microsecond) AND
// its important, which is isn't. Else means else.
RF Developer |
SherpaDoug
Posted: Fri May 25, 2012 6:00 am |
If you just rearrange these lines you will solve your immediate problem: Code: |
intake[i]= read_adc(); // Get input |
You need a delay AFTER selecting the A/D channel and BEFORE reading it. _________________ The search for better is endless. Instead simply find very good and get the job done. |
sterob
Posted: Sat May 26, 2012 5:10 am |
Hi everyone, thanks for your suggestions. I've been able to fix the problem, i observed that the channel 8 was not responding, probably due to my "for() loop", so I decided to use a 40pin chip, instead of skipping, through 5, 5,and 7. Also, I changed the "for loop" to scan through only six channels. I also applied your suggestions, Thanks a million buck! Here is an excerpt of the changes made:
for(i=0; i<6; i++ ) // scan from 0 through 5
set_adc_channel(i); // Select channel
delay_ms(100); // Wait 1 sec
intake [i]= read_adc(); // Get input
takn[i]=((intake[i])*scale); // Scale intake
printf( " takin%u = %4.3f \r", i , takn[i]); // Display displays each
dyeatman
Posted: Sat May 26, 2012 8:07 am |
BTW, the delay after setting the channel only needs to be 20 to 30
microseconds not milliseconds depending on input impedance. In
your case just use 30 to be safe. If you want a pause between the reads
put a line with the desired delay (i.e 500ms) after the printf. _________________ Google and Forum Search are some of your best tools!!!! |
SherpaDoug
Posted: Sat May 26, 2012 4:27 pm |
Usually right after I read the A/D I select the next channel. By the time I have scaled the result and stored it away the A/D is ready for the next reading without any explicit delay. I still count the cycles to make sure though. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Posted: Sun May 27, 2012 12:12 pm |
Quote: | #include <18F2550.h>
#DEVICE ADC=8
#FUSES NOWDT
#FUSES WDT128
#FUSES PLL1
#FUSES CPUDIV1
#FUSES NOUSBDIV
#FUSES XT // Crystal osc <= 4mhz for PCM/PCH ,
Did you notice the comment about the XT fuse, and then compare it
to your #use delay() frequency ?
What is your real crystal frequency ? Is it 4 MHz or 20 MHz ?
If it's 20 MHz, the XT fuse won't work. The PIC won't run with that fuse.
It requires the HS fuse for 20 MHz.
Because you have this mistake, I suspect that this is really a Proteus
project. Proteus doesn't care about mistakes like that, but real hardware
won't work at all. |
sterob
Posted: Sun May 27, 2012 5:49 pm |
Quote: | Did you notice the comment about the XT fuse, and then compare it
won't work at all.
I am using a 4MHz crystal, yeah you are right, I simulated with proteus! |
Posted: Sun May 27, 2012 5:52 pm |
If you have a 4 MHz crystal and you set the #use delay() at 20 MHz,
all delay_ms() and delay_us() statements will run 5 times longer
than they should.
You must match the oscillator frequency and the #use delay(). |
