wtorres
| CCS Pointer Issue |
Posted: Mon May 21, 2012 7:39 pm |
I'm facing an issue with CCS compiler version 4.065, when I compile the code below:
rom char Data[] = {1,2,3};
rom char *ShowData;
Mostra = &Data[0];
printf("%x", (char)*Mostra);
Instead of receiving the value 1 through the serial port, I'm getting always 10. Could you please someone help me on this. I have executed the same code on Code::Blocks and worked fine.
Thanks. |
Posted: Mon May 21, 2012 8:58 pm |
| Always post your PIC. |
Posted: Tue May 22, 2012 1:19 am |
I think 4.065, was before CCS got rom pointers to work. It was one of the features that was 'last' to get going, and my memory was that it didn't work before about 4.07x somewhere.
Sorry, but compiler upgrade only real answer if so.
Posted: Tue May 22, 2012 7:40 am |
As another comment though, you don't show the declaration of 'Mostra'. Also remember that 'Data' on it's own, is the address of the first element of the array.
Just tried:
#include <18F452.h>
#FUSES HS //External 20MHz clock
#FUSES PUT //Power Up Timer
#FUSES NOLVP
#use rs232(baud=9600,parity=N,UART1,bits=8,ERRORS)
void main(void) {
rom char* ShowData;
int temp;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
ShowData = &Data[0];
temp=*Showdata;
printf("%02x\n", temp);
do {
} while (TRUE);
With 4.070 (the oldest V4 compiler I have kept), and it doesn't work.
Then compiled with 4.099, and it does.
I had tweaked a couple of things that might cause problems (I had found in the past that for some printf operators, you do have to extract the element from the array 'first'), but these didn't help on the older compiler.
So, I'm afraid 'compiler age' is the fundamental problem.
