Firmware Won't Start Up After Power Cycling
Geps
PostPosted: Wed May 16, 2012 3:31 am     Reply with quote
I've got a bizarre problem that I'm at a loss to explain.
I have the following program that when programmed to the PIC works as intended. I then turn the unit off and on again and the text doesn't get transmitted. I've cleared out as much of my code as I can and as you can see it doesn't leave many places to go wrong.
Attached is the (#list) .lst file:
CCS PCH C Compiler, Version 4.125, 54981               16-May-12 10:20
               Filename:
               ROM used: 200 bytes (0%)
                         Largest free fragment is 55934
               RAM used: 9 (0%) at main() level
                         10 (0%) worst case
               Stack:    1 locations
00000:  GOTO   0068
....................    #include <18F4620.h>
.................... //////// Standard Header file for the PIC18F4620 device ////////////////
.................... #device PIC18F4620
.................... #list
....................    #fuses H4, NOWDT, NOBROWNOUT, NOPUT, NOLVP, NOMCLR
....................    #USE delay(crystal=10Mhz, clock=40Mhz)
0001A:  CLRF   FEA
0001C:  MOVLW  09
0001E:  MOVWF  FE9
00020:  MOVF   FEF,W
00022:  BZ    0040
00024:  MOVLW  0C
00026:  MOVWF  01
00028:  CLRF   00
0002A:  DECFSZ 00,F
0002C:  BRA    002A
0002E:  DECFSZ 01,F
00030:  BRA    0028
00032:  MOVLW  F7
00034:  MOVWF  00
00036:  DECFSZ 00,F
00038:  BRA    0036
0003A:  BRA    003C
0003C:  DECFSZ FEF,F
0003E:  BRA    0024
00040:  GOTO   00BA (RETURN)
....................    #BYTE port_b = 0xF81
....................    #zero_ram
....................    #define BOOTLOADER_END  (150*64)
....................    #build(reset=0x00:0x07)
....................    #org 0xEF, BOOTLOADER_END {}
.................... #define MCUADDRESS 0x12
.................... #define BOOTLOADER_NOT_PRESENT
.................... #use RS232 (STREAM=DEBUGSERIAL, baud=115200, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
.................... void main() {
00068:  CLRF   FEA
0006A:  CLRF   FE9
0006C:  CLRF   04
0006E:  BSF    FB8.3
00070:  MOVLW  56
00072:  MOVWF  FAF
00074:  MOVLW  00
00076:  MOVWF  FB0
00078:  MOVLW  A6
0007A:  MOVWF  FAC
0007C:  MOVLW  90
0007E:  MOVWF  FAB
00080:  MOVF   FC1,W
00082:  ANDLW  C0
00084:  IORLW  0F
00086:  MOVWF  FC1
00088:  MOVLW  07
0008A:  MOVWF  FB4
0008C:  CLRF   FF8
0008E:  BCF    FD0.7
00090:  MOVLW  7E
00092:  MOVWF  00
00094:  MOVLW  10
00096:  MOVWF  01
00098:  MOVLW  02
0009A:  MOVWF  FE9
0009C:  MOVLW  00
0009E:  MOVWF  FEA
000A0:  CLRF   FEE
000A2:  DECFSZ 00,F
000A4:  BRA    00A0
000A6:  DECFSZ 01,F
000A8:  BRA    00A0
000AA:  CLRF   05
000AC:  CLRF   06
000AE:  CLRF   07
....................    int8 ByteCount = 0x00;
....................    int8 TempByte = 0x00;
....................    int8 BitCount = 0x00;
....................    delay_ms(2000);
000B0:  MOVLW  08
000B2:  MOVWF  08
000B4:  MOVLW  FA
000B6:  MOVWF  09
000B8:  BRA    001A
000BA:  DECFSZ 08,F
000BC:  BRA    00B4
....................       fprintf(DEBUGSERIAL, "Philips Starting\n");
000BE:  MOVLW  08
000C0:  MOVWF  FF6
000C2:  MOVLW  00
000C4:  MOVWF  FF7
000C6:  BRA    0044
....................    while(TRUE){}
000C8:  BRA    00C8
000CA:  SLEEP
Configuration Fuses:
   Word  1: C600   H4 FCMEN IESO
   Word  2: 1E19   NOPUT NOBROWNOUT BORV20 NOWDT WDT32768
   Word  3: 0700   CCP2C1 PBADEN LPT1OSC NOMCLR
   Word  4: 0081   STVREN NOLVP NOXINST NODEBUG
   Word  5: C00F   NOPROTECT NOCPB NOCPD
   Word  6: E00F   NOWRT NOWRTC NOWRTB NOWRTD
   Word  7: 400F   NOEBTR NOEBTRB
SherpaDoug
PostPosted: Wed May 16, 2012 6:10 am     Reply with quote
I would make sure the clock is running at the speed you expect. Can you put a scope on the serial and see if the baud rate is way off? Output a square wave and verify the speed with either a scope, or make it real slow and use a watch.
drh
PostPosted: Wed May 16, 2012 8:21 am     Reply with quote
Enable the Power Up Timer?
David
PostPosted: Wed May 16, 2012 8:56 am     Reply with quote
Is the programmer still attached when it works?.
Obvious thing would be something like a ground connection not made, but going through the programmer unit when it is present....
Geps
PostPosted: Thu May 17, 2012 1:52 am     Reply with quote
Thanks guys,
After a couple more hours investigating it seems it was a faulty board that was drawing power from the USB cable.
