Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
Driver for the ADNS 2051
milops3
PostPosted: Fri May 11, 2012 9:24 am     Reply with quote
This is a driver for Avago ADNS 2051, reads the current frame 16x16 pixel.
//       name      ADNS_2051.c
  Set_serial();      seting I/O for communication
  init_ADNS2051 ();      chip initialization,return product id 0x02
  dumpFrame();          reads actual picture, 16x16 pixels in frame[]
#define    SCLK    PIN_B0         < in def_ADNS2051.h
#define    SDIO    PIN_B1         <
#define    PD    PIN_B2         <
static unsigned int frame[255];      <
#define REG_PRODUCT_ID 0x00
#define REG_REVISION_ID 0x01
#define REG_MOTION 0x02
#define REG_DELTA_X 0x03
#define REG_DELTA_Y 0x04
#define REG_SQUAL 0x05
#define REG_AVERAGE_PIXEL 0x06
#define REG_MAXIMUM_PIXEL 0x07
#define REG_CONFIG_BITS 0x0A
#define REG_DATA_OUT_LOWER 0x0C
#define REG_DATA_OUT_UPPER 0x0D
#define REG_SHUTTER_LOWER 0x0E
#define REG_SHUTTER_UPPER 0x0F
#define REG_FRAME_PERIOD_LOWER 0x10
#define REG_FRAME_PERIOD_UPPER 0x11
void Set_serial()
 OUTPUT_HIGH(SCLK);
 OUTPUT_FLOAT(SDIO);
 OUTPUT_HIGH(PD);
 delay_us(1);
 OUTPUT_LOW(PD);
void Write_ADNS2051(int8 adr,int8 data)
unsigned char i;
 adr|= 0x80;
 for(i=0;i<8;i++)
   output_low (SCLK); if (adr&128)  output_high(SDIO); else output_low(SDIO);adr=adr<<1; output_high (SCLK);
 for(i=0;i<8;i++)
   output_low (SCLK); if (data&128)  output_high(SDIO); else output_low(SDIO); data=data<<1;output_high (SCLK);
 OUTPUT_FLOAT(SDIO);
unsigned char Read_ADNS2051(int8 adr)   //
unsigned char data=0,i;
 for(i=0;i<8;i++)
   output_low (SCLK); if (adr&128)  output_high(SDIO); else output_low(SDIO); adr=adr<<1;output_high (SCLK);
 OUTPUT_FLOAT(SDIO);
 delay_us(100);
 for(i=128; i >0 ; i >>= 1)
   output_low (SCLK);output_high (SCLK); output_toggle (PIN_B3);if (input(SDIO)==1) data|= i;
 return data;
unsigned int init_ADNS2051 ()
unsigned int datain,P_ID;
 P_ID=Read_ADNS2051(REG_PRODUCT_ID);
 datain=Read_ADNS2051(REG_REVISION_ID);
 datain=Read_ADNS2051(REG_CONFIG_BITS);
 datain |= 0x80;
 Write_ADNS2051(REG_CONFIG_BITS, datain);
 return P_ID;
void dumpDelta()
 signed int dx,dy;
 Read_ADNS2051(REG_MOTION);
 dx = Read_ADNS2051(REG_DELTA_X);
 dy = Read_ADNS2051(REG_DELTA_Y);
 // printf("DELTA:");
 printf(" %d",dx);
 printf(" %d",dy);
 putc(0x0d);
 putc(0x0a);
void dumpFrame()
 unsigned int datain,count = 0,dumpWidth = 255;
  datain = Read_ADNS2051(REG_CONFIG_BITS);
  datain |= 0x01;
  datain |= 0x08;
  do
       //pix = Read_ADNS2051(REG_DATA_OUT_UPPER);
       datain = Read_ADNS2051(REG_DATA_OUT_LOWER);
       if( (datain & 0x80) == 0 ) { // Data is valid
            frame[count++] = datain;
  while (count != dumpWidth);
  datain &= 0xE0;
an example, view the current images on the LCD Nokia 3310
#include <18F2320.h>
#include <def_ADNS2051.h>
#device adc=8
#FUSES NOWDT
#FUSES WDT128
#FUSES INTRC
#FUSES PUT
#FUSES NOBROWNOUT
#FUSES NOLVP
#fuses MCLR
#fuses FCMEN
#use delay(oscillator=8Mhz)
//#use rs232(baud=38400,xmit=PIN_C6,rcv=PIN_C7)
#include <N_3310_DISPLAY.c>      //by Michel Bavin
#include <ADNS_2051.c>
//static unsigned int frame[255];      < in def_ADNS2051.h
unsigned int p,f,i;
unsigned long t;
 setup_oscillator(OSC_8MHZ);
 OUTPUT_HIGH(pin_A0);
 Set_serial();
 delay_ms (100);
 init_ADNS2051 ();
 nokia_init(1);            //vertikalne - vertical addressing
 nokia_clear_screen();
while(true)
 OUTPUT_toggle(pin_A0);
 dumpFrame();
 nokia_gotoxy(0,0);
 f=0;
 for(p=0;p<32;p++)
   if(frame[f++]<0x1b) pixel[p]|=1;      //0x1b
   if(frame[f++]<0x1b) pixel[p]|=2;
   if(frame[f++]<0x1b) pixel[p]|=4;
   if(frame[f++]<0x1b) pixel[p]|=8;
   if(frame[f++]<0x1b) pixel[p]|=16;
   if(frame[f++]<0x1b) pixel[p]|=32;
   if(frame[f++]<0x1b) pixel[p]|=64;
   if(frame[f++]<0x1b) pixel[p]|=128;
 p=0;
 for(i=0;i<15;i++)
   nokia_write_data(pixel[p]);
   pixel[p]=0;
   p++;
   pixel[p]=0;
   p++;
   nokia_gotoxy(i,0);
videos
http://www.youtube.com/watch?v=mVHUqZME2Cc&feature=g-upl
