16C773 analog problems
Tone
PostPosted: Tue Oct 30, 2001 11:09 am     Reply with quote
I've just tried to port a program over from a 16F876 to a 16C773 so as to make use of the 12 bit ADC on this part (I'm using v2.734). The program seems to fall over on ADC reading, and adc_read() just keeps returning 4095. Here is a listing for the 16F876 which seems to work fine:-
#include <16f876.h>
#fuses XT, NOWDT, NOPUT, NOPROTECT, NOBROWNOUT
main()
setup_adc_ports(RA0_ANALOG);
setup_adc(ADC_CLOCK_DIV_8);
set_adc_channel(0);
printf("\%lu\n\r", read_adc());
And here's the ported code for the 16C773:-
#include <16c773.h>
main()
setup_adc_ports(ANALOG_A0);
set_adc_channel(0);
The only changes I had to make, was the first line in main() where the #define in the header file 16c773.h is different for single channel ADC conversion. As I mentioned above, this version just outputs 4095 no matter what voltage (within power rails) was applied. In the header file, I noticed that there are extra options that can be or'd with other options to set up the reference for the ADCs, however since my preferred option "VSS_VDD" is defined to be 0x00, I didn't bother to add it. I also made sure I connected the power pins correctly as they are different to the 16F876.
Any help appreciated.
Tone.
___________________________
Original Post ID: 891
Tomi
Re: 16C773 analog problems
PostPosted: Tue Oct 30, 2001 3:22 pm     Reply with quote
Try to separate the printf() and Read_ADC() functions:
unsigned long value;
value = read_adc();
printf("\%lu\n\r", value);
:=Hello,
:=I've just tried to port a program over from a 16F876 to a 16C773 so as to make use of the 12 bit ADC on this part (I'm using v2.734). The program seems to fall over on ADC reading, and adc_read() just keeps returning 4095. Here is a listing for the 16F876 which seems to work fine<img src="http://www.ccsinfo.com/pix/forum/disagree.gif" border="0">
:=#include <16f876.h>
:=#fuses XT, NOWDT, NOPUT, NOPROTECT, NOBROWNOUT
:=#use delay(clock=4000000)
:=#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
:=main()
:= setup_adc_ports(RA0_ANALOG);
:= setup_adc(ADC_CLOCK_DIV_8);
:= set_adc_channel(0);
:= while(TRUE)
:= printf("\%lu\n\r", read_adc());
:= delay_ms(100);
:=And here's the ported code for the 16C773<img src="http://www.ccsinfo.com/pix/forum/disagree.gif" border="0">
:=#include <16c773.h>
:=main()
:= setup_adc_ports(ANALOG_A0);
:= while(TRUE)
:= delay_ms(100);
:=The only changes I had to make, was the first line in main() where the #define in the header file 16c773.h is different for single channel ADC conversion. As I mentioned above, this version just outputs 4095 no matter what voltage (within power rails) was applied. In the header file, I noticed that there are extra options that can be or'd with other options to set up the reference for the ADCs, however since my preferred option "VSS_VDD" is defined to be 0x00, I didn't bother to add it. I also made sure I connected the power pins correctly as they are different to the 16F876.
:=Any help appreciated.
:=Tone.
Original Post ID: 894
Tone
PostPosted: Wed Oct 31, 2001 3:53 am     Reply with quote
Thanks for the reply. I have just tried what you suggested to no effect. It still doesn't work. I just wandered if anyone knows whether the adc_read() function works with the 16C773, as my code is very simple yet still doesn't seem to work?
Regards,
Tone.
:=Try to separate the printf() and Read_ADC() functions:
:=unsigned long value;
:=value = read_adc();
:=printf("\%lu\n\r", value);
Original Post ID: 899
Kari Leino
PostPosted: Wed Oct 31, 2001 7:49 am     Reply with quote
A/D result is given default left justified. Modify line "#define ANALOG_A0 0xE // RA0" to "#define ANALOG_A0 0x8E // RA0" in 16c773.C -file.
:=Hello,
:=main()
:= while(TRUE)
:= delay_ms(100);
:=main()
:= while(TRUE)
:= delay_ms(100);
:=Tone.
Original Post ID: 902
Tone
PostPosted: Wed Oct 31, 2001 9:01 am     Reply with quote
I have just tried this out, and again no joy. Because with the orginal code I was getting no change at all in the result, I wasn't expecting a justification error to be the cause of the problem. I was (and still am) getting 4095 all the time, regardless of input voltage.
Many Thanks,
Tone.
:=A/D result is given default left justified. Modify line "#define ANALOG_A0 0xE // RA0" to "#define ANALOG_A0 0x8E // RA0" in 16c773.C -file.
Original Post ID: 906
Kari Leino
PostPosted: Wed Oct 31, 2001 2:02 pm     Reply with quote
How about Tris registers? Analog inputs reads full scale or zero depending port state if ports are configured as outputs. Set_tris_a(0b00000001);
:=I have just tried this out, and again no joy. Because with the orginal code I was getting no change at all in the result, I wasn't expecting a justification error to be the cause of the problem. I was (and still am) getting 4095 all the time, regardless of input voltage.
:=Many Thanks,
:=Tone.
:=:=A/D result is given default left justified. Modify line "#define ANALOG_A0 0xE // RA0" to "#define ANALOG_A0 0x8E // RA0" in 16c773.C -file.
Original Post ID: 911
argosy
PostPosted: Wed Oct 31, 2001 3:03 pm     Reply with quote
Yes the Read_ADC() function works on the with the 16c773 because I have ported code from the 16f876 and it worked with little trouble, but the version of PCM I was using did not the support the 16c773 so I had to modify the 16f876.h file to make it work. The other problem you may encounter is that the 12 bit ADC is not 12bit but 11bit at best see the microchip errata ( unless they have fixed it). Also use an off chip voltage reference for the best result. I am sorry that I can only offer these general words of advice as my code is on my works machine and I won't have access to it until next week sometime.
Argosy
:=Thanks for the reply. I have just tried what you suggested to no effect. It still doesn't work. I just wandered if anyone knows whether the adc_read() function works with the 16C773, as my code is very simple yet still doesn't seem to work?
:=Regards,
:=Tone.
:=:=Try to separate the printf() and Read_ADC() functions:
:=:=unsigned long value;
:=:=value = read_adc();
:=:=printf("\%lu\n\r", value);
Original Post ID: 913
Tone
PostPosted: Fri Nov 02, 2001 9:17 am     Reply with quote
Well, I have finally got the thing working now, and I have to admit that it was down to my own stupidity. I thought I had got the power lines wired up correctly but it turns out that I hadn't. I made the correction and my ported code now runs.
Many Thanks to all who replied.
Tone.
:=Hello,
Original Post ID: 925
