MRF89XA
jeremy57350
MRF89XA
PostPosted: Sun May 06, 2012 3:21 am     Reply with quote
hello, I made a small program for my transmission module, and I do not understand why it does not work.
A problem of waking up?
Wrong setting?
Help please :(
Code principal:
#include <18F2580.h>
#include <MRF89XA.h>
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_1  (SPI_L_TO_H)
#define SPI_MODE_2  (SPI_H_TO_L)
#define SPI_MODE_3  (SPI_H_TO_L | SPI_XMIT_L_TO_H
#use delay (clock=4000000)
#int_timer2
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,BITS=8)  //exemple pour 9600bds et émission sur C6 et réception sur C7
#use spi(FORCE_HW,BITS=8, stream=SPI_STREAM)
//#include "LCD Picdem2.c"
#define MASTER_CS PIN_c0 // selection spi donnée
#define DATA_CS PIN_c1 // selection spi configuration
void RegisterSet(BYTE address, BYTE value)
      output_low(MASTER_CS);
      address = (address<<1);
      spi_write (address);
      spi_write (value);
      output_high(MASTER_CS);
void WriteFIFO(BYTE data )
    output_low(DATA_CS);
    spi_write(Data);
    output_high(DATA_CS);
//set_tris_c (0b11010001);
setup_spi (spi_master|SPI_MODE_0);
//setup_oscillator( OSC_4MHZ );
//output_low(MASTER_CS);
//output_low(DATA_CS);
//delay_ms(200);
RegisterSet(REG_MCPARAM0, RF_TRANSMITTER | FREQBAND_950  | VCO_TRIM_11,  );
//lcd_init();
while(true)
   int toto=25;
   delay_ms(20);
   writeFIFO(toto);
header microchip.
PostPosted: Sun May 06, 2012 11:19 am     Reply with quote
We need more information.
What doesn't 'wakeup' the PIC or the peripheral device ?
I don't see where you tell the PIC to go to sleep though.
You should add a couple of LEDs and toggle them at 'key' points of your program to confirm the PIC does what you think it should.
Since you seem to have an LCD as well as PC link, perhaps send them 'messages' as to the state of the program(step 1,2,3,etc).
jeremy57350
PostPosted: Sun May 06, 2012 1:51 pm     Reply with quote
I thought was a problem of waking up the module MRF89XA, or parameters parametrais evil, have you ever work with this module?
Mike Walne
PostPosted: Sun May 06, 2012 2:01 pm     Reply with quote
Does it matter?
The guy's trying to help you, so don't be rude.
I agree you are NOT giving enough information.
You've got a problem, otherwise you would not be asking.
It's often the case that you're looking in the wrong place.
CCS don't pay us to provide help.
That's why we ask awkward questions.
Mike
jeremy57350
PostPosted: Sun May 06, 2012 2:22 pm     Reply with quote
I do not think it was annoying and I'm sorry to offended, I thank you in advance for your help.
PostPosted: Sun May 06, 2012 2:37 pm     Reply with quote
Ignoring the module for a moment, there are some severe problems with the code as posted:
1) _Except_ for the device header file, in general 'includes', _must_ be after the system configuration lines (clock, fuses RS232 etc.). Otherwise if any of the features using these (delays, serial I/O etc.) are used in the include file, they won't work.
It doesn't appear as if the posted code actually uses the include file, but correct this.
2) The definition #INT_TIMERx, is meant to be followed by the routine to handle this interrupt. Having it floating in the middle of the configuration lines, may well result in invalid code.....
3) Then you are mixing SPI operation methods. You need to _either_ use '#USE SPI', and include a mode definition here, _or_ use setup_spi. If you use the latter, then you must use 'spi_xfer' to actually send/receive, as opposed to spi_read/spi_write. I'd doubt if the SPI is actually setup as you want....
4) You have two 'chip selects' (called 'CSCON', and CSDAT on the chip). Your patterns need to be to drop CSCON to access the config registers, or drop CSDAT to access the data registers. It is not clear from your 'master_cs' name, which line you are dropping, but hopefully this is the CSCON line.
5) Look at the data sheet. You are only setting the GCONFIG register. You need to set several more values before the chip will be ready to run.
6) Are you making connections to the IRQ lines. You _will_ need to be able to poll these at least.
jeremy57350
PostPosted: Sun May 06, 2012 3:09 pm     Reply with quote
thank you for your help
1. If I understand you well I have to remove the 232 and fix my problem came out with an example TRIS_C
2. my # int_timer came from an old program, so has excluded entirely
3. I thought my SPI bus has functioned properly because the oscilloscope I was reporting the correct values​​.
I think most used out # use_spi because I have more KNOWLEDGE for this.
I should then set encors other address, even if it defaults are set by
MASTER_CS my line is well connected and has CS_CON I did not think the IRQ input is important for transmission but only to receive an interrupt with
ps: Sorry for language mistakes I'm doing better or worse in English
Mike Walne
PostPosted: Mon May 07, 2012 8:50 am     Reply with quote
Apology accepted.
You're being told to put the basics right first. Then you have a chance of getting your module to work.
Best of luck.
Mike
jeremy57350
PostPosted: Mon May 07, 2012 1:44 pm     Reply with quote
Thank you, when you said to the first base to right, I must change what program?
I vien because today I try again this is still nothing unfortunately.
