PIC16F628 Portb Pullups Enable
2-Chri
PostPosted: Sat Apr 28, 2012 4:02 pm     Reply with quote
I want to enable the internal pullups resistor but I couldn't enable the resistors. My code is below:
#include <16F628A.h>
#include <Lcd_16x2_4bit_Operation_2.c>
#fuses HS,MCLR,PUT,NOLVP,NOWDT,NOBROWNOUT,PROTECT,CPD
#byte PORTA = 0x05
#byte PORTB = 0x06
port_b_pullups(TRUE);
set_tris_a(0x2F);
set_tris_b(0xC0);
while (TRUE)
  if(input(PIN_B7) == 1)
     output_high(OUT);
     output_low(OUT);
Mike Walne
PostPosted: Sun Apr 29, 2012 12:58 pm     Reply with quote
How do you KNOW that pullup is not working?
The code in your post does not compile. ( I get error "Undefined identifier OUT". )
Mike
2-Chri
PostPosted: Sun Apr 29, 2012 2:41 pm     Reply with quote
FInally works. I disconect the pins PGC and PGC from ICD3 to PIC and works OK! Thanks!
