Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
ICD-U40 debug - gets/printf
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go
schmez
PostPosted: Sun Apr 15, 2012 3:20 pm     Reply with quote
I am trying to debug using the ICD-U40 on a PIC16F690 - all works in debugger but the "Monitor" section does not seem to work. I have the "#use RS232(DEBUGGER)" set and nothing shows in the monitor and it does not allow me to send characters as well - I cannot find any good documentation on using the debugger in the PCW.
Thanks.
schmez
Sample code being tested
PostPosted: Tue Apr 17, 2012 10:28 am     Reply with quote
Here is a sample code I am testing - it will not show Hello World in the monitor window in the PCW software debugger:
#include <16F690.h>
#device adc=16
#include <stdio.h>
#include <string.h>
#use rs232(DEBUGGER)
main()
printf("Hello World \n\r");
schmez
B3 is not supported in 16F690
PostPosted: Fri Apr 20, 2012 12:49 pm     Reply with quote
Have to connect wire from pin 6 of J2 on header to a xmit pin on emulator.
For example:
#use RS232(DEBUGGER, xmit=PIN_B7, RCV=PIN_B7)
Pin B7 on the header emulator was connected to pin 6 of J2 (the RJ45 plug for the debugger).
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go All times are GMT - 6 Hours
