Hendrik
| Need help to change the code use for LCD into Oled |
Posted: Thu Apr 19, 2012 11:05 am |
I have the sources to use LCD display now I use the Winstar
WH1602 L1 lcd display and want to change this into the WEH001602B
both are HD44780 compatible.
Does anyone can help me out changing the source that will work on the Oled of Winstar?
I use the PIC16F877A.
Hereby the code
//// LCDD.C ////
//// Driver for common LCD modules ////
//// lcd_init() Must be called before any other function. ////
//// lcd_putc(c) Will display c on the next position of the LCD. ////
//// The following have special meaning: ////
//// \f Clear display ////
//// \n Go to start of second line ////
//// \b Move back one position ////
//// lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1) ////
//// lcd_getc(x,y) Returns character at position x,y on LCD ////
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#ifdef LCD_16x4_lines
#define lcd_line_1 0x00 // LCD RAM address for the first line (16x4)
#define lcd_line_2 0x40 // LCD RAM address for the second line (16x4)
#define lcd_line_3 0x10 // LCD RAM address for the third line (16x4)
#define lcd_line_4 0x50 // LCD RAM address for the fourth line (16x4)
#else //LCD_20x4_lines
#define lcd_line_1 0x00 // LCD RAM address for the first line (20x4)
#define lcd_line_2 0x40 // LCD RAM address for the second line (20x4)
#define lcd_line_3 0x14 // LCD RAM address for the third line (20x4)
#define lcd_line_4 0x54 // LCD RAM address for the fourth line (20x4)
#endif
// Comptible with 16,20,40x2 (default) but not for 40x4
// *x1 or 8x2 LCD data types are NOT recommanded.
byte CONST LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
// These bytes need to be sent to the LCD
// to start it up.
#list
byte lcd_read_byte() {
byte low,high;
#ifdef LCD_HIGH
tris_lcd_port |= 0xf0; // Input High Pins
#else
tris_lcd_port |= 0X0f; // Input Low Pins
#endif
lcd_rw = 1;
delay_cycles(1);
lcd_enable = 1;
delay_us(1);
high = lcd_port;
lcd_enable = 0;
delay_cycles(2);
lcd_enable = 1;
delay_us(1);
low = lcd_port;
lcd_enable = 0;
#ifdef LCD_HIGH
tris_lcd_port &= 0x0f; // Output High Pins
#ASM MOVLW 0xF0
ANDWF HIGH,F
SWAPF LOW,W
ANDLW 0x0F
IORWF HIGH,F
#ENDASM
return(high);
#else
tris_lcd_port &= 0Xf0; // Output Low Pins
#ASM
MOVLW 0x0F
ANDWF LOW,F
SWAPF HIGH,W
ANDLW 0xF0
IORWF LOW,F
#ENDASM
return(low);
#endif
void lcd_send_nibble( byte n ) {
#ifdef LCD_HIGH
tris_lcd_port &= 0x0f; // lcd_port direction = Output
lcd_port &= 0b00001111;
#else
tris_lcd_port &= 0Xf0; // lcd_port direction = Output
lcd_port &= 0b11110000;
#endif
lcd_port |= n;
delay_cycles(1);
lcd_enable = 1;
delay_us(2);
lcd_enable = 0;
void lcd_send_byte( byte address, byte n ) {
byte i=0; // Init 500ms. Counter for LCD Time_Out (NOT Implemented here).
trisb &= 0b11100111; // RW and RS pins are Outputs.
lcd_rs = 0;
while(bit_test(lcd_read_byte(),7));
lcd_rs = address;
delay_cycles(1);
lcd_rw = 0;
delay_cycles(1);
lcd_enable = 0;
#ifdef LCD_HIGH
lcd_send_nibble(n & 0xf0); // Send High nibble...
lcd_send_nibble(n << 4);
#else
lcd_send_nibble(n >> 4); // Send High nibble...
lcd_send_nibble(n & 0x0f);
#endif
void lcd_init() {
byte i;
#ifdef LCD_HIGH
#else
#endif
delay_ms(15);
for(i=1;i<=3;++i) {
lcd_send_nibble(3);
delay_ms(5);
lcd_send_nibble(2);
for(i=0;i<=3;++i)
lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( byte x, byte y) {
byte address;
if (y == 1 || !y) // If y=0 or 1 chooses the first line.
address=lcd_line_1;
if (y == 2)
address=lcd_line_2;
if (y == 3)
address=lcd_line_3;
if (y == 4)
address=lcd_line_4;
address+=x-1;
lcd_send_byte(0,0x80|address);
#separate
void lcd_putc( char c) {
switch (c) {
case '\f' : lcd_send_byte(0,1);
delay_ms(2);
case '\n' :
case '\2' : lcd_gotoxy(1,2); break;
case '\3' : lcd_gotoxy(1,3); break;
case '\4' : lcd_gotoxy(1,4); break;
case '\b' : lcd_send_byte(0,0x10); break;
default : lcd_send_byte(1,c); break;
char lcd_getc( byte x, byte y) {
char value;
lcd_gotoxy(x,y);
lcd_rs=1;
value = lcd_read_byte();
lcd_rs=0;
return(value);
#nolist
Gabriel
Posted: Thu Apr 19, 2012 2:25 pm |
| Quote: | | both are HD44780 compatible |
Does that not imply they use the same driver?
... i might be wrong.
G. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Hendrik
Posted: Thu Apr 19, 2012 2:33 pm |
| Yes, but when i connect the Oled display nothing happen. |
ezflyr
Posted: Thu Apr 19, 2012 2:48 pm |
Well, does your circuit and code work with a "normal" LCD display? Lots of people here have trouble with getting a normal LCD display working, so I'd try that first before attempting to use the OLED display.
A couple of suggestions:
1. Scrap the driver you are using, and switch to the Flex_LCD driver. This driver has very good support on the forum.
2. Make sure that you disconnect pin #3 on the OLED when you substitute it for the "normal" LCD. It may not matter, but the datasheet for the OLED display says this pin is a 'NC' (no connect), but it's the Vee (contrast voltage) pin on the normal LCD.
John |
Hendrik
Posted: Thu Apr 19, 2012 3:07 pm |
Yes everything work with the lcd display of winstar
For several yards how.
Because winstar has an Oled display i want to use this
That's the reason why I want to change it |
ezflyr
Posted: Thu Apr 19, 2012 3:11 pm |
OK, if the exact circuit, and the exact firmware work with a "normal" display then you should ask Winstar if the OLED is a direct swap for the normal LCD.
What about the pin #3 issue I mentioned?? Did you disconnect it when you connect the OLED display?
Thanks,
John |
Hendrik
Posted: Thu Apr 19, 2012 3:13 pm |
I have change the code see
this link http://www.picaxe.com/docs/oled.pdf
strange:
only the upperline in the display works the lowerline
stay black. everything on the upperline works ok
see code
//// LCDD.C ////
#endif
byte CONST LCD_INIT_STRING[6] = {
0x08, //display off
0x06, //entry mode set//need to configure this cmd or char will move left not move right
0x17, //Character mode and internel power on (have to turn on internel power to get the best brightness)
0x01, //clear display
0x02, //return home
0x0c //display on
// to start it up.
#list
byte low,high;
#ifdef LCD_HIGH
#else
#endif
lcd_rw = 1;
delay_cycles(1);
lcd_enable = 1;
delay_us(1);
high = lcd_port;
lcd_enable = 0;
delay_cycles(2);
lcd_enable = 1;
delay_us(1);
low = lcd_port;
lcd_enable = 0;
#ifdef LCD_HIGH
#ASM MOVLW 0xF0
ANDWF HIGH,F
SWAPF LOW,W
ANDLW 0x0F
IORWF HIGH,F
#ENDASM
return(high);
#else
#ASM
MOVLW 0x0F
ANDWF LOW,F
SWAPF HIGH,W
ANDLW 0xF0
IORWF LOW,F
#ENDASM
return(low);
#endif
#ifdef LCD_HIGH
#else
#endif
lcd_port |= n;
delay_cycles(1);
lcd_enable = 1;
delay_us(2);
lcd_enable = 0;
lcd_rs = 0;
lcd_rs = address;
delay_cycles(1);
lcd_rw = 0;
delay_cycles(1);
lcd_enable = 0;
#ifdef LCD_HIGH
#else
#endif
void lcd_init() {
byte i;
#ifdef LCD_HIGH
#else
#endif
delay_ms(15);
for(i=1;i<=3;++i) {
lcd_send_nibble(3);
delay_ms(5);
lcd_send_nibble(2);
for(i=0;i<6;++i)
byte address;
address=lcd_line_1;
if (y == 2)
address=lcd_line_2;
if (y == 3)
address=lcd_line_3;
if (y == 4)
address=lcd_line_4;
address+=x-1;
#separate
switch (c) {
delay_ms(2);
case '\n' :
char value;
lcd_gotoxy(x,y);
lcd_rs=1;
lcd_rs=0;
return(value);
#nolist
Hendrik
Posted: Thu Apr 19, 2012 3:27 pm |
| I have disconnect pin 3 and it is NC |
