Problem usb 18f2550
maissa
Problem usb 18f2550
PostPosted: Tue Apr 10, 2012 11:23 am     Reply with quote
Hi everyone, I have to detect usb connection. I tried to simulate my program in Isis and it works very well but when I program my pic and connect the cable usb nothing happen. Will you help me please to configure fuses bits in the programmer ? I'm using pikprog2elnec and this is my ccs program:
#include <18F2550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#define USB_HID_DEVICE TRUE
#define USB_EP1_TX_ENABLE USB_ENABLE_INTERRUPT
#define USB_EP1_TX_SIZE 8
#include <pic18_usb.h>
#include <usb_desc_mouse.h>
#include <usb.c>
#define LED1 PIN_B7
#define LED2 PIN_B6
#define LED_ON output_high
usb_init_cs();
LED_ON(LED2);
while (TRUE) {
 usb_task();
 if (usb_enumerated())
      LED_ON(LED1);
and the Dns FILE
http://img546.imageshack.us/img546/5274/sanstitrejp.jpg
PostPosted: Tue Apr 10, 2012 12:11 pm     Reply with quote
What is the crystal frequency on your hardware board ?
PostPosted: Tue Apr 10, 2012 12:50 pm     Reply with quote
Assuming it is 20MHz, then with the fuses posted, the CPU will be running at 48MHz, not 20MHz, so this might well cause problems....
maissa
PostPosted: Tue Apr 10, 2012 4:08 pm     Reply with quote
Yes It s 20Mhz, but i ditn't understand, what do you mean "with the fuses posted, the CPU will be running at 48MHz and not 20MHz"
PostPosted: Tue Apr 10, 2012 4:15 pm     Reply with quote
Read the explanations in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=44817
And also here:
http://www.ccsinfo.com/forum/viewtopic.php?t=40078
maissa
PostPosted: Tue Apr 10, 2012 4:18 pm     Reply with quote
ok, thank you
PostPosted: Wed Apr 11, 2012 2:09 am     Reply with quote
Other things possibly wrong in the circuit:
Vusb, does _not_ want a resistor to D- on it. This may well cause problems. This pin is the _output_ of the internal voltage regulator, and you can use your own resistors, to signal to the USB master what type of device you have, _or_ use the internal ones. The standard code has the internal resistors enabled. Note 2, Fig 17-1 in the data sheet:
"The internal pull-up resistors should be disabled (UPUEN = 0) if external pull-up resistors are used.".
There is a further problem, that a pull up on D-, would signal a low speed device, and your code is setup to use full speed, so the device will not enumerate.
On the same pin, you show an electrolytic capacitor, and with the picture (difficult to see), it looks as if it is 470uF. If so, this is _too large_. Recommended capacitor is 200nF to 1uF. Preferably something like a polyester capacitor, not an electrolytic (the latter do not have the high frequency performance required).
Then you show the USB 5v, connected to Vcc , but do not show any decoupling components on this anywhere. You _need_ a small capacitor (perhaps 0.1uF ceramic), _immediately_ adjacent to the PIC, and something slightly larger on the rail (perhaps 4.7uF).
