ratheeshbr
| Interfacing RTC and GSM |
Posted: Tue Apr 03, 2012 12:13 am |
hi, I am tying to interface RTC DS1307 and GSM modem to control electrical devices. Both are working independently but not when integrated.
Here is my code.
#include <16F877A.h>
#define max 65534
#device *=16
#device adc=10
#include"pic.h"
#include"lcd1.h"
#include<string.h>
#use i2c(Master,Slow,sda=PIN_C4,scl=PIN_C3)
#include "ds1307.c"
#define h_sw rc0
#define m_sw rc1
#define s_sw rc2
#define set_sw
#define pir rd3
#define ir rd2
char num[15];
char msg[25];
char no3[12]="xxxxx";
char noofc[12]="xxxx";
int hon=0,mon=0,s,l;
int sethron();
int setmnon();
int sethrof();
int setmnof();
void mode100();
void mode0();
void mode50();
int hof=0,mof=0;
int setflg=0;
int lflg=0;
char ctr1[]="**D1ON";
char ctr2[]="**D2ON";
char ctr3[]="**D1OF";
char ctr4[]="**D2OF";
msg_read(char *num,char *msg)
char ch;
int i,j,m;
int1 flg=0;
unsigned long time;
while(kbhit())
ch=getch();
if(ch=='"')
while(ch!= '1') ///Loop to reach to No
if(kbhit())
ch=getch();
time=0;
time++;
if(time > max)
return(0);
//Extracting NO
for(j=0;j<=12;)
if(kbhit())
num[j]=getch();
j++;
num[j]='\0';
// prints(num);
//Extacting Message
j=0;
if(kbhit())
ch=getch();
if(ch==10)
flg=1;
time=0;
if(flg)
if(j>0)
if(ch==10)
{ j-=2;
msg[j]='\0';
go(64);
//prints(msg);
return(1);
msg[j-1]=ch;
j++;
}//kbhit
sms_cntrl()
msg_read(num,msg);
if(msg_read(num,msg)==1)
if(!strcmp(ctr1,msg))
//mode50();
delay_ms(800);
clrscr();
// sms1_on();
lflg=1;
else if(!strcmp(ctr3,msg))
// mode0();
delay_ms(800);
clrscr();
// sms1_of();
lflg=0;
delay_ms(1300);
clrscr();
// sms2_wrong();
void sms_start(char*ch)
printf("AT+CMGS=");
printf("\"%s\"\r",ch);
void sms_send(void)
putchar(26);
delay_ms(200);
void sms1_on()
sms_start(num);
printf("Device1 is ON");
sms_send();
void sms2_on()
sms_start(num);
printf("Device2 is ON");
sms_send();
void sms2_wrong()
sms_start(num);
printf("Wrong Format,Try **D_ON/OFF");
sms_send();
void sms2_me()
sms_start(no3);
printf("PAACET PJT IS ON");
sms_send();
void sms2_ofc()
sms_start(noofc);
printf("Street Light fault");
sms_send();
void sms1_of()
sms_start(num);
printf("Device1 is OFF");
sms_send();
void sms2_of()
sms_start(num);
printf("Device2 is OFF");
sms_send();
float ldr()
set_adc_channel(0);
delay_us(20);
return(read_adc());
byte sec;
byte min;
byte hrs;
byte day;
byte month;
byte year;
byte dow;
char col[]=":";
int m=35;
int msgflg=1;
trisb=0x00;
trisc0=trisc1=trisc2=trisd0=1;
trisd4=trisd5=trisd6=trisd7=0;
trisd2=trisd3=1;
enable_interrupts(INT_RDA);
enable_interrupts(global);
lcdinit();
go(4);
printc("xxxxx");
go(64);
printc("xxxxxxxxx");
clrscr();
mode0();
sms2_me();
setup_adc_ports(ALL_ANALOG);
//initialize 1307
//ds1307_init();
//ds1307_set_date_time(26,3,12,3,4,56,55); //day, month,year,dow,hr,min.sec
lflg=0;
if(kbhit())
sms_cntrl();
mode50();
sms_cntrl();
if(lflg)
if(ldr()>700)
if(msgflg)
sms2_ofc();
msgflg=0;
ds1307_get_date(day,month,year,dow);
ds1307_get_time(hrs,min,sec);
sms_cntrl();
go(0);
print(hrs);prints(col);print(min);prints(col);print(sec);
go(76);
print(ldr());
if(ir||pir)
if(ir)
mode100();
delay_ms(2000);
if(setflg)
go(64);
print(hon);prints(col);print(mon);printc(" ");
print(hof);prints(col);print(mof);printc(" ");
clrscr();
if(rd0)
printc("Press to set Time");
sethron();
setmnon();
sethrof();
setmnof();
setflg=1;
if(hon==hrs&&mon==min)
mode50();
hon=mon=0;
setflg=0;
lflg=1;
if(pir||ir)
mode100();
mode50();
if(hof==hrs&&mof==min)
mode0();
lflg=0;
hof=mof=0;
setflg=0;
int sethron()
{ do
clrscr();
printc(" Set ON HR");
if(rc0)
hon=hon+1;
go(64);
print(hon);
delay_ms(300);
if(hon==24)
hon=0;
else if(rc1)
hon=hon-1;
go(64);
print(hon);
delay_ms(300);
if(hon==-1)
hon=23;
while(!rd0);
return(hon);
int setmnon()
do
clrscr();
printc(" Set ON min");
if(rc0)
mon=mon+1;
go(64);
print(mon);
delay_ms(200);
if(mon==60)
mon=0;
else if(rc1)
mon=mon-1;
go(64);
print(mon);
delay_ms(200);
if(mon==-1)
mon=59;
while(!rd0);
return(mon);
int sethrof()
{ do
clrscr();
printc(" Set OFF HR");
if(rc0)
hof=hof+1;
go(64);
print(hof);
delay_ms(200);
if(hof==24)
hof=0;
else if(rc1)
hof=hof-1;
go(64);
print(hof);
delay_ms(200);
if(hof==-1)
hof=23;
while(!rd0);
return(hof);
int setmnof()
do
clrscr();
printc(" Set OFF mn");
if(rc0)
mof=mof+1;
go(64);
print(mof);
delay_ms(200);
if(mof==60)
mof=0;
else if(rc1)
mof=mof-1;
go(64);
print(mof);
delay_ms(200);
if(mof==-1)
mof=59;
while(!rd0);
return(mof);
void mode50()
rd4=1;rd5=rd6=rd7=0;
go(12);
printc("m50");
void mode0()
rd4=rd5=rd6=rd7=1;
go(12);
printc("m0");
void mode100()
rd4=rd5=rd6=0;
rd7=1;
go(12);
printc("m100");
I am using the compiler CCS 3.36
Anyone please check these? |
Gabriel
Posted: Tue Apr 03, 2012 8:51 am |
so, what is your problem exactly?
expected results?
symptoms?
G. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
ratheeshbr
Posted: Tue Apr 03, 2012 5:55 pm |
Both RTC and GSM works independently.
But GSM is not working, means messages are not received by the controller. I tried to use interrupt but, not enough space. |
Posted: Wed Apr 04, 2012 5:47 am |
couple of comments...
1) whenever you use the hardware UART, be sure to add 'errors' to the uses rs232(....) code !
2) NEVER enable any interrupt without having an ISR for it ! You enable INT_RDA but I can't se the 'handler' ( ISR) for it. Program will crash...
3) your timesetting code is very similar,so codespace could be saved by creating a common function and calling it instead of all the inline code you have.
4) you've coded the ldf() function to return a float,but the ADC will only return a 10bit integer.
5) go(xx) means what ???? either I can't see it or it's missing ? |
