Problem when using Timer0 Interrupt in RDA interrupt !!!
tienchuan
PostPosted: Fri Mar 30, 2012 6:08 am     Reply with quote
Hi every one.
My problems is using timer0 interrupt inside RDA interrupt, my code is recieve character from rs-232 (in RDA interrupt programe) to check condition, if condition is true, jump to timer 0 interrupt to perform.
Here is my code :
#int_rda
void ngat_gprs(void)
   char c1;
   c1=fgetc(ID1);
   switch (c1)
      case 10:    {
                     indexx=0;
      case 13:    {
                     chk_gprs=0;
                     check_connect();
      default:    {
                     connect_buffer[indexx]=c1;
                     indexx++;
void check_connect(void)
   if (     (connect_buffer[0]=='C')&&(connect_buffer[1]=='O')&&(connect_buffer[2]=='N')
         && (connect_buffer[3]=='N')&&(connect_buffer[4]=='E')&&(connect_buffer[5]=='C')
         && (connect_buffer[6]=='T')&&(connect_buffer[8]=='O')&&(connect_buffer[9]=='K'))
            chk_gprs=1;
            indexx=0;
   else {};
#int_timer1
void update_check(void)
      if (chk_gprs==1)
                   fprintf(ID1,"AT+CIPSEND=%d\r\n",length_gps);
                   fprintf(ID1,"%s \n",gps_str);
void init_gprs(void)
   fputs("AT+CIPSHUT\n",ID1);
   fputs("AT+CIPSTART=\"TCP\",\"113.165.52.122\",\"2020\"\n",ID1);
   TRISA=0;
   TRISB=0;
   TRISJ=0;
   TRISE=0;
   TRISD=0;
   TRISH=0;
   TRISG=0X04; //rs232
   TRISC=0X80; //rs232
   PORTJ=0;
   PORTE=0;
   PORTD=0;
   setup_timer_1(RTCC_INTERNAL|RTCC_DIV_1|RTCC_8_BIT);
   set_timer1(0);
   enable_interrupts(int_rda2);
   enable_interrupts(int_rda);
   enable_interrupts(int_timer1);
   enable_interrupts(global);
   lcd_gotoxy(3,1);
   printf(lcd_putc,"GPS Tracking");
   lcd_gotoxy(3,2);
   printf(lcd_putc,"HAC Solutions ");
   delay_ms(3000);
   LCD_MoveLeft(20);
   lcd_putc("\f");
while (1)
        init_gprs();
when i send character from Hyper Terminal to Pic, ("CONNECT OK"), but program not jump to update_check programe(int_timer0) to do.
Please show errors in my code.
thnks+regards.
Begin Begin Begin !!!
jeremiah
PostPosted: Fri Mar 30, 2012 6:47 am     Reply with quote
You use both delays and print statements in your ISR. Aside from being pretty bad form, I wonder if the compiler is disabling interrupts in your main when you call those same functions. If it is, it is possibly your INT_RDA isr is missing data.
Have you verified that the PIC got the entire CONNECT string?
Also, you enable interrupts for RDA2, but don't have an ISR...not a good idea usually.
Bill Havins
PostPosted: Fri Mar 30, 2012 6:49 am     Reply with quote
Which PIC are you using?
tienchuan
PostPosted: Fri Mar 30, 2012 11:53 am     Reply with quote
Hi Jeremiah !
Thanks for your reply.
Main purpose of my code is using timer 0 interrupt to always check conditon (in check_connect program ) and have must send data through rs232 (I used printf () command).
Oh, You tested with "CONNECT OK" and will be test with "CONNECT" soon Smile
Thank you Smile
tienchuan
PostPosted: Fri Mar 30, 2012 11:54 am     Reply with quote
Hi Bill Havins.
I used Pic 18F97J60 (2 uart port).
Thanks.
PostPosted: Fri Mar 30, 2012 9:13 pm     Reply with quote
never use a printf in an interrupt
that is a code wrecker
iporboon
PostPosted: Fri Mar 30, 2012 10:57 pm     Reply with quote
Did you check that RDA interrupt worked correctly and chk_gprs=1 when you sent the desired string? Maybe use LED toggle.
Did you check that TIMER1 periodic interrupt worked correctly?
And you should clear the chk_gprs flag in the update_check function , not in the ngat_gprs function.
printf should not be the problem if you did not use TBE interrupt enable.
yamenn
PostPosted: Sat Jun 14, 2014 7:52 am     Reply with quote
I have the same problem.
I am trying to get GPS DATA using RDA interrupt and using Timer0 interrupt for alarm.
I can't use the both interrupts in the same time.
Any ideas ? Wink
yamenn
PostPosted: Sat Jun 14, 2014 7:57 am     Reply with quote
#include <18f452.h>
#FUSES HS
#FUSES NOPROTECT //Code protected from reading
//#FUSES NOMCLR //Master Clear pin used for I/O
#use delay(clock=20M)
#use rs232(baud=4800, xmit=PIN_C6,rcv=PIN_C7)
#include <lcd11.c>
#include <stdlib.h>
#int_RDA
void  RDA_isr(void)
int i;
let=getch();
if (let=='$')
   letter[0]=getch();
   letter[1]=getch();
   letter[2]=getch();
   letter[3]=getch();
   letter[4]=getch();
   if (letter[0]=='G'&&letter[1]=='P'&&letter[2]=='V'&&letter[3]=='T'&&letter[4]=='G')
   gets(speed);
   if (letter[0]=='G'&&letter[1]=='P'&&letter[2]=='Z'&&letter[3]=='D'&&letter[4]=='A')
   gets(time);
   //for (i=1;i<=6;i++)
   //ck [i-1]=time[i];
   day  [0]=time[12];
   day  [1]=time[13];
   mun [0]=time[15];
   mun [1]=time[16];
   year[0]=time[18];
   year[1]=time[19];
   year[2]=time[20];
   year[3]=time[21];
   if (letter[0]=='G'&&letter[1]=='P'&&letter[2]=='G'&&letter[3]=='G'&&letter[4]=='A')
      gets(letter1);
      //for (i=0;i<=6;i++)
      //ck[i]=letter1[i];
      for (i=12;i<=22;i++)
            L1[i-12]=letter1[i];
      L3=letter1[24];
      for (i=26;i<=37;i++)
         L4[i-26]=letter1[i];
      L5=letter1[39];
#int_timer0
timer0_isr()
   set_timer0(255);
   lcd_putc('\f');
   lcd_putc("Hello");
   delay_ms(2000);
int i;
   setup_timer_0(RTCC_EXT_L_TO_H|RTCC_DIV_1);
   delay_ms(150);
   set_timer0(255);
      for (i=0;i<=15;i++)
      lcd_putc(L1[i]);
      puts(L1);
      lcd_putc('\f');
This is my test code
