Noob problem
rikotech8
Noob problem
PostPosted: Wed Mar 28, 2012 1:27 pm     Reply with quote
Hello!
How can I read the value of the given port (defined as an input) and store it in the RAM like integer value? Just like to invert parallel to serial data.
Thx in advance!
PostPosted: Wed Mar 28, 2012 2:48 pm     Reply with quote
Download the manual:
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
Look in the following sections that lists all the CCS functions:
BUILT-IN-FUNCTIONS
Anytime you have a question about an i/o port function, look in this
sub-section: DISCRETE I/O and just click on the most likely function
and read the description for it.
You want to input from a port and put the result in a variable. If I click
on the most likely looking function in the DISCRETE I/O section, if shows
examples that do exactly that.
I'm trying to make you use the manual instead of using us as the manual.
rikotech8
PostPosted: Thu Mar 29, 2012 10:57 am     Reply with quote
I was searching for this function, but none success until now. I didn't know, just where exactly to searching for. Thanks to you I find my purpose.
data=input_X()
Next time I'll look around better, before writing to the forum Embarassed Smile
PostPosted: Thu Mar 29, 2012 11:22 am     Reply with quote
if you press F11 while your project is open , the CCS Help files FULL of information, is super easy to search !!
ezflyr
PostPosted: Thu Mar 29, 2012 2:53 pm     Reply with quote
Sometimes being a 'NOOB' is more a state of mind than anything else. Instead of falling into this mindset, I'd recommend that you dig into the compiler manual, and the supplied examples - you can learn a lot from both these resources. Also, make a point to read the forum for 10 minutes every day, and in no time you'll have a huge advantage over all those that refuse to make this effort!
John
rikotech8
PostPosted: Fri Mar 30, 2012 10:47 am     Reply with quote
I will admit this advice!
