RS232 pic <--> PC
Louati
RS232 pic <--> PC
PostPosted: Mon Mar 26, 2012 11:24 am     Reply with quote
Hello Smile
I have a little problem with communication rs232, in fact when I do simulation with Proteus ISIS it's working but when I integrate the chip Max232, infomations are received but they are all false :(
Even in practice the same problem :/
I supposed that the max232 is not working so I integrated another pic and I used the Max232 to transfer informations from pic1 to pic2 and it's working !!
gpsmikey
PostPosted: Mon Mar 26, 2012 12:16 pm     Reply with quote
Have you verified the voltage levels are correct on the max232 chip ? (the correct charge pump caps are in place). How are you trying to talk to it from the PC ? Hyperterminal or just what? What does a scope (if you have one available) show on the tx and rx lines to/from the pc ? Remember that RS232 is inverted, so a "1" from the PIC should be a negative voltage on the MAX232 chip.
mikey
mikey
Louati
PostPosted: Mon Mar 26, 2012 12:28 pm     Reply with quote
mikey
For the problem of voltage it's on right, I checked that.
I use MATLAB to send informations.
I do not have an oscilloscope :/
I use an converter usb --> rs232.
Mike Walne
UART problem
PostPosted: Mon Mar 26, 2012 2:43 pm     Reply with quote
Describe the problem you are seeing.
The CCS manual suggests several tests for RS232 links.
CCS also provide example programs which can be used with a PC to verify correct operation.
Mike
PostPosted: Mon Mar 26, 2012 3:59 pm     Reply with quote
You should also do a loopback test of your 'USB<-> RS-232' convertor. Not all actually work ! I have 2 new ones here both fail miserably.
Useless Serial Bus....sigh, bring back REAL comports!
bkamen
PostPosted: Mon Mar 26, 2012 5:14 pm     Reply with quote
No kidding.
I've tried plugging in multiple vendors' worth of USB->RS232 into a single computer...
yea... welcome to unhappy driver-land.
(shaking head)
-ben
Louati
PostPosted: Tue Mar 27, 2012 10:50 am     Reply with quote
Actually it just a problem of inverting input and output Smile
It's on right now Smile Thanks for help Smile
