Web service calling from 18f67j60 microcontroller to Server
Posted: Thu Mar 22, 2012 9:53 pm
I need to send data to external server from microcontroller. I'm using pic 18F67J60 controller. I need to send data from microcontroller to external server through web service. Please help me by giving sample code.
dpechman
Posted: Fri Mar 23, 2012 7:22 am
Basically you can use http client to put and retrieving data from the webservice.
You can check for lots of samples at microchip TCP/IP stack or with the CCS TCP/IP stack that is a port from microchip code
There are several ways to do what you want and I strongly suggest you to read AN 833 and then try the samples.
bkamen
Joined: 07 Jan 2004 Posts: 1616 Location: Central Illinois, USA
Posted: Fri Mar 23, 2012 11:06 am
Download Microchip's FREE application library.
It has ALL the sample code you need.
-Ben _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D
