GLCD Image
exodia505
GLCD Image
PostPosted: Fri Mar 16, 2012 5:11 am     Reply with quote
Hello evrybody!!
i want to display a Bmp image using pic18f452 and GLCD(128x64) (ks0108 controller),i didn't find a software that convert Bmp to hex
So i tried a one that convert to decimal, i used a method already found it in this forum topics
But i got nothing just random display.
how to make this works
const int 8 image [64][16]={
255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
 255,255,255,255,255,255,255,127,127,127, 63, 63, 63, 31, 31, 31,
  15, 47, 47, 47, 39, 23,135,135,135,131,  3,  3,  3,  3,  3,  1,
   1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  0,  0,  0,  0,  0,  0,
   0,  1,  1,  0,  0,  0,  1, 33, 33, 33, 33, 33, 97, 97, 97, 97,
  97,195,195,195,131,131,131,135,  7,  7,  7,  7, 15, 15, 15, 15,
  31, 31, 31, 63, 63, 63,127,127,127,255,255,255,255,255,255,255,
 255,255,255,255,255,255,255,255,255,127,127, 63, 31, 31, 15,  7,
   7,  3,  3,  1,  1,  0,  0,  0,  0,  0,  0,  0,  0,  0,  4,  6,
   4,  4,  6, 14, 30,159,255,255,255,255,255,254,252,252,252,244,
 164,180,148, 20, 24, 88, 80,242,242,242,240,240,240,248,240, 48,
  24,  8,  8,  0,  0,  0,  0,  0,  0,  0,  0,  0,192,192,144,128,
   0,  0,  0,  0,  1,  3,  3,  3,  7,  6,  8,  0,  0,  0,  0,  0,
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  1,  1,  3,  3,  7,
   7, 15, 31, 31, 63, 63,127,255,255,255,255,255,255,255,255,255,
 255,255,127, 31, 15,  7,  3,  1,  0,  0,  0,  0,  0,  0,  0,  0,
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,
   0,  0,  0,  0,128,134,255,255,254,252,254,255,255,255,255,255,
 255,255,127,127,255,255,255,127,125,236,230,199,199,207,191,190,
 252,252,124,124, 60, 24, 56, 56,120,120,224,224,192,192,255,255,
 127,127,238,255,255,253, 61,153,200,206, 12,  4,  4,  0,  0,  8,
  16,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,
   0,  0,  0,  0,  0,  0,  0,  0,  1,  3,  7, 15, 31,127,255,255,
  15,  1,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,
   0, 44,126,255,255,255,255,255,127,255,255,183,183,255,255,255,
 255,255,255,255,255,255,255,255,255,252,251,255,255,255,255,255,
 255,255,254,254,254,254,240,224,240,252,248,240,224,240,241,243,
 249,249,249,159, 15, 23,  7,  7,  1,  0,  0,  0,  0,  0,  0,  0,
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  1,  7,
 224,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,
   0,  0,  0,  0,  0,  7,  3,  3,  3, 15, 31, 63, 63,127,255,255,
 255,255,255,255,255,255,255,255,255,255,191, 63, 31, 31, 31, 31,
  31, 31, 31, 31, 31, 31, 15, 15, 13, 15, 15, 15, 15, 15, 31, 55,
   3,  3,  1,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,192,
 255,255,252,248,224,192,128,  0,  0,  0,  0,  0,  0,  0,  0,  0,
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  1,
   1, 15, 15, 31, 31, 31, 31, 63, 63, 63, 57, 48, 32, 32,  0,  0,
   0, 64, 64, 96,224,240,112,176,136,128,128,128,128,128,  0,  0,
   0,  0,  0,  0,  0,  0,128,128,128,128,128,128,  0,  0,  0,128,
 128,128,  0,  0,  0,  0,  0,  0,  0,128,192,224,240,252,255,255,
 255,255,255,255,255,255,255,255,254,252,252,248,240,240,224,192,
 192,128,128,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,
   0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  3,  0,  0,
   0,  0,  0,  0,128,192,192,236,252,252,254,254,255,254,254,255,
 255,255,255,255,255,255,255,255,255,255,127,127, 63,191,159,223,
 205,236,246,242,249,253,252,254,255,255,255,255,255,255,255,255,
 255,255,255,255,255,254,254,254,252,252,248,248,248,240,240,240,
 240,224,224,224,192,192,192,192,192,128,128,128,128,128,128,128,
   0,128,128,131,131,135,135,199,199,199,199,199,239,239,239,247,
 247,247,243,251,251,249,253,253,254,254,254,255,255,255,255,255,
//display function is :
void glcd_image()
char i,j;
signed char k;
for( i = 0 ; i < 64 ; i ++ )
for( j = 0 ; j < 16 ; j ++)
for(k=7;k>-1;--k)
if( bit_test(image[i][j] ,7-k ))
glcd_pixel( j*8+k,i, ON );
glcd_image();
is it obligatory to convert to hex ???
NOway!!
PostPosted: Fri Mar 16, 2012 6:06 am     Reply with quote
Do yourself a BIG favour !!
in your program...
Insert code to printout the variables i,j,7-k, etc.... ALL of them
saving to a file on a PC terminal program.
Then compare what IS being send to the GLCD as data to what you WANT to be sent there!
Also I woudln't be using signed variables for simple counters ( k ) , not needed. CCS C is smart, you just need to recode the for(....) loop.
exodia505
PostPosted: Fri Mar 16, 2012 1:36 pm     Reply with quote
I tried the function with another picture (hex) not mine and it worked
pretty good so, i think problem is in image matrix.
How to convert it to [64][16] hex ?
NOway!!
exodia505
PostPosted: Sat Mar 17, 2012 1:54 pm     Reply with quote
I always fix my problems alone.
!!! hehe it works.
NOway!!
