output_x(n) question
KamPutty
PostPosted: Wed Jan 04, 2006 10:16 pm     Reply with quote
Hi all,
In the output_high/low method, how do I pass a variable instead of a constant? I want to make lets say pin D0 ~ D7 high or low etc., and I do not want to hardcode the pin but would rather use a variable.
The pins will not all be high or low, but a mixed.
I'm multiplexing my 8 7-seg led, and would like to not have constants but a formula etc...
Any thoughts?...
~Kam (^8*
PostPosted: Wed Jan 04, 2006 10:23 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=25501&highlight=dopinio
nailuy
PostPosted: Sun Mar 11, 2012 11:07 am     Reply with quote
Why is so hard to put an example.
I try to read/understand and nothing.
My code is:
int8 A=0;
set_adc_channel(0);
delay_us(10);
A=read_adc();
OUTPUT_D=(A);
I want to put in channel D digital value read on ADC ch 0.
can someone put example code like:
OUTPUT_D=A; //of course this is not working.
regards
SherpaDoug
PostPosted: Sun Mar 11, 2012 11:14 am     Reply with quote
The problem is that the compiler fundamentally does not allow this. It expects to know the pin number at compile time. You have to use some sort of trick to get what you want. The simplest is a select/case statement, but there are other ways people have devised to do this too.
dyeatman
PostPosted: Sun Mar 11, 2012 11:33 am     Reply with quote
It would help for you to read the manual. If I understand what you
are trying to do, the following will simply take the value you get from
the ADC and output the value on the D port pins as individual bits (to
light 8 LEDs connected to Port D for example).
nt8 A=0;
set_adc_channel(0);
delay_us(10);
A=read_adc();
OUTPUT_D(A);
If you want to send the bits serially that's a bit different but can be
done pretty easily.
Google and Forum Search are some of your best tools!!!!
Mike Walne
Output to PIN(x)
PostPosted: Sun Mar 11, 2012 12:29 pm     Reply with quote
To manipulate PIN(x) of PORT_Y:
(1) Create int8 variables which you use as a mask, and copy_of_y.
(2) Make the mask either ALL 1's and a 0 in bit x, or ALL 0's and a 1 in bit x.
(3) Read the current state of PORT_Y into copy_of_y.
(4) Either AND or OR copy_of_y with the mask into copy_of_y.
(5) Write copy_of_y to PORT_Y.
Choose options in (2) and (4) depending on whether your trying to set or clear the bit.
When you get really clever you can do all of the above as a single 'C' construct without the intermediate variables.
Mike
nailuy
PostPosted: Sun Jul 01, 2012 2:06 am     Reply with quote
Look at this example:
int port_b_image;
if(bit_test(port_b_image,i))        // and set pin as needed
            bit_clear(port_b_image,i);
            bit_set(port_b_image,i);
output_b(port_b_image);
why this is work?
Is a piece from "ex_patg.c"
I use the same instruction to work my code, but is not working.
Regrds
Mike Walne
PostPosted: Sun Jul 01, 2012 3:24 am     Reply with quote
int port_b_image;
why this is work?
Regrds
You're confusing me.
What is/isn't working?
What is/isn't happening that should/shouldn't?
Which PIC / compiler version etc. are you using?
Mike
PostPosted: Sun Jul 01, 2012 3:26 am     Reply with quote
Two parts:
1) Age of compiler.
Using a variable to access a port _pin_, is supported in the V4 compilers, but not in the V3 compilers. The original question you have attached this to, was posted before the V4 compilers.
The 'do_pin_io' function in the thread pointed to by PCM_programmer adds this ability for 16 PIC's, and the V3 compilers. It can be modified to suit 18 PIC's, by simply changing the addresses used.
To output an entire _byte_, the compilers have always supported this, and that is just a matter of getting the syntax right:
OUTPUT_D=(A); //No
output_d(a);
//Functions in C, expect to receive the variables they work on in brackets
//after the function name. Not using an equals sign (this is how you pass
//values to _variables_.
nailuy
PostPosted: Sun Jul 01, 2012 4:25 am     Reply with quote
Yes Ttelmah this was the problem...
OUTPUT_D(A); //is working
OUTPUT_D=(A); //is not good
dyeatman was first showed, but my eye's don't see the difference.
Thank you again guys.
Best regards.
PostPosted: Sun Jul 01, 2012 9:23 am     Reply with quote
What I found funny/confusing, is you used the correct syntax, in the title for the thread!. Very Happy
Going mad occasionally is essential when working with computers.
