I have a pcb with ICSP output. Pin 53(Rbias) is connected to Vss throught 2.2k resistor. But in this case it cause a voltage drop to the programmer Vdd to 1.7V and it`s not enough for programming. Is my chip burned or this is normal???
asmallri
Joined: 12 Aug 2004 Posts: 1678 Location: Perth, Australia
Posted: Sat Mar 10, 2012 9:34 am
Sound like you have a home made PCB with a wiring fault. _________________ Regards, Andrew
