Moved computers and don't get MPLAB to compile anymore
cerr
PostPosted: Fri Mar 09, 2012 12:09 pm     Reply with quote
I moved PCs and I don't get CCS to compile anymore for me.
Following code:
#include <PIC18F86K22.h>
Returns these build messages:
Executing: "C:\Program Files (x86)\PICC\Ccsc.exe" +FH "main.c" #__DEBUG=1 +ICD +DF +LN +T +A +M +Z +Y=9 +EA  #__18F86K22=TRUE
*** Error 18 "main.c" Line 1(9,24): File can not be opened
    Not in project "C:\Users\ron\Desktop\test\PIC18F86K22.h"
*** Error 128 "main.c" Line 3(1,16): A #DEVICE required before this line
      2 Errors,  0 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Fri Mar 09 10:01:27 2012
How can I get my compuiler back up and running like it's supposed to be(opening "<>-includes " from my "C:\Program Files (x86)\PICC\Devices" directory)?
I also tried to add the header manually to my test project but that didn't do it either...
Thank you!!!
Ron
PostPosted: Fri Mar 09, 2012 12:21 pm     Reply with quote
I'd guess you copied the project/compiler across, rather than:
1) making a new project.
2) re-installing.
You need to do both. The install sets up the path to the compiler directories, and when you make a project it includes these paths, so you then need to make a new project which will inherit these settings.
PostPosted: Fri Mar 09, 2012 12:22 pm     Reply with quote
That's not how CCS header files are named. Are you possibly trying
to compile C18 code with the CCS compiler ? That won't work. They
are not compatible.
cerr
PostPosted: Fri Mar 09, 2012 12:49 pm     Reply with quote
Yep, created a new project and also called CCS up and they'll send me an installable compiler version over. Smile
Hoops, of course i had 18F86K22.h in my code, just mistypped it...that however isn't the reason why it doesn't compile.
PostPosted: Fri Mar 09, 2012 1:18 pm     Reply with quote
Right, but it shows you like to take shortcuts and not check things.
You gotta do everything precisely. Even then, things will still fail
from time to time.
jeremiah
PostPosted: Fri Mar 09, 2012 2:12 pm     Reply with quote
What I had to do in MPLAB when that happened to me was go into the project settings and go to the section for the CCS compiler. There is an option to add include directories. I added both the devices and drivers folders to that, and it worked. Lately it seems like MPLAB can't do it automatically anymore like it used to.
