Keypad problem
KONAMI
View user's profile Send private message Send e-mail Yahoo Messenger
Keypad problem
PostPosted: Mon Jul 25, 2011 2:57 pm     Reply with quote
Hi all the CCS programmer. I have a problem and i know that here some people can help me. I'm using 4x3 keypad. I still can only read one value. And I want to read many character from the keypad like some 8 character username and password. Please if some people know how to do post it here it will help all the community.
PostPosted: Tue Jul 26, 2011 4:01 pm     Reply with quote
Here's a demo program that shows how to get an 8-digit ASCII password
from a 4x3 keypad and display it on an LCD.
When you run the program, it will display this on the LCD:
Enter Password:
Then you type in a password and press the '#' key, and it
might look like:
Enter Password:
12345678
Then it displays the password that you entered:
Password is:
12345678
Here's the main program:
#include <16F877.H>
#fuses HS, NOWDT, BROWNOUT, PUT, NOLVP
#use delay(clock = 20M)
#include "flex_lcd.c"
#include "flex_kbd.c"
#include "kbd_buffer.c"
#define MAX_PASSWORD_SIZE  8
int8 password_array[MAX_PASSWORD_SIZE +1];
lcd_init();
kbd_init();
kbd_buffer_init();
   lcd_putc("\fEnter Password:\n");
   // Get the password from keypad input by the user.  The password
   // can be from 1 to 8 digits.
   // The user must press '#' key to exit the password entry screen.
   // The user can press '*' key to backspace over chars.
   kbd_get_string(password_array, MAX_PASSWORD_SIZE);
   // Display the password that we just got.
   lcd_putc("\fPassword is:\n");
   printf(lcd_putc, "%s", password_array);
   delay_ms(3000);
flex_lcd.c is from here:
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
flex_kbd.c is from here:
http://www.ccsinfo.com/forum/viewtopic.php?t=26333
Note: You need to edit the flex_kbd.c driver as follows:
Edit the #define statement for the debounce factor, and change it 0.
It was set to 33, but that's for a software-loop polled keypad. The
example code in this post uses a 10ms timer interrupt, so disable
the software-loop polling by setting it to 0 as shown below:
#define KBD_DEBOUNCE_FACTOR  0
The kbd_buffer.c file is given below:
#define BUFFER_SIZE 32
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
// The RTCC preload value calculated below will
// will give an RTCC interrupt rate of 100 Hz.
// This is intended for an oscillator of 4 to 20 MHz.
#define FOSC getenv("CLOCK")
#if(FOSC < 26000000)
  #define RTCC_PRELOAD (256 - (FOSC/4/256/100))
#else
  #error Oscillator frequency is too high:  FOSC
// Setup Timer0 to provide a 10ms tick for the keypad driver.
void kbd_buffer_init(void)
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_256 | RTCC_8_BIT);
set_rtcc(RTCC_PRELOAD);
enable_interrupts(INT_RTCC);
// The keypad is polled every 10ms in this interrupt
// routine.
#int_rtcc
void rtcc_isr(void)
int t;
int k;
set_rtcc(RTCC_PRELOAD); // Reload Timer0 for 10ms rate
k = kbd_getc();  // Check the keypad for a keypress
// If we got a keypress, put it in the circular
// buffer.
if(k != 0)
   buffer[next_in] = k;
   t=next_in;
   if(next_in==next_out)
      next_in=t;
int8 bgetc(void)
int8 c;
while(!bkbhit);
c=buffer[next_out];
return(c);
// This version of get_string() works with a keypad
// and LCD.  The max_str_size parameter is the max
// length of the actual text the user is allowed to
// enter.   Your array that holds the text must be
// at least 1 char larger than this, to allow for
// the terminator null byte (0x00) at the end of a
// string.
#define KEYPAD_ENTER '#'
#define KEYPAD_BS    '*'
void kbd_get_string(int8 *str, int8 max_str_size)
int8 len;
int8 c;
if(max_str_size == 0)
   *str = 0;
   return;
len=0;
   c=bgetc();
   if(c == KEYPAD_BS) // Was the backspace key pressed ?
      if(len>0)   // If yes, then do we have any existing text ?
         len--;
         lcd_putc('\b');
         lcd_putc(' ');
         lcd_putc('\b');
   else if(c == KEYPAD_ENTER)
      if(len < max_str_size)
         str[len++]=c;
         lcd_putc(c);
str[len]=0;
Edit:
Added note about editing flex_kbd.c to set debounce factor to 0.
yasotha
hi..need help
PostPosted: Tue Mar 06, 2012 11:26 pm     Reply with quote
I've tried the codings given above exactly but yet i encountered some errors in kbd_buffer.c
undefined identifier --lcd_putc (4errors)
undefined identifier --lcd_init (1 error)
I don't know how to show the print screen of the error... can help me? I'm doing exactly the same project.
yasotha
hi..
PostPosted: Tue Mar 06, 2012 11:36 pm     Reply with quote
I figured it out myself...
sterob
PostPosted: Sat May 26, 2012 4:32 am     Reply with quote
PCM_PROGRAMMER
Hi, I tried to adapt the example code you posted to request for a password set, store it in eeprom. Then, ask a user to enter password,store the user's input and compare with the "set password in memory", my "if" conditions return "wrong", how do I achieve this. And I also observed that, the keypad takes like 1 second before it responds to keypress (the scanning through port B) takes time, how do I hasten it up?
Here's your code that I edited:
#include <string.h>
#include "flex_KBD.c"
#define MAX_PASSWORD_SIZE  4
   int8 password_request[MAX_PASSWORD_SIZE +1];
   int8 stored,userPass;
   lcd_init();
   delay_ms(500);// for lcd initialization
   kbd_init();
   kbd_buffer_init();
   write_eeprom(8,100);
   write_eeprom(16,120);
      lcd_putc("\fSet Password:\n");
      write_eeprom(8,password_array);
      stored = read_eeprom(8);
      printf(lcd_putc, "\fstored = %s", stored);
      kbd_get_string(password_request, MAX_PASSWORD_SIZE);
      write_eeprom(16,password_request);
      userPass = read_eeprom(16);
      printf(lcd_putc, "\nuserPass = %s", userPass);
      if(stored==userPass)
      lcd_putc("\f Correct ");
      if(stored!=userPass)
      lcd_putc("\f wrong\n");
Mike Walne
PostPosted: Sat May 26, 2012 1:35 pm     Reply with quote
You've got delay_ms(1000)'s sprinkled through your code. This could account for
the keypad takes like 1 second before it responds to keypress(
How are you comparing the characters of the stored_password against the characters of the user_password?
Mike
PostPosted: Sun May 27, 2012 12:15 pm     Reply with quote
Post all the missing lines from the top of the program.
Post these lines:
1. #include for PIC
2. #fuses
3. #use delay()
Tell us if this is a real hardware project or is it a Proteus simulator project.
Also I think you have a misunderstanding of the write_eeprom() function.
It does not write an array to eeprom. It only writes one byte to eeprom.
Look in the CCS manual to see how a function should be used.
Finally, I think you have a misunderstanding of how to use the keypad
password program. You are supposed to compare the complete password
string, as typed in by the user, to the stored password string. You need
to use the strcmp() function to do this. Make sure you completely
understand what is a "string" in the C language. Also, make sure you
completely study the return values from the strcmp() function.
