curt2go
| Slow PWM with 16MHz clock.... |
Posted: Mon Mar 05, 2012 11:17 pm |
I am working on way too many projects but i am faced with another issue. I am trying to run a 80Hz PWM but I am running at 16MHz on the clock. I am using the 18F88k22 and PWM 9 to do the work. Using an internal osc for this one as well as I dont have any pins left over for another clock.
I have tried to use a timer with a little program to make one but I am also running a display that needs to refresh and the timer slows everything down too much. So let me know if you guys have some thoughts.. Thanx as always..
CCS 4.128 |
Posted: Mon Mar 05, 2012 11:24 pm |
There is no 18F88k22, and as always, post a short test program that
shows the problem. |
gpsmikey
Posted: Mon Mar 05, 2012 11:26 pm |
| PCM programmer wrote: | | There is no 18F88k22, ..... |
Ah ha !! That must be the problem ... _________________ mikey
curt2go
Posted: Tue Mar 06, 2012 11:55 am |
Thanx.. Typo... 18F87K22....
#include <18F87K22.h>
#device ICD=TRUE
#device adc=10 *=16
//#FUSES WDT128 //Watch Dog Timer uses 1:128 Postscale
#FUSES INTRC_IO //High speed Osc (> 4mhz)
#FUSES PROTECT //Code protected from reads
#FUSES NOIESO //Internal External Switch Over mode enabled
#FUSES BROWNOUT //No brownout reset
//#FUSES BORV45 //Brownout reset at 2.5V
#FUSES PUT //Power Up Timer
#FUSES DEBUG //No Debug mode for ICD
//#FUSES NOLVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
//#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES NOMCLR //Master Clear pin enabled
#FUSES BBSIZ1K //1K words Boot Block size
//#FUSES CCP2C1
//#FUSES PLLEN //enable the PLL
#use delay(clock=16000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,errors)
//#use i2c(Master,Fast,sda=PIN_D5,scl=PIN_D6)
void main(){
setup_ccp9(CCP_PWM | CCP_USE_TIMER7_AND_TIMER4);
setup_timer_4(T4_DIV_BY_16, 0xff,1);
setup_oscillator(OSC_16MHZ );
while(true){
set_pwm9_duty(200);
asmboy
Posted: Tue Mar 06, 2012 2:54 pm |
i don't see how you can get a basic PWM frequency any lower than about
1 khz at 10 bit resolution , based on a quick read of the datasheet
80 hz seems out of the question based on the frequency equations in the datasheet |
Posted: Tue Mar 06, 2012 3:12 pm |
Unlike most of the older PICs where the PWM runs only off the master oscillator, on these latter PIC's you do have the option of running the PWM, from a timer that is running another clock.
You can generate a slow hardware PWM two ways:
1) Run a separate slow oscillator.
2) Cascade - run a PWM using the master oscillator output from (say) PWM1, and feed this into the clock input of another timer (T1CKI for example).
You can then generate really nice slow PWM outputs if required.
curt2go
Posted: Tue Mar 06, 2012 3:58 pm |
But that wold be a hardware change correct ? You are saying make a pwm at X frequency and feed that from the PWM output into a clock input and then use that frequency to generate an even lower pwm frequency on another pwm. Or am I missing something. I am looking for a software solution but if there isn't one then that may be my best option. I have run out of pins the the pic though so it will be extremely tough.
Let me know if I got your thoughts right Ttelmah? Thanx TTY |
asmboy
Posted: Tue Mar 06, 2012 5:48 pm |
You got his thoughts exactly right.
The nice thing about working with PICs is how you can blend hardware and software TOGETHER to get a solution. |
