My math operators, are not working as i want
Chaud
PostPosted: Tue Mar 06, 2012 1:07 pm     Reply with quote
Double conta = 100 * 0.0512;
printf("%ld \r\n",conta);
Result expected = 5.12
Result i get = 9089
curt2go
PostPosted: Tue Mar 06, 2012 1:18 pm     Reply with quote
Try this
Float conta = 100 * 0.0512;
printf("%2.2f \r\n",conta);
SherpaDoug
PostPosted: Tue Mar 06, 2012 1:19 pm     Reply with quote
I believe you are printing it as if it was an integer. Look at the formats for printf().
Chaud
PostPosted: Tue Mar 06, 2012 1:27 pm     Reply with quote
if i change "conta" to float, it works curt2go
Isnt it supossed to work with double too?
curt2go
PostPosted: Tue Mar 06, 2012 1:41 pm     Reply with quote
Double is not used by CCS...
C Standard Type
Default Type
short
int1
char
unsigned int8
int
int8
long
int16
long long
int32
float
float32
Hope that helps..
FvM
PostPosted: Tue Mar 06, 2012 1:44 pm     Reply with quote
C-standard type specifier for double is %g not %d. It's listed as "rounded decimal" float format in the CCS C manual, however.
Double is supported in PCD.
Chaud
PostPosted: Tue Mar 06, 2012 1:59 pm     Reply with quote
Ok i get it, thanks for you help Smile
