LCD Interfacing Problem with PIC16F877A
07arunsharma
PostPosted: Mon Mar 05, 2012 9:13 pm     Reply with quote
Hello everyone i am new to CCS Compiler.
I write a simple code to to display some text on LCD.
But it not works.
Here is my CODE
#include<16f877a.h>
#include <lcd.c>
/*#define LCD_ENABLE_PIN  PIN_C0                                    ////
#define LCD_RS_PIN      PIN_C1                                    ////
#define LCD_RW_PIN      PIN_C2                                    ////
#define LCD_DATA4       PIN_D4                                    ////
#define LCD_DATA5       PIN_D5                                    ////
#define LCD_DATA6       PIN_D6                                    ////
#define LCD_DATA7       PIN_D7*/
   set_tris_d(0x00);
   set_tris_c(0x00);
    Delay_ms(100);
      lcd_gotoxy(1,1);
      Delay_ms(1000);
      lcd_putc("\fReady...\n");
after asking several forums on internet,
someone has given me a file flex_lcd.c
i write the code for that as follow:
#include<16f877a.h>
#include "flex_lcd.c"
   set_tris_d(0x00);
   set_tris_c(0x00);
    Delay_ms(100);
      lcd_gotoxy(1,1);
      Delay_ms(1000);
and changed the pin configuration for that, and my lcd program starts working,
so i want to know why the file provided with ccs pic c i.e lcd.c is not working for me...
Arun Sharma
PostPosted: Mon Mar 05, 2012 10:21 pm     Reply with quote
You need to place the pin assignment statements above the #include line
for lcd.c. Also, the #define statements must not be commented out.
Example:
#include <lcd.c>  // This line must go here
07arunsharma
PostPosted: Tue Mar 06, 2012 9:34 am     Reply with quote
Thank You very Much,
It works, i was halted at this problem from last 2 month.
today i got solution..
what is the meaning of "%f"
Thanks alot..
Arun Sharma
07arunsharma
PostPosted: Tue Mar 06, 2012 10:37 am     Reply with quote
%f is used to clear the LCD Screen,
what if i want to go to a particular line,
i use statement lcd_gotoxy(1,1);
it means 1st row and 1st columns
while
lcd_gotoxy(2,1);
second row first column not working
Can you tell me why it is so.
#include<16f877a.h>
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,parity=N,bits=8,ERRORS)
#include <lcd.c>
   set_tris_d(0x00);
   set_tris_c(0x00);
    Delay_ms(100);
      lcd_gotoxy(2,1);
      Delay_ms(1000);
      lcd_putc("\fArun Sharma");   // /f clears the display
      Delay_ms(1000);
      printf("Serial Communication\n\r");
      Delay_ms(1000);
This is not working means Arun Sharma is not displaying on Second line..
Arun Sharma
PostPosted: Tue Mar 06, 2012 11:52 am     Reply with quote
lcd_gotoxy(2,1);
Have a read of the LCD driver comments at the beginning...
(1,2) not (2,1)
07arunsharma
PostPosted: Tue Mar 06, 2012 12:30 pm     Reply with quote
I have tried all combination..
and it is not written in driver file,
//// LCD.C ////
//// Driver for common LCD modules ////
//// lcd_init() Must be called before any other function. ////
//// lcd_putc(c) Will display c on the next position of the LCD. ////
//// The following have special meaning: ////
//// \f Clear display ////
//// \n Go to start of second line ////
//// \b Move back one position ////
//// lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1) ////
//// lcd_getc(x,y) Returns character at position x,y on LCD
This is written,,
Anyways thanks for ur reply,
but still it doesn't works..
#include<16f877a.h>
#include <lcd.c>
   set_tris_d(0x00);
   set_tris_c(0x00);
    Delay_ms(100);
      lcd_gotoxy(1,2);
      Delay_ms(1000);
      Delay_ms(1000);
      Delay_ms(1000);
Not working,
Any suggestion pls
Arun Sharma
gpsmikey
PostPosted: Tue Mar 06, 2012 12:33 pm     Reply with quote
Been a while since I looked at the LCD specs (and they all vary), but I thought there had to be a delay after a "\f" (form-feed / clear display) before you sent it more text ?
mikey
mikey
PostPosted: Tue Mar 06, 2012 2:33 pm     Reply with quote
It's all handled by the lcd driver. Check the source code in the CCS
Code Library forum.
jeremiah
PostPosted: Tue Mar 06, 2012 5:28 pm     Reply with quote
I've not dealt with LCD's much, but does the clear screen in lcd_putc("\fArun Sharma") also reset the position? If so, the lcd_gotoxy(1,2) would be meaningless.
PostPosted: Tue Mar 06, 2012 5:47 pm     Reply with quote
Yes, it clears the display and puts the cursor in home position (1, 1).
