kamillas
| decrement counter in real time |
Posted: Sun Mar 04, 2012 1:28 pm |
In my program, I want the LCD displays the value of my delay_ms, as a counter decrement to zero,
example:
time of 500 ms, the display shows me
temp = 500 = 499= 498= 497=496=495=494=.........=0ms
and this account will display in real time, a counter will décémenter
| Code: | #include <16F877A.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#use delay(clock= 4000000)
#use standard_io(a)
#include <lcd_flex>
int time = 500 ;
#include <stdlib.h>
port_b_pullups(TRUE);
while (TRUE) {
output_high(PIN_A0);
delay_ms( time );
output_low(PIN_A0); |
I want to decrement time, real-time. |
asmboy
Posted: Sun Mar 04, 2012 2:03 pm |
thats what the PIC timers are for
timer 1 and timer 3 come to mind -
read how they work when driven by Fosc.....
however updating the LCD display at a 1 msec rate
may prove more of a challenge than you expect
your pic will certainly be busy enough |
Posted: Sun Mar 04, 2012 5:09 pm |
| Quote: | time of 500 ms, the display shows me
and this account will display in real time, a counter will décémenter |
You can't do this. No one can see numbers that exist for only 1 ms.
Also, the typical 16x2 lcd has a very slow optical update rate.
You probably can only update the lcd at maybe 4 times per second.
I can't test this right now, but that's what I recall from earlier experiments. |
Mike Walne
| LCD timer limits |
Posted: Sun Mar 04, 2012 5:46 pm |
What I THINK you are asking for is NOT realistic.
I understand that PCM programmer is now your LCD hero!!
You should have got the message, by now, that an LCD is a VERY VERY SLOW device:-
(1) It will NOT be able to refresh fast enough to count 10ms never mind 1ms.
(2) Even IF it could. ALL that you would SEE is a blur.
An LED matrix CAN work fast enough.
Your eyes will still NOT be able to follow the changing display.
You need to change your design brief.
I'm happy to give guidance/clues/help BUT I will NOT write code.
You COULD get an LCD to count down in 100ms steps, and your eyes MAY be able to follow it.
Is this counter/timer just a small part of a larger project? (If it is please enlighten us.)
Tell us what you REALLY want, and we MAY try to assist.
Mike |
kamillas
| for 10ms |
Posted: Mon Mar 05, 2012 5:41 am |
| PCM programmer wrote: |
and if I want, show 500ms, decrementing by 10 ms means that the LCD as I see it: time = 500 ms, after, time = 490, after, time = 480 .......... . up, time = 0, it can be done? in this case what I do. |
Joined: 01 Jul 2010 Posts: 9637 Location: Greensville,Ontario
Posted: Mon Mar 05, 2012 5:57 am |
PARTIAL CODE FRAGMENT...
i=500;
do {
your print statement goes here......;
delay_ms(10);
i=i-10;
while(i!=0); |
Posted: Mon Mar 05, 2012 6:21 am |
You still won't see it though.
The normal way to do this is to have the fast counter running, and only _write_ the data to the LCD perhaps 10* per second. Most multiplexed LCD's take something like 1/4 second to actually update anyway. Then when whatever happens that is meant to record the time, occurs, you take the full reading from the counter and write this.
If you look at digital watches with stopwatch functions, the display shows the seconds, and then when you hit the 'stop', the tenths and hundredths are displayed.
Posted: Mon Mar 05, 2012 7:39 am |
'we' all know that, but unless he does it, he'll not understad why...
some learn by doing, others read the datasheets... |
SherpaDoug
Posted: Mon Mar 05, 2012 12:56 pm |
More practical might be to count down seconds and show a "spinning baton" made of | / - \ characters to indicate fractions of a second. _________________ The search for better is endless. Instead simply find very good and get the job done. |
kamillas
| 1 S |
Posted: Mon Mar 05, 2012 3:03 pm |
| temtronic wrote: | PARTIAL CODE FRAGMENT...
i=500;
do {
delay_ms(10);
i=i-10;
while(i!=0);
For example, if I have a delay_ms(10000), and I want to display every 1000 ms (1s) is a decrement a counter to 0,
example: lcd displays: time = 10 seconds, after it appears, time = 9 seconds, until ......, time = 0 seconds, what method is used for its |
Posted: Mon Mar 05, 2012 3:47 pm |
You could try something like this...
version 2
i=10;
do {
i=i-1;
}while(i!=0);
...or a variation thereof. |
kamillas
Posted: Tue Mar 06, 2012 5:54 am |
| temtronic wrote: | You could try something like this...
version 2
i=10;
do {
i=i-1;
}while(i!=0);
Thanks temtronic |
