3 digits Digital volt meter
Goto page 1, 2, 3, 4  Next
sahu77
PostPosted: Fri Mar 02, 2012 11:45 am     Reply with quote
Whats wrong with me. This code i was found from http://coolcircuit.com/project/meter/index.html
its code as ...
/*        voltmeter For 0 volt to 300 volt link are as
          Shivendra Sahu
        16F676 Configuration
          O = Output, I = Input
                             _________
                       vdd   | 1  14 |  Vss
for 1 (0)1ST_DISPLY--> RA5   | 2  13 |  AN0 <-- Sense_Value (I)
      (O)  SEG_(G) <-- RA4   | 3  12 |  AN1 --> 3RD_DISPLY (0) for 100
               N\C    MCLR   | 4  11 |  RA2 --> 2ND_DISPLY (0) for 10
      (O)  SEG_(F) <-- RC5   | 5  10 |  RC0 --> SEG_(A) (O)
      (O)  SEG_(E) <-- RC4   | 6   9 |  RC1 --> SEG_(B) (O)
      (O)  SEG_(D) <-- RC3   | 7   8 |  RC2 --> SEG_(C) (O)
#include <16F676.h>
#device adc=10
#fuses INTRC_IO,NOWDT,PUT,NOPROTECT,BROWNOUT,NOMCLR
#use delay (clock=4000000) // 4MHz clock
#rom  0x3ff={0x3444}
#byte PORTA = 0x05
#byte PORTC = 0x07
#byte TRISA = 0x85
#byte TRISC = 0x87
#define SPORTA PORTA
#define SPORTC PORTC
#define  TICKS_BETWEEN_INTERRUPTS      5000 //5000
#define  INTERRUPT_OVERHEAD            35
#define  TMR1RESET (0xFFFF-(TICKS_BETWEEN_INTERRUPTS-INTERRUPT_OVERHEAD))
//// segment activates on LOW state of pins.
//const char SegCode[11] = {0x40,0x57,0x22,0x06,0x15,0x0C,0x08,0x56,0x00,0x04,0xFF};//for
sahu
PostPosted: Fri Mar 02, 2012 12:27 pm     Reply with quote
what's right ???
does the ADC section work right ??
does the display section work right ?
does the PIC setup section work right ??
honestly I can see 23 things 'wrong' with the code as presented...
.., or do you just want it 'working right '???
sahu77
PostPosted: Fri Mar 02, 2012 12:43 pm     Reply with quote
temtronic wrote:
what's right ???
display section not work right.
this is right
const char SegCode[11] = {0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10,0xFF};//for my vm
   //                       0    1    2    3    4    5    6    7    8    9
/* CA display (common anode) for  my vm
        A
      F|G |B                0=ON
      E|  |C                1=OFF
        D
  A  B  C  D  E  F  G             = in order
  c0 c1 c2 c3 c4 c5 A4           =   A4 c5 c4 c3 c2 c1 c0       =  HEX CODE  = DECIMAL
  0  0  0   0  0 0  1             =  1  0  0  0  0  0  0        =  0X40      = 0
  1  0  0   1  1 1  1             =  1  1  1  1  0  0  1        =  0x79      = 1
  0  0  1   0  0 1  0             =  0  1  0  0  1  0  0        =  0x24      = 2
  0  0  0   0  1 1  0             =  0  1  1  0  0  0  0        =  0x30      = 3
  1  0  0   1  1 0  0             =  0  0  1  1  0  0  1        =  0x19      = 4
  0  1  0   0  1 0  0             =  0  0  1  0  0  1  0        =  0x12      = 5
  0  1  0   0  0 0  0             =  0  0  0  0  0  1  0        =  0x02      = 6
  0  0  0   1  1 1  1             =  1  1  1  1  0  0  0        =  0x78      = 7
  0  0  0   0  0 0  0             =  0  0  0  0  0  0  0        =  0x00      = 8
  0  0  0   0  1 0  0             =  0  0  1  0  0  0  0        =  0x10      = 9
  1  1  1   1  1 1  0             =  1  1  1  1  1  1  1        =  0xFF      = - */
const char Column[3]   = {0x06,0x03,0x02};  // may be as use \\(RA1= 0x02),(RA2= 0x04),(RA5=
0x32) my vm
sahu
dyeatman
PostPosted: Fri Mar 02, 2012 1:24 pm     Reply with quote
OK, so what does it do/not do?\
- the characters display wrong? If so, which ones? How are they wrong?
- None of the digits work?
- Parts of the digits work? If so, which ones
- All of the digits work but they flicker?
- Or something else?
Google and Forum Search are some of your best tools
PostPosted: Fri Mar 02, 2012 3:05 pm     Reply with quote
basic debugging101 says to try 1 digit at a time and cycle from 0 to 9.
record the results compare to desired response.
cut code to test each segment of each display.....
these 'test' programs should have been executed and confirmed before trying a 'digital voltmeter'.
standard 'post' procedure would be to cycle each segment of each display to confirm LEDs are 100% operational..
Mike Walne
You are asking the wrong questions!
PostPosted: Fri Mar 02, 2012 4:21 pm     Reply with quote
sahu77.
You're doing it again
You are making it very difficult for us. You are making us work out what your problem is.
Please try to make it easier.
Have you got real hardware in front of you?
What can you see?
What is your hardware doing that it should not do?
What do you expect your hardware to do that is missing?
Supply your compiler version and a short compilable code snippet which demonstrates your problem.
Read the CCS guidelines.
Mike
sahu77
PostPosted: Fri Jan 17, 2014 11:27 am     Reply with quote
I'm 100% suare my each display operational .
its not shown ADC value on 7 segments .
sahu
gpsmikey
PostPosted: Fri Jan 17, 2014 12:08 pm     Reply with quote
You are going to have a big problem in the real world if you don't learn to debug these kinds of issues. You need to create test routines that allow you to demonstrate the problem (or find the problem) in as simple a routine as it takes. Create a simple counter that updates every second - display the results - does it count right? Is it displaying the digits correct? You are "100% sure your display is right" --EXCEPT you are not seeing the expected results. You need to find why the results are not as expected - "I know it's right" isn't the correct answer. Verify it is working as expected. Then verify you are reading the ADC correctly, etc.
mikey
PostPosted: Fri Jan 17, 2014 12:51 pm     Reply with quote
You have to 'break' apart your program to debug.
Instead of reading the ADC 20 times, avg, etc. simply put in a 'dummy' value of say 123 and see what is displayed.
IF you get 123 on display
THEN you have an ADC section problem
ELSE you have a display problem.
IF you have an ADC problem
THEN confirm the Vin to ADC is correct
ELSE repair/rewire ADC section as required
IF you have a display problem
THEN confirm all wiring/LEDS/code is correct
ELSE repair/rewire as required OR recode as required
This is all 'basic debugging101'.
hth
jay
sahu77
PostPosted: Fri Jan 17, 2014 2:45 pm     Reply with quote
hth
jay
no no sir
problem is not this.
problem is in digit display .
like 123
its not show properly.
sahu
PostPosted: Fri Jan 17, 2014 3:29 pm     Reply with quote
OK, the display section isn't correct.
simply cut code to display 000-999 at a 1/2Hz rate and record what you get to say a spreadsheet,or just write down the results on paper.
Even doing just 0-9 should show the problem.
I can't help you further without knowing what the results are.What is needed is a chart of input vs output(ie: input a '1' , but display shows 'E', '2' shows 'C', etc.
hth
jay
Mike Walne
PostPosted: Fri Jan 17, 2014 3:31 pm     Reply with quote
sahu77 wrote:
no no sir
like 123
After nearly two years you still don't get it.
YOU have to tell us CLEARLY what's wrong, THEN we can help you.
Tell us EXACTLY what you can see on the display and what you expect, with a short complete compilable code we can all copy&paste to test.
Mike
sahu77
PostPosted: Fri Jan 17, 2014 3:32 pm     Reply with quote
hth
jay
pl give 1 exp. code.
Bcoz I'm very confused.
sahu
sahu77
PostPosted: Fri Jan 17, 2014 3:42 pm     Reply with quote
Mike Walne wrote:
sahu77 wrote:
no no sir
like 123
Mike
I wire 16f676 as
_________
vdd | 1
14 | Vss
N\C MCLR | 4 11
| RC0 --> SEG_(A) (O)
read ADC value with an0 .
sahu
Mike Walne
PostPosted: Fri Jan 17, 2014 3:50 pm     Reply with quote
Answer the question.
Mike
PS We are all really trying to help you.
Page 1 of 4
