PIC12F683 won't run stand-alone
embedder
PostPosted: Fri Feb 24, 2012 3:57 pm     Reply with quote
The program below runs fine using the CCS PIC12F683 dev board with the ICD. But when I remove #device ICD=TRUE and program either the 14-pin ICD chip or a standard 8-pin chip it doesn't run past the first 'if" statement. Same if I program a PIC separate from the dev board. I've tried changing the fuses, clock speed, etc., but no joy. Any ideas?
#include <12f683.h>
//#device ICD=TRUE
#device ADC=10
#fuses INTRC_IO, NOMCLR, NOWDT, NOPROTECT
#use fixed_io(a_outputs=PIN_A2,PIN_A4,PIN_A5)
   Pin-out
       (+3.3V) 1 - VDD            VSS - 8 (0V)
   (INDEX OUT) 2 - GP5        GP0/AN0 - 7 (INDEX IN)
    (CH A OUT) 3 - GP4/AN3    GP1/AN1 - 6 (CH A IN)
               4 - GP3        GP2/AN2 - 5
#define ADC_FS    1023
#define HYST      100
                           // PIC12F683 dev board
#define LED_GRN   PIN_A2   // pin 5 = Green LED
#define INDX_IP   0        // pin 7 = AN0
#define CH_A_IP   1        // pin 6 = AN1
#define INDX_OP   PIN_A4   // pin 3 = Red LED
#define CH_A_OP   PIN_A5   // pin 2 = Green LED
   int8 n, db;
   int16 adc_result[2];
   setup_adc_ports(sAN0|sAN1);
   output_high(INDX_OP);
   output_high(CH_A_OP);
   db=read_eeprom(0);
   if (db!=170){
      for(n=0;n<3;++n){
         output_high(LED_GRN);
         delay_ms(150);
         output_low(LED_GRN);
         delay_ms(150);
      write_eeprom(0,170);
   for(n=0;n<3;++n){
      delay_ms(150);
      delay_ms(150);
   while(1){
      set_adc_channel(INDX_IP);
      delay_ms(1);
      adc_result[INDX_IP]=read_adc();
      set_adc_channel(CH_A_IP);
      delay_ms(1);
      adc_result[CH_A_IP]=read_adc();
      if(adc_result[INDX_IP]>(ADC_FS/3)){
      else output_low(INDX_OP);
      if(adc_result[CH_A_IP]>(ADC_FS/3)){
      else output_low(CH_A_OP);
      for(n=0;n<3;++n){
         delay_ms(150);
         delay_ms(150);
PostPosted: Fri Feb 24, 2012 5:44 pm     Reply with quote
Don't know if it applies to you but...
..if using MPLAB, is the 'build configuration' set to 'debug' and not 'release'?
IF 'debug', you need to change to 'release', then recompile (F10) , then download the code....
embedder
PostPosted: Mon Feb 27, 2012 7:36 am     Reply with quote
Thanks temtronic. I don't think it applies, but I will experiment with the fuses a bit more. I feel like I am missing something obvious. Anyone?
