Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
Nokia 3310 LPH7779 rev 3 V3 Michel Bavin
Post new topic   Reply to topic    CCS Forum Index -> Code Library
treitmey
PostPosted: Tue Jan 03, 2006 9:35 am     Reply with quote
Copy and past from main forum
I'm taking no responsibility for this code.
It has no copy right text, But it shows the author.
contact author for permission.
Graphic LCD Nokia 3310 (LPH7779) routines v3
CCS compiler
by Michel Bavin 2004 --- bavin@skynet.be --- http://users.skynet.be/bk317494/ ---
august 29, 2004
// ex:
// nokia_init();
// nokia_gotoxy(0,0);
// printf(nokia_printchar,"test???");
#define nok_sclk  PIN_D4
#define nok_sda   PIN_D3
#define nok_dc    PIN_D2
#define nok_cs    PIN_D1
#define nok_res   PIN_D0
char char_row,charsel,charpos,chardata;       // for nokia_3310 lcd
int16 ddram;
char plot_value;
int32 plot_value32;
int32 plot_umsb,plot_lmsb,plot_ulsb,plot_llsb;
BYTE const TABLE5[240]=            {0x00,0x00,0x00,0x00,0x00,   // 20 space          ASCII table for NOKIA LCD: 96 rows * 5 bytes= 480 bytes
  0x00,0x00,0x5f,0x00,0x00,   // 21 !
  0x00,0x07,0x00,0x07,0x00,   // 22 "
  0x14,0x7f,0x14,0x7f,0x14,   // 23 #
  0x24,0x2a,0x7f,0x2a,0x12,   // 24 $
  0x23,0x13,0x08,0x64,0x62,   // 25 %
  0x36,0x49,0x55,0x22,0x50,   // 26 &
  0x00,0x05,0x03,0x00,0x00,   // 27 '
  0x00,0x1c,0x22,0x41,0x00,   // 28 (
  0x00,0x41,0x22,0x1c,0x00,   // 29 )
  0x14,0x08,0x3e,0x08,0x14,   // 2a *
  0x08,0x08,0x3e,0x08,0x08,   // 2b +
  0x00,0x50,0x30,0x00,0x00,   // 2c ,
  0x08,0x08,0x08,0x08,0x08,   // 2d -
  0x00,0x60,0x60,0x00,0x00,   // 2e .
  0x20,0x10,0x08,0x04,0x02,   // 2f /
  0x3e,0x51,0x49,0x45,0x3e,   // 30 0
  0x00,0x42,0x7f,0x40,0x00,   // 31 1
  0x42,0x61,0x51,0x49,0x46,   // 32 2
  0x21,0x41,0x45,0x4b,0x31,   // 33 3
  0x18,0x14,0x12,0x7f,0x10,   // 34 4
  0x27,0x45,0x45,0x45,0x39,   // 35 5
  0x3c,0x4a,0x49,0x49,0x30,   // 36 6
  0x01,0x71,0x09,0x05,0x03,   // 37 7
  0x36,0x49,0x49,0x49,0x36,   // 38 8
  0x06,0x49,0x49,0x29,0x1e,   // 39 9
  0x00,0x36,0x36,0x00,0x00,   // 3a :
  0x00,0x56,0x36,0x00,0x00,   // 3b ;
  0x08,0x14,0x22,0x41,0x00,   // 3c <
  0x14,0x14,0x14,0x14,0x14,   // 3d =
  0x00,0x41,0x22,0x14,0x08,   // 3e >
  0x02,0x01,0x51,0x09,0x06,   // 3f ?
  0x32,0x49,0x79,0x41,0x3e,   // 40 @
  0x7e,0x11,0x11,0x11,0x7e,   // 41 A
  0x7f,0x49,0x49,0x49,0x36,   // 42 B
  0x3e,0x41,0x41,0x41,0x22,   // 43 C
  0x7f,0x41,0x41,0x22,0x1c,   // 44 D
  0x7f,0x49,0x49,0x49,0x41,   // 45 E
  0x7f,0x09,0x09,0x09,0x01,   // 46 F
  0x3e,0x41,0x49,0x49,0x7a,   // 47 G
  0x7f,0x08,0x08,0x08,0x7f,   // 48 H
  0x00,0x41,0x7f,0x41,0x00,   // 49 I
  0x20,0x40,0x41,0x3f,0x01,   // 4a J
  0x7f,0x08,0x14,0x22,0x41,   // 4b K
  0x7f,0x40,0x40,0x40,0x40,   // 4c L
  0x7f,0x02,0x0c,0x02,0x7f,   // 4d M
  0x7f,0x04,0x08,0x10,0x7f,   // 4e N
  0x3e,0x41,0x41,0x41,0x3e    // 4f O
BYTE const TABLE6[240]=            {0x7f,0x09,0x09,0x09,0x06,   // 50 P
  0x3e,0x41,0x51,0x21,0x5e,   // 51 Q
  0x7f,0x09,0x19,0x29,0x46,   // 52 R
  0x46,0x49,0x49,0x49,0x31,   // 53 S
  0x01,0x01,0x7f,0x01,0x01,   // 54 T
  0x3f,0x40,0x40,0x40,0x3f,   // 55 U
  0x1f,0x20,0x40,0x20,0x1f,   // 56 V
  0x3f,0x40,0x38,0x40,0x3f,   // 57 W
  0x63,0x14,0x08,0x14,0x63,   // 58 X
  0x07,0x08,0x70,0x08,0x07,   // 59 Y
  0x61,0x51,0x49,0x45,0x43,   // 5a Z
  0x00,0x7f,0x41,0x41,0x00,   // 5b [
  0x02,0x04,0x08,0x10,0x20,   // 5c
  0x00,0x41,0x41,0x7f,0x00,   // 5d
  0x04,0x02,0x01,0x02,0x04,   // 5e
  0x40,0x40,0x40,0x40,0x40,   // 5f
  0x00,0x01,0x02,0x04,0x00,   // 60
  0x20,0x54,0x54,0x54,0x78,   // 61 a
  0x7f,0x48,0x44,0x44,0x38,   // 62 b
  0x38,0x44,0x44,0x44,0x20,   // 63 c
  0x38,0x44,0x44,0x48,0x7f,   // 64 d
  0x38,0x54,0x54,0x54,0x18,   // 65 e
  0x08,0x7e,0x09,0x01,0x02,   // 66 f
  0x0c,0x52,0x52,0x52,0x3e,   // 67 g
  0x7f,0x08,0x04,0x04,0x78,   // 68 h
  0x00,0x44,0x7d,0x40,0x00,   // 69 i
  0x20,0x40,0x44,0x3d,0x00,   // 6a j
  0x7f,0x10,0x28,0x44,0x00,   // 6b k
  0x00,0x41,0x7f,0x40,0x00,   // 6c l
  0x7c,0x04,0x18,0x04,0x78,   // 6d m
  0x7c,0x08,0x04,0x04,0x78,   // 6e n
  0x38,0x44,0x44,0x44,0x38,   // 6f o
  0x7c,0x14,0x14,0x14,0x08,   // 70 p
  0x08,0x14,0x14,0x18,0x7c,   // 71 q
  0x7c,0x08,0x04,0x04,0x08,   // 72 r
  0x48,0x54,0x54,0x54,0x20,   // 73 s
  0x04,0x3f,0x44,0x40,0x20,   // 74 t
  0x3c,0x40,0x40,0x20,0x7c,   // 75 u
  0x1c,0x20,0x40,0x20,0x1c,   // 76 v
  0x3c,0x40,0x30,0x40,0x3c,   // 77 w
  0x44,0x28,0x10,0x28,0x44,   // 78 x
  0x0c,0x50,0x50,0x50,0x3c,   // 79 y
  0x44,0x64,0x54,0x4c,0x44,   // 7a z
  0x00,0x08,0x36,0x41,0x00,   // 7b
  0x00,0x00,0x7f,0x00,0x00,   // 7c
  0x00,0x41,0x36,0x08,0x00,   // 7d
  0x10,0x08,0x08,0x10,0x08,   // 7e
  0x78,0x46,0x41,0x46,0x78    // 7f
void    nokia_init(void);
void    nokia_write_command(char bytefornokia_command);
void    nokia_write_data(char bytefornokia_data);
void    nokia_write_dorc(char bytefornokia);
void    nokia_gotoxy(int8 xnokia, int8 ynokia);
void    nokia_erase_y(int8 ynokia);
void    nokia_erase_x(int8 xnokia);
void    nokia_printchar(int8 cvar);
void    nokia_clean_ddram(void);
void    table_to_nokialcd(void);
void    nokia_plot(int8 xnokia,int8 plot_value8);
void    nokia_write_data_inv(char bytefornokia_data_inv);
void    nokia_clear_screen(void);
void    nokia_clear_xy(int8 xnokia, int8 ynokia);
void    nokia_print_uparrow(void);
void    nokia_print_downarrow(void);
void    nokia_print_leftarrow(void);
void    nokia_print_rightarrow(void);
void    nokia_print_degree(void);
void    nokia_print_lowbatdegree(void);
  output_high(nok_dc);            // bytes are stored in the display data ram, address counter, incremented automatically
  output_high(nok_cs);            // chip disabled
  output_low(nok_res);            // reset chip during 250ms
  delay_ms(10);         // works with less.....
  output_high(nok_res);
  nokia_write_command(0x21);   // set extins extended instruction set
  nokia_write_command(0xc2);   // Vop  v1: 0xc8 (for 3V)// v2: 0xa0 (for 3V) // v3: 0xc2 (2v6-5v)   ********************************************************************************************************************
  nokia_write_command(0x13);   // bias
  nokia_write_command(0x20);   // horizontal mode from left to right, X axe are incremented automatically , 0x22 for vertical addressing ,back on normal instruction set too
  nokia_write_command(0x09);   // all on
  nokia_clean_ddram();      // reset DDRAM, otherwise the lcd is blurred with random pixels
  nokia_write_command(0x08);   // mod control blank change (all off)
  nokia_write_command(0x0c);   // mod control normal change
  nokia_gotoxy(0,0);         // 84*6=504      clear LCD
  for (ddram=504;ddram>0;ddram--){nokia_write_data(0x00);}
  output_low(nok_dc);   // byte is a command it is read with the eight SCLK pulse
  output_low(nok_cs);   // chip enabled
  nokia_write_dorc(bytefornokia_command);
  nokia_write_dorc(bytefornokia_data);
void nokia_write_dorc(char bytefornokia)         // serial write data or command subroutine
  char caa;
  for (caa=8;caa>0;caa--) {
    output_low(nok_sclk);
    // delay_us(2);
    if ((bytefornokia&0x80)==0){output_low(nok_sda);}
    else {output_high(nok_sda);}
    output_high(nok_sclk);
    bytefornokia=bytefornokia<<1;
void nokia_gotoxy(int8 xnokia, int8 ynokia)      // Nokia LCD 3310 Position cursor
  nokia_write_command(0x40|(ynokia&0x07));   // Y axe initialisation: 0100 0yyy
  nokia_write_command(0x80|(xnokia&0x7f));   // X axe initialisation: 1xxx xxxx
  nokia_gotoxy(0,ynokia);
  printf(nokia_printchar,"              ");
  char column;
  for (column=0;column!=6;column++){
    nokia_gotoxy(xnokia,column);
void nokia_printchar(int8 cvar)               // Write 1 character to LCD
  charsel=cvar;
  table_to_nokialcd();
void table_to_nokialcd(void)   // extract ascii from tables & write to LCD
  if (charsel<0x20)return;
  if (charsel>0x7f)return;
  for (char_row=0;char_row<5;char_row++) {      // 5 bytes
    if (charsel<0x50){charpos=(((charsel&0xff)-0x20)*5);chardata=TABLE5[(charpos+char_row)];}            // use TABLE5
    else if (charsel>0x4f){charpos=(((charsel&0xff)-0x50)*5);chardata=TABLE6[(charpos+char_row)];}            // use TABLE6
    nokia_write_data(chardata);      // send data to nokia
  nokia_write_data(0x00);      //    1 byte (always blank)
  char i;
  plot_value32=0;
  // plot_value32|=1;         // unremark this if you want dotgraph instead of bargraph
  for (i=0;i!=plot_value8;i++){
    plot_value32|=1;         // remark this if you want dotgraph instead of bargraph
    plot_value32<<=1;
  plot_value32|=2;            // bottom line is always filled
  plot_llsb=(plot_value32&0xff);
  plot_ulsb=((plot_value32>>8)&0xff);
  plot_lmsb=((plot_value32>>16)&0xff);
  plot_umsb=((plot_value32>>24)&0xff);
  nokia_gotoxy(xnokia,1);
  nokia_write_data_inv(plot_umsb);
  nokia_gotoxy(xnokia,2);
  nokia_write_data_inv(plot_lmsb);
  nokia_gotoxy(xnokia,3);
  nokia_write_data_inv(plot_ulsb);
  nokia_gotoxy(xnokia,4);
  nokia_write_data_inv(plot_llsb);
  char caa;
    delay_us(2);
    if ((bytefornokia_data_inv&0x01)==0){output_low(nok_sda);}
    bytefornokia_data_inv=bytefornokia_data_inv>>1;
  nokia_erase_y(0);
  nokia_erase_y(1);
  nokia_erase_y(2);
  nokia_erase_y(3);
  nokia_erase_y(4);
  nokia_erase_y(5);
  nokia_gotoxy(xnokia,ynokia);
  nokia_printchar(" ");
  nokia_write_data(0x04);
  nokia_write_data(0x02);
  nokia_write_data(0x7f);
  nokia_write_data(0x10);
  nokia_write_data(0x20);
  nokia_write_data(0x08);
  nokia_write_data(0x1c);
  nokia_write_data(0x2a);
  nokia_write_data(0xf8);
  nokia_write_data(0x06);
  nokia_write_data(0x09);
  // nokia_printchar("  ");
  nokia_write_data(0x0f);
barkerben
PostPosted: Sun Feb 05, 2006 1:37 pm     Reply with quote
Can anyone confirm this code works? I'm debugging a circuit, and can't get anything upon the LCD (a 3310). The software looks fine though...
Ben
gs
PostPosted: Sun Feb 05, 2006 4:35 pm     Reply with quote
This code works, I used it in two of my projects.
I originally found it here
Works nice Smile
www.hlektronika.gr
barkerben
PostPosted: Sun Feb 05, 2006 6:41 pm     Reply with quote
Ok...I guess I must have fried the driver circuitry when I soldered my display. Does anyone know how easy this is to do...
I'll be more careful next time :-p
nebula_1979
Plot XY and scroll functions
PostPosted: Sun Jul 30, 2006 1:59 am     Reply with quote
Hi.
Does anyone implement a PlotXY, PlotLine functions or scroll functions?
Regards
joven
PostPosted: Sat May 12, 2007 3:47 pm     Reply with quote
Hi
Does anyone implement with this driver a function can give the coordinates and print a dot, any place of the LCD.
zola
solution
PostPosted: Mon Jun 11, 2007 12:46 am     Reply with quote
Use FastLCD, remember that the display have 84x48 pixel, make this change in FastLCD, after that draw a picture. Press BAS button, clic image, you whil be prompted to save the file, save it but whit .txt at end.
Open word copy paste the code, clic replace , replace &h whit 0x . In this momment you have an 504 array. You must split it in 2 tables 240 and another one smaller 24 i think.
EX:
BYTE const picture1[240]={
........ //whitout ","
BYTE const picture2[240]={
BYTE const picture3[24]={
save this file in my_picture.c . After that add in your code:
#include <c:\....\my_picture.c>
void picture_1 (void);
void picture_1(void){
nokia_clear_screen();
for(i=0;i<240;i++){
nokia_write_data(picture1[i]);
for(i=0;i<240;i++){
nokia_write_data(picture2[i]);
for(i=0;i<24;i++){
nokia_write_data(picture3[i]);
main(){
//your code
picture_1();//clear the screen and print the image!!!
Allsow you can write your picture in an 24cxxx but you must changhe the function to read from eeprom. ;)
Best Regard
Nicola Bogdan
buneri
PostPosted: Mon Oct 08, 2007 1:46 am     Reply with quote
I wanna work on Mobile Communication but i have Nokia6030
Is the above code will work for Nokia6030 and other Nokia mobile?
Plz reply!
zola
PostPosted: Tue Oct 16, 2007 1:40 pm     Reply with quote
If you have the driver, yes it works, but the driver must have the function like the driver from 3310 display(write data). If not.... try to make some test !!! All the code I wrote work 100% for 3310, If you allready have the display try it. Just take an look at the maximum number of bytes that you can send to it, and split it.... and how the image must be converted ... AND, OR....
God Luck!!!
If someone need 2 projects : an digital weight scale (alphanumerical display) and an alarm made whit nokia 3310 display just email me, is all free (Open source!!!!).
ROBOTICAR
PostPosted: Sat Nov 24, 2007 8:17 am     Reply with quote
thankyou......but how can I simulate " 3310 " in proteus.
Do you have any library about it?
Valmirez
PostPosted: Tue Mar 24, 2009 6:00 am     Reply with quote
lcd nokia 3310 model for Proteus
http://www.tanu-sha.narod.ru/nokia3310.html
works version: 6.x 7.4
dont use in 7.2
Hectorpkmn
PostPosted: Sat Jan 28, 2012 11:17 am     Reply with quote
Someone could tell me if this library have the option to print in inverse video?
Blambik
PostPosted: Wed Feb 22, 2012 3:38 am     Reply with quote
Normal Mode: nokia_write_command(0x0c); //Normal Mode
Inverse mode: nokia_write_command(0x0D); // Inverse Mode
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
