MMC card
Dasat
MMC card
PostPosted: Wed Feb 15, 2012 6:27 am     Reply with quote
I've been battling with this mmc code. I'm trying to interface it with PIC18F4520. I observed that it seems the card is not initiliazing at all, so I would like to clarify this before moving to reading and writing at all. Pls help me view the code and make any suggestions. Thanks.
I'm using the inbuilt mmc_spi.c.
#include <nokia3310driver.c>
#use delay (clock=20000000)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
#fuses HS,NOWDT,NOBROWNOUT,NOLVP
#define MMC_CS    PIN_C1
#define MMC_CLK   PIN_C3
#define MMC_DI    PIN_C4
#define MMC_DO    PIN_C5
#include <mmc_spi.c>
int i,display;
signed int16 ad;
char dat;
int16 size;
int8 data[64];
int *ptr;//pointer to array
int32 adres;
adres = &data[0];
size = 8;
ptr = data;
SETUP_SPI(SPI_MASTER | SPI_CLK_DIV_64 | SPI_L_TO_H |SPI_XMIT_L_TO_H );
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1 ( T1_DISABLED | T1_DIV_BY_8 );
setup_timer_2(T2_DIV_BY_1,199,5);
initlcd();
mmc_init();
if (mmc_init()==0)
  putlcdchar("mmc init succ");
  putlcdchar("mmc unsucces");
delay_us(100);
// put values in my array;
/*for (i=0; i<64; i++){
     data[i] = 1;
   ad =mmc_write_block(adres, size, *ptr);
   if (ad==0)
     putlcdchar("write was successful");
     putlcdchar("write was un");
   adres++;
dat = mmc_read_data();
Believe and u would see
PostPosted: Wed Feb 15, 2012 6:32 am     Reply with quote
Tell us what hardware you're using.
That's PIC, interface and mmc card specs.
Dasat
PostPosted: Wed Feb 15, 2012 10:56 am     Reply with quote
I'm still working with simulation on ISIS not yet setting it up. But the PIC is 18F4520
PostPosted: Wed Feb 15, 2012 12:51 pm     Reply with quote
You will NEVER,EVER get the ISIS ( Proteus) simulation to work..
Can't be done, it is full of bugs,errors and faulty DRCs.
Get REAL hardware...program a REAL PIC, then and only then will it work.
BTW you CANNOT get a 5 volt PIC and a 3 volt SD card to work if they are the ONLY devices you have,NEVER,EVER going to happen.
well,maybe once, then the magic smoke comes out and you've destroyed both devices....
asmallri
PostPosted: Sat Feb 18, 2012 3:55 am     Reply with quote
Funny thing, one of my customers used my file system driver with Proteus. I like you said it will never work. I had to eat humble pie because he got it working. :-)
Regards, Andrew
