Control the program of the pic
ssaakmnt
PostPosted: Tue Feb 07, 2012 4:52 am     Reply with quote
Hi everyone
Is there a way or a simple code to control the program so it makes
microcontroller work and execute instructions let say for 5 times,
and after power it up at 6th time it enter endless loop. Thank you.
ezflyr
PostPosted: Tue Feb 07, 2012 6:04 am     Reply with quote
Yes, for most 'F' PICs that is trivial. Five minutes tops!
John
SherpaDoug
PostPosted: Tue Feb 07, 2012 7:58 am     Reply with quote
Increment a counter in EEPROM each time the PIC starts. When the counter reaches 5 do the other behavior.
ssaakmnt
PostPosted: Wed Feb 08, 2012 3:25 am     Reply with quote
yeah..but if anyone can put a short example code of counter in EEPROM it would be appreciated..thanks
PostPosted: Wed Feb 08, 2012 5:18 am     Reply with quote
I can give you my bank account number. As soon as I have received your money I'll start doing your (school) work. Wink
Here on this forum we like people to learn something. Just giving you the answer means you'll be returning many times with problems you could easily solve yourself (and that are boring to us).
Try to create a program yourself. When you get stuck you can post whatever you have and we will help you to get going.
ssaakmnt
PostPosted: Thu Feb 09, 2012 12:47 am     Reply with quote
ok..I already wrote a code but I did not post it because in fact its first time with EEPROM
write_eeprom(0x00,i++);
value=read_eeprom(0x0);
if (value>5)
{output_b(0);}
{output_b(255);}
The program is supposed to increment (int i) every time we power the pic and save
the value of i after power off. When we power at 6th time pic do other behavior.
PostPosted: Thu Feb 09, 2012 2:56 am     Reply with quote
You need to read the last value from the EEPROM, before you write to the EEPROM.
You also need to ensure the EEPROM cell is set to '0' when you program the chip.
So:
#ROM int8 getenv("EEPROM_ADDRESS") = {0}
//This writes '0' into the EEPROM when the chip is programmed.
void main(void) {
   int value;
   value=read_eeprom(0); //Get the value last stored in the EEPROM
   if (value<6) write_eeprom(0,++value);
   //Increment the value in the EEPROM
  if (value>5)
     output_b(0);
     output_b(255); //Will do this five times
  //The chip will now go to sleep. This doesn't matter, since the value
  //is already output on the port, and will save power.
  sleep();
Now, a couple of things here.
First, I stop updatiing the EEPROM, once the count gets to 6. This saves EEPROM life, but also stops the code doing five more cycles after another 250 power cycles, which will otherwise happen when the int value gets to 256, and then wraps back to 0.....
Second, once the value is output on the port, the chip can just stop running. The lines will remain driven when this happens, and save power.
ssaakmnt
PostPosted: Thu Feb 09, 2012 5:08 am     Reply with quote
Thank you this helps a lot
RoGuE_StreaK
PostPosted: Thu Feb 09, 2012 5:10 am     Reply with quote
Really? Cool, didn't know that; so it essentially latches to it's last state, and doesn't need to use power (well, extra power) to keep it that way?
Learn a new thing every day in this joint!
