horse riding on 16*2 lcd with flex_lcd.c
sahu77
PostPosted: Sat Jan 28, 2012 1:59 pm     Reply with quote
Few day ago I found HI-TECH code. Its work 16*2 lcd. Its working as display on lcd like horse riding on 16*2 lcd. So I decide, I will convert on CCS C, those are as...
  Main Program
   disable_interrupts(GLOBAL);
  // Initilize RAM Variables
   //Timer1 Init
   //ADC Init
   while (TRUE)
 lcd_init();  // Always call this first.
 for(;;){
          for(ctr=0;ctr<17;ctr++){
      horse1();
      lcd_gotoxy(ctr,1);
      for(a=0;a<=3;a++) lcd_putc(a);
      lcd_gotoxy(ctr,2);
      for(a=4;a<=7;a++) lcd_putc(a);
      delay_ms(500);}
      horse2();
      lcd_gotoxy(ctr,2);
      lcd_gotoxy(ctr,1);
void horse1(void)
 int i,s,adres=64;
 const byte karakter_[8][8]=
 {(0b00000) ,(0b00000) ,(0b00000) ,(0b00000) ,(0b00000) ,(0b00111) ,(0b01111) ,(0b11110)},
 {(0b00000) ,(0b00000) ,(0b00000) ,(0b00000) ,(0b01110) ,(0b11111) ,(0b11111) ,(0b11111)},
 {(0b00000) ,(0b00000) ,(0b00000) ,(0b00000) ,(0b00111) ,(0b11111) ,(0b11111) ,(0b11111)},
 {(0b00000) ,(0b00010) ,(0b11111) ,(0b11111) ,(0b11111) ,(0b11011) ,(0b10011) ,(0b10000)},
 {(0b00000) ,(0b00000) ,(0b00000) ,(0b00000) ,(0b00001) ,(0b00001) ,(0b00001) ,(0b00000)},
 {(0b11111) ,(0b11111) ,(0b11011) ,(0b10010) ,(0b00001) ,(0b00001) ,(0b10001) ,(0b00000)},
 {(0b11111) ,(0b11111) ,(0b00001) ,(0b00001) ,(0b00001) ,(0b00001) ,(0b00000) ,(0b00000)},
 {(0b11000) ,(0b11100) ,(0b00100) ,(0b01000) ,(0b10000) ,(0b00000) ,(0b10000) ,(0b00000)},
 for(i=0;i<=7;i++)
 lcd_send_byte(0,adres);
 for(s=0;s<=7;s++) {
 lcd_send_byte(1,karakter_[i][s]);
 adres=adres+8;
void horse2(void)
 int i,s,adres=64;
 { (0b00000) ,(0b00000) ,(0b00000) ,(0b00111) ,(0b01111) ,(0b01110) ,(0b11100) ,(0b11000)},
 { (0b00000) ,(0b00000) ,(0b00000) ,(0b01111) ,(0b11111) ,(0b11111) ,(0b11111) ,(0b11111)},
 { (0b00000) ,(0b00000) ,(0b00000) ,(0b00011) ,(0b11111) ,(0b11111) ,(0b11111) ,(0b11111)},
 { (0b00000) ,(0b00001) ,(0b11111) ,(0b11111) ,(0b11111) ,(0b11011) ,(0b10011) ,(0b10000)},
 { (0b10011) ,(0b10011) ,(0b00010) ,(0b00010) ,(0b00100) ,(0b00000) ,(0b00000) ,(0b00000)},
 { (0b11111) ,(0b00111) ,(0b01110) ,(0b00110) ,(0b00001) ,(0b00000) ,(0b00000) ,(0b00000)},
 { (0b01111) ,(0b00111) ,(0b10011) ,(0b01111) ,(0b00000) ,(0b10000) ,(0b00000) ,(0b00000)},
 { (0b10000) ,(0b11000) ,(0b01100) ,(0b00100) ,(0b00010) ,(0b00001) ,(0b00000) ,(0b00000)},
 for(i=0;i<=7;i++)
 for(s=0;s<=7;s++) {
 adres=adres+8;
Original code is here:
http://shahrulnizam.com/pic-lesson-custom-character-lcd/
sahu
sahu77
PostPosted: Mon Jan 30, 2012 10:56 am     Reply with quote
    lcd_gotoxy(ctr,1);
       lcd_gotoxy(ctr,2);
       delay_ms(500);}
lcd_gotoxy(ctr,1);
Use for 1st line 1 to 4, 5*7 matrix, &&
lcd_gotoxy(ctr,2);
use for 2nd line 1 to 4, 5*7 matrix, is right ????
But display give image 1st line, 1 to 8 & then come 2nd line 1 to 4, 5*7 matrix.
pl help me .....
sahu
PostPosted: Mon Jan 30, 2012 11:38 am     Reply with quote
You don't show what LCD driver you're using or the actual LCD itself.
It could be a problem with the translation from the original program or a driver / LCD mismatch.
The link didn't work for me, so I can't comment further on the 'translation' from it and without knowing the make/model of the LCD as well as the driver info...,can't help there either.
sahu77
PostPosted: Mon Jan 30, 2012 1:22 pm     Reply with quote
I use flex_lcd.c.
If know any problem I can post here original code, but it is HI-TECH . Can I post here ?
sahu
PostPosted: Mon Jan 30, 2012 1:55 pm     Reply with quote
Well there's nothing wrong with the flex_lcd driver..
Sounds like you've got the wrong addresses for the lines on your LCD unit. You'll have to read the datasheet for your LCD to see though.
sahu77
PostPosted: Tue Jan 31, 2012 10:02 am     Reply with quote
Right now no need for datasheet for my LCD. Because right now I use Oshonsoft sim.
sahu
PostPosted: Tue Jan 31, 2012 10:37 am     Reply with quote
Gee next time you ask a question tell us all, upfront, you're using a SIMULATOR !!!
That will really help!!
sahu77
PostPosted: Tue Jan 31, 2012 11:44 am     Reply with quote
ok sorry - sorry
Oshon Soft SIMULATOR
sahu
Mike Walne
Horse image
PostPosted: Wed Feb 01, 2012 5:06 am     Reply with quote
Link worked for me. It produces these two images of a horse on LCD. I do not propose to help with translation from Hi-Tec to a simulator.
horse1
horse2
Mike
sahu77
Re: Horse image
PostPosted: Wed Feb 01, 2012 9:29 am     Reply with quote
My propose for translating it is, because I add it in rest of my code. Which is in ccs c.
sahu
Mike Walne
Simulators
PostPosted: Wed Feb 01, 2012 2:19 pm     Reply with quote
What the real experts on this forum are saying loud and clear is "SIMULATORS ARE A WASTE OF TIME". You will get more help when you use hardware. All simulators are flawed, there are enough problems to solve without getting into sorting out other issues.
Mike
