ffgt
vortexe9000
ffgt
PostPosted: Thu Jan 26, 2012 2:15 pm     Reply with quote
xd
Banned for spamming his own posts
PostPosted: Thu Jan 26, 2012 3:27 pm     Reply with quote
Vortex,
Again, please use the tools available to you, such as the forum's search
page. Do not use us as a search engine for simple questions.
Here is the forum's search page:
http://www.ccsinfo.com/forum/search.php
Search for this:
Nokia command*
Set it for: Search for all terms
This should give you many posts about Nokia AT commands.
vortexe9000
PostPosted: Thu Jan 26, 2012 4:21 pm     Reply with quote
hhg
PostPosted: Thu Jan 26, 2012 5:42 pm     Reply with quote
Post a short test program that tests the AT command with your Nokia.
Make sure to post the #include, #fuses, #use delay(), and main(), and
the short code (10 lines) in main().
vortexe9000
PostPosted: Fri Jan 27, 2012 5:20 am     Reply with quote
gg
ezflyr
PostPosted: Fri Jan 27, 2012 7:38 am     Reply with quote
I make my own RS232 communication interface with 3.3 volt VCC
I suspect you've got a circuit problem! Can you post a schematic of your circuit?
What is the supply voltage of your PIC? The easiest hardware implementation is to run the PIC and the phone (or GSM modem) at the same voltage. In this way there is no need for "level shifting", and the PIC Tx pin goes directly to the phone Rx pin, and the phone Tx pin goes directly to the PIC Rx pin.
I just wrapped up a project that uses the ADH8066 GSM modem for remote control and telemetry. Getting basic communication with the modem was very easy with the modem and the PIC (18LF2550) both running at 3.8V.
John
vortexe9000
PostPosted: Sun Jan 29, 2012 4:36 am     Reply with quote
fd
PostPosted: Sun Jan 29, 2012 7:27 am     Reply with quote
yes, you should follow with 0x0d. This tells the command interpreter
you are finished with the command and to process the command.
PostPosted: Sun Jan 29, 2012 10:42 am     Reply with quote
also you should add 'errors' to the use rs232(...) options if you want to receive anything back from the phone....
ezflyr
PostPosted: Mon Jan 30, 2012 7:58 am     Reply with quote
vortexe9000 wrote:
Should I send the command "AT" followed by the character "13" which means the key presses ENTER CR Question Question Question
Do yourself a huge favor, and connect the phone to your PC via a MAX232 IC (or equivalent), and "exercise" the phone using Hyperterminal. In this way, you can determine what commands the phone will respond to, and the exact syntax of the reply. Once you know all this, you can write your 'C' code to do the same thing. This may take you a little while to set-up, but it will be a huge time saver in the end!
John
