Float performance
FMOpt2000
Float performance
PostPosted: Wed Jan 25, 2012 9:42 am     Reply with quote
I've a firmware on which I need to normalize some result.
The firmware has a polling structure and the float division use a lot of time.
I don't need a particular precision.
When the firmware starts, reads from EEPROM 2 values and I calculate
the "normalizzazione" variables (L=left,R=right).
During the polling, I do the float computation.
Is there a way to reduce the time computation in some way (reducing the precision)?
Here, part (incomplete) of firmware:
main()
    limit_foot_h_left=read_EEPROM(0x00);
    limit_foot_h_right=read_EEPROM(0x01);
    normalizzazione_L=((127-limit_foot_h_left)/100.0);
    normalizzazione_R=((limit_foot_h_right-127)/100.0);
while (1)
   pot_lev_2=127-(127-pot_lev_2)/normalizzazione_L;
PostPosted: Wed Jan 25, 2012 10:40 am     Reply with quote
Quickest solution is to NOT use floats ! Really, just use simple int8 bit math as the data appears to be 8 bits anyway ?
Also consider /128 as opposed to /100.0 . That will shave a LOT of time off the 'math', though you may need to adjust the result.
Since we don't know the range or precision or accuracy required it's hard to guess which is better overall since the application is unknown to us.
SherpaDoug
PostPosted: Wed Jan 25, 2012 4:33 pm     Reply with quote
Also note that multiplication is faster than division. If you can precalculate X=1/normalizzazione_L and then multiply by X when needed it will be faster.
But if there is ANY way to use long ints instead of floats it will be much faster.
consider:
pot_lev_2=127-(127-pot_lev_2) * Xnormint / 256;
where Xnormint is a precalculated 16 bit int.
FMOpt2000
PostPosted: Thu Jan 26, 2012 8:39 am     Reply with quote
Good,
I've improved a lot the polling rate, but in some cases
the RS232 is blocked by an over-rate.
Is there a way to reset/flush the buffer or port?
PostPosted: Thu Jan 26, 2012 9:18 am     Reply with quote
you should have 'errors' added to the use rs232(....) options....
