jjude
Compiler say "Undefined identifier" |
Posted: Tue Jan 24, 2012 2:39 am |
Complier 4.099
PIC 16F616
#include <16F616.h>
#device adc=8
#FUSES WDT //Watch Dog Timer
#FUSES INTRC //Internal RC Osc
#FUSES NOPROTECT //No code protected from reads
#FUSES IOSC8 //INTOSC speed 8MHz
#FUSES NOMCLR //No master Clear pin enabled
#FUSES PUT //Power Up Timer
#use delay(clock=8000000)
#use fast_io(a)
#use fast_io(c)
#bit ECCPAS0 = 0x17.4 // Auto shutdown control bit (ECCPAS-reg)
#bit ECCPASE = 0x17.7 // PWM start/stop control bit (ECCPAS-reg)
#include "Aliohjelmat.h" //Subroutine
set_tris_a(0b111011); // 1=input, 0=output.
set_tris_c(0b001111);
output_float(PIN_C0);
output_float(PIN_C1);
output_float(PIN_C2);
setup_adc(ADC_OFF);
setup_wdt(WDT_2304MS);
restart_wdt();
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_1,99,1);
ECCPAS0 = 1; // < ------ This is OK.
ECCPASE = 1; // < ------ This is OK.
set_pwm1_duty(0L);
setup_ccp1(CCP_PWM | CCP_SHUTDOWN_ON_COMP1);
setup_vref(VREF_HIGH|REFERENSSI);
setup_comparator(CP1_C3_VREF | CP1_OUT_ON_A2 | CP1_INVERT);
void eteen_kiihdytys() <- Subroutine
restart_wdt();
nopeus = NOPEUS_START;
kiihdytys_nopeus = NOPEUS_OK - 20;
set_pwm1_duty(nopeus);
ECCPAS0 = 1; < ----- Undefined identifier ECCPAS0 !?!?!?!?!
ECCPASE = 0; < ------ This is OK.
delay_ms(10);
while((!ECCPASE) && (nopeus < kiihdytys_nopeus))
restart_wdt();
nopeus = nopeus+20;
delay_ms(10);
if(!input(PIN_C2)) suunta = 20;
if(suunta == 20) if(input(PIN_C2)) suunta = 30;
if(!ECCPASE) set_pwm1_duty(NOPEUS_OK);
kahva_old = kahva;
return;
Posted: Tue Jan 24, 2012 5:18 am |
This normally means there is a syntax error several lines _earlier_.
The compiler flags an error, when what it is trying to do becomes impossible. Unfortunately the root cause, can often be something else many lines before.
Since you have cut and carved the stuff in front of it, there is no way we can help. However (for example), you will find people having faults like this, often having something missing like a bracket, semi-colon, or comma even sometimes in something like an include file, hundreds of lines earlier....
jjude
Posted: Tue Jan 24, 2012 5:45 am |
Ttelmah wrote: | Since you have cut and carved the stuff in front of it, there is no way we can help. However (for example), you will find people having faults like this, often having something missing like a bracket, semi-colon, or comma even sometimes in something like an include file, hundreds of lines earlier....
If I only to add a line of subroutine #bit ECCPAS0 = 0x17.4 compiler is OK ?
void eteen_kiihdytys() // <- Subroutine
restart_wdt();
ECCPAS0 = 1;
ECCPASE = 0;
delay_ms(10);
restart_wdt();
nopeus = nopeus+20;
delay_ms(10);
kahva_old = kahva;
return;
Douglas Kennedy
Posted: Tue Jan 24, 2012 7:57 am |
Might it be you have ECCPAS0 once with a zero and the other with a capital letter O. |
jjude
Posted: Tue Jan 24, 2012 8:29 am |
Douglas Kennedy wrote: | Might it be you have ECCPAS0 once with a zero and the other with a capital letter O. |
No. All ECCPAS0 is zero. |
Posted: Tue Jan 24, 2012 11:01 am |
Have you actually 'cut and pasted' the name between the locations?. This has all the symptoms, of the actual value typed, accidentally having an invisible character in it. Used to be a standard 'trick' for testing how programmers think, where you include a character that doesn't display on the selected font, in the name, and see how long it takes people to work out why the variable isn't recognised as it should be.
jjude
Posted: Tue Jan 24, 2012 11:32 pm |
Ttelmah wrote: | Have you actually 'cut and pasted' the name between the locations?. This has all the symptoms, of the actual value typed, accidentally having an invisible character in it. Used to be a standard 'trick' for testing how programmers think, where you include a character that doesn't display on the selected font, in the name, and see how long it takes people to work out why the variable isn't recognised as it should be.
Yes, i copy/paste, no invisible characters!
Aliohjelmat.h files is 5 subroutine, all need paste
#bit ECCPAS0 = 0x17.4 - rows.
I don't understand.
Sorry my bad english... |
jjude
Posted: Wed Jan 25, 2012 6:19 am |
I moved "#bit-rows" subroutine files and now compiles OK.
#bit ECCPAS0 = 0x17.4 // PWM auto shotdown contro
restart_wdt();
ECCPAS0 = 1; // Autoshutdown enabled
ECCPASE = 0; // PWM-start
delay_ms(10);
restart_wdt();
nopeus = nopeus+20;
delay_ms(10);
kahva_old = kahva;
return;
Next subroutines
Next subroutines
Next subroutines |
Posted: Wed Jan 25, 2012 10:54 am |
One little thought leaps into my mind at this point.
Are you compiling directly with the CCS compiler/IDE, or are you perhaps using MPLAB as the development environment?.
This fault is 'classic' for the latter, and having made the mistake of putting the names of the 'include' files, into the project definitions. If this is done, MPLAB will attempt to compile these separately, so stuff defined in the main file won't be defined.
Only C files that should themselves be compiled should be in the project definitions when running this way.
